Question about Dirt Devil Vacuums
When i am vaccuming it is really hard to push how do u change that setting
    Novelist:
  • 97 Answers
Raise your height adjust, and replace your belt. This will fix 99% of the problems with vacuums being hard to push.
Your height should only be as low as it takes to get your brushes to just make contact with your carpet. Peoples' natural inclination is to slam the vacuum as low as possible to deep clean the carpet, but in reality it's restricting your airflow and is cleaning less effectively, as well as making it harder to push.
A properly designed vacuum should be easy to push any time there's a new belt on. If these two solutions don't make it any easier, make sure your wheels are spinning free on the bottom.
-R
Posted on Aug 09, 2008
After changing the bag on my riccar it is very hard to push'
after putting a clean bag into the vacuum cleaner, more air can get through it, so it generates more vacuum, sp it is obvious, that it will be harder to push for some time. if it wont get better, it only means you didnt gt it with a clean airbag
Apr 22, 2013 | Riccar 8955 Upright Vacuum
My change floor setting on/off button blinks and it is really hard to push but it doesnt **** up like it use to either.
I'm sorry to hear you're having difficulties with your Dyson cleaner. From your description, it sounds as if you have a DC28 Animal, rather than a DC17 Animal. If the cleaner seems hard to push, and an indicator light is flashing, you may have the brushbar set to a level too low for the carpet you're trying to clean. Try raising the brushbar to the next height available on the selector pad.
If you need any further assistance with your Dyson, please get in touch with us directly - you can call us free on 1866MYDYSON.
Kind regards,
Jack
Dyson Online Customer Support
Jul 15, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
My dyson vaccum feels heavy and slow when pushing it. Please advise. Thanks
First make sure that brush roll is moving not broken belt....if all ok then try setting height for thick pile carpet lift head a bit this will ease off on a thinner carpet and in turn make it easy to push,
Jul 04, 2011 | Dyson Vacuums
No suction at all on my Kirby just cleaned the brush, etc... had a hard time getting the belt back on... really hate this vacuum cleaner
I have a kirby Diamond series and the 'green light' on the upper right side (while standing behind the vaccum) does not come on and when it doesn't come on I noticed that it does not sound as though it is picking up at all. I have changed the belt, placed a new bag in it and made sure that there is no clogs. What else could it be?
Apr 03, 2010 | Kirby Ultimate G Bagged Upright Vacuum
My new vaccum wont pick up cat hair
i would return this vacuum while it is still under warranty.
Aug 22, 2009 | Vacuums
My Windsor Versamatic plus has all of the sudden become very hard to push. I maintain this vaccum very well. It picks up fine, just to heavy tp push apparently
Likely the wheels are frozen with thread and hair at the sides of the wheels. Check for free movement of each wheel and pick out the debris around any that are hard to turn. Long needles and tweezers are good tools for this.
Jul 26, 2009 | Vacuums
Kirby G5 rear wheels lock up completely when in "Drive"
When wheels lock when vacuum is OFF - it is normal. If it happens when Kirby is ON then there are a few things that may have gone wrong
Primary drive belt is broken or something is wrong with plastic gears. See how to check the primary drive belt HERE.
If it is fine and gears are spinning - then something must be wrong inside the transmission. Parts for tech drive are not available from manufacturer so you are on your own. It is not really complicated - 2 clutches that engage and disengage depending which direction you push the vacuum. But if something in there is broken - you have to get a new tranny. It is not like getting a transmission for a truck but it still will set you back by about 100 $.
Good Luck
Rocky
May 16, 2009 | Kirby G5 Bagged Upright Vacuum
While vacuuming it's unusually hard to push.
I see your post is from May. I just joined Fixya this month so, id you're still looking for a solution, I would saythe belt broken or is so stretched the roller isn't spinning. Here is an link to an online guide with illustrations for changing belt. Also check the roller brushes for wear and change if necessary. Hope this helps.
http://www.info-vacuum-cleaner.com/oreck-vac-belt.php
May 02, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Vaccum has no suction
Need a new belt -- you might have suction but you need the brush to spin (hard to help without make or model, upright or canister)
Oct 17, 2007 | Kenmore 25614 / 25615 Progressive Bagged...
Vacuums Logo
329 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
