Vokera combi boiler
The boiler heats the water but the radiators are not working. When I switch the central heating on the green light flashes for a while and then goes red. Please help.
  • 2 more comments
  • thinkingfish Aug 12, 2008
    any idea as to how to get air out of the system?
  • bath1959 Nov 30, 2008
    My new boiler 14 months old heats the rads on dual setting. for about 20 minutes then cuts out to \solid \red light. \sometimes it cuts out earlier when I TURN ON THE HOT TAPS. Sometimes there is hot water and sometimes not.
    When I put it on the summer setting (ie hot water only) the green light flashes i hear the boiler kick in when i open a hot tap but there is no hot water.
    This is frustrating for a family of four which includes a three year old. Its freezing and taking stress from my wife and kids,
    I have heard I may need to replace the thermistor or Venturi to fix the rad.
    Help. Anyone.
  • scottia Jan 13, 2009
    Vokera Compact: Constantly have to reset it after about 30mins or will cut out if you try to put heating and hot water on at same time.
  • noahgroves Apr 20, 2009
    vokera boiler.error 21 keeps appearing.why
Air in system
Posted on Aug 11, 2008
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
MY VOKERA BOILER IS NOT WORKING I HAVE NO HOT WATER AND NO HEATING
try check in the water pressure on the boiler should be on 1.5 bar
Jun 01, 2010 | Heating & Cooling
Problem with hot water from Vokera Excell 80sp boiler
Hi - hope someone can help. I have a VOKERA EXCEL 80SP combi boiler and been without hot water/central heating for two days. The pilot light is on, the fan is on, but boiler not triggering once the hot water tap is turned on.
Hopefully someone come to look at it today but hoping for some advice. Anyone else had this problem?
Thank you.
Dec 21, 2009 | Water Heaters
Bled radiator and now boiler is losing pressure
if your boiler is a combi re-pressurise locate filling loop and refere to manual
Oct 09, 2009 | Water Heaters
Vokera combi boiler
there is a zoneing valve thats suppose to be in the line to keep this from happening, might even have a check valve either way which ever one you have is bad and should be changed with a new one
Feb 20, 2009 | Water Heaters
No hot water from combi boiler
i have a combie bolier when i turn the hot water taps on only cold water comes out central heating working fine can any one give some advise ?and can i fix it myself.
Jan 03, 2009 | Combi Centre DX - Mango
COMBI BOILER /CENTRAL HEATING
the boiler should modulate to controll the radiator temperature but the central heating will go off whilst you are drawing hot water
Nov 13, 2008 | Water Heaters
Heating & Cooling Logo
901 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
