Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 90 plus series spin dry is not working
I have a Kenmore 90 plus series washer that is not spin drying the cloths. I hear the motor going i think. The water is draining out, but not getting the excess water out of the cloths before they go to the dryer.
The wash cycles are working.
There is a part between the moter and something else and i can turn it by hand when I lay it over on its side.
  • 1 more comment
  • Anonymous Dec 01, 2008
    inner cage won't spin during spin cycle. I took the back of the washer apart and the motor is running but makes a horrible sound. i don't know if it is a berring or what, but the gear directly connected to the cage doesn't spin. I know that particular gear isn't locked up because I can spin in manually
  • Anonymous Dec 29, 2008
    I have a similiar problem on my series 90 washer by kenmore - agitator is working fine but the water does not drain at all and it will not spin dry at all. The coupler appears to be intact ( although the alternate pins on the motor side are somewhat loose with some play to them.) What would you suspect to be the most likely solution to this problem?
  • alaingarner Feb 23, 2009
    Same problem, washer agitates and pumps out the water, but the spin cycle doesn't work. Motor is running but drum doesn't spin. Lid switch works fine. Can torn drum by hand with a little force.
In resposnse to guest Dec 29th - I read further and later tested the lid switch. That did the trick. Thank you for the information contained on this site: not only did it save me a service call, but my wife was ready to purchase a new unit. Thanks to all those that have contributed in the past, your knowledge is invaluable to the do it yourselfer. C.F.
Posted on Dec 29, 2008
Doesn't agitate and spin cycle work when reset
you have a worn motor coupler
you can order a new one at sears
and its a ver y easy repair
Oct 06, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
I have a Kenmore 90 series that i have to run through drying cycle twice before the clothes get dry"
try washing the lint screen it gets blocked if you are using fabric sheets
Apr 28, 2009 | Washing Machines
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 90 Series washer needs two spins to remove water
We have exact same washer. It is 11 years old. We are at a point where we have to spin it 7 times and then still isn't too dry. It dies yesterday a very loud death. Mentioning this here because it could be a foreshadowing of your Kenmore 90's future.
Dec 29, 2008 | Washing Machines
Kenmore 90 series washer will only spin with a couple of pieces of clothing in it, when I add more wet clothing it will not spin. If I take some cloths out it will then spin. When washer spins the water is...
looks like you have a defective motor or a leaked load capacitor need to get the motor rewired....or get a new motor for your washer..... have the capacitor checked....
but ya the issue is 1 of the 2....faulty cap/motor
Nov 12, 2008 | Kenmore 15864/15862 Top Load Washer
Kenmore 90 series
you can look at the water pump inlet and outlet hoses. sometimes socks and other small items would be sucked in and blocked the water from going out.
another theory would be the clutch on the spin cycle is slipping that is why the drum is not spinning as fast as it should.
tnx 4 using fixya,
Sep 02, 2008 | Kenmore 15864/15862 Top Load Washer
Kenmore washer - water is emptying from tub but clothes are not spinning dry
replace door switch.If the computer thinks the door is open, it will not fast spin as a safety precaution.
Feb 27, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
867 people viewed this question
Sal De
 Brian Main
Brian Main
