Question about Sonic Computers & Internet
When I reboot my PC or open Sonic, I get a Sonic Update Manager window that says "The feature you are trying to use is on a CD-ROM or other removable disk that is not available. Insert the 'Sonic Update Manager' disk and click OK". When I click cancel I get another window that says "An installation package for the product Sonic Update Manager can not be found. Try the installation again using a vaild copy of the installation package 'UM.MSI'. This occured after using "RegCure" and "ParetoLogic" - products that were only supposed to clean up my PC registry and temp files.
  • Mary Lynch Aug 09, 2008
    Your solution is to run yet another registry cleaner - this will not work. After running RegCure - a similar cleaner, a file that I need was deleted.
    Thanks for trying then - your solution does not fix my problem. The problem occurred after using a cleaner (RegCure & ParetoLogic) that removed a file that the Sonic Update Manager needs. Running another cleaner will not restore the missing file.
    Master:
  • 397 Answers
Download and install CCleaner.
You can use ccleaner to clean up all windows and internet temporary files, ren a registry clean and also in "tools > startup" stop that annoying Sinic nag screen from coming up.
www.ccleaner.com
Posted on Aug 09, 2008
  • Richard Finch Aug 09, 2008
    Well, what was inappropriate in my answer. Inappropriate is used for answers that are abusive or out of context. I think I gave you a solution. Please remove the rating. Thanks
    Registry cleaning is just one of the tools available to you with ccleaner.
    I am sure you are probably aware of MSCONFIG and how you can go to start up and remove or disable app's (programs) from starting with Windows and then you get the MSCONFIG nag screen the next time you boot your machine.
    Using the delete and disable feature in Tools > Startup of ccleaner avoids this nag screen and is a lot easier to use.
    I have only ever seen Sonic on store bought machines like HP, Gateway or Emachines, quite honestly these machines come bundled with a pile of rubbish programs that you don't need and have everything installed set to auto update slowing your machine down and sometimes producing the nag screen you are seeing now.
    I do this for a living and if you have one of these types of machine and want to get it running smoother and less stressed let me know and I will gladly help you.
Both of my dvd drive shows "This device cannot start.(code 10)" in device manager. i'm using windows 7 32bit thanks
make sure that the cd rom is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard
hope this helps or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
also
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
only do the registry check if you cant see the drive/s in windows explorer/my computer
or it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
May 14, 2011 | ASUS DVD E818A4 Disk drive DVDROM 18x IDE...
Dvd burner wouldn't close session - won't eject - now computer not acknowledging disk in cd-rom and it won't manually open. Rebooted several times. Rebooting taking longer now.
click start control panel administrive tools,computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Hope this helps
if your computer came with a motherboard disc the drivers could be on it
Click start control panel administrive tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver
hope this helps
Apr 28, 2011 | E-Machines emachines (emachinees) CD-ROM...
DVD/CD rom player is not working -and theres a "!" by the device-have tried updating from internet but computer says all correct updates are in placer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. Hope this helps
Apr 27, 2011 | Packard Bell Computers & Internet
Hi, The DVD/CD Rom Icon has dissapeared on My Computer. When I go to control panel - device manager and click on the dvd/cd rom drive icon I get the following message in the genaral...
You will need to re-install the driver. Right click the device in device manager and select properties. Navigate to the driver section and uninstall all existing drivers. (It may *not* give you the option to do that, depending on how corrupted the driver is, but it should.)
Reboot the PC.
Upon reboot, Windows should find the new device and install generic drivers. It will probably ask you to reboot a second time.
Apr 07, 2011 | LG GSA H62N Super-Multi - Disk drive - DVD...
Sonic cannot find writable equipment on my PC
When you open "My Computer", does the icon shows 'CD-ROM' or 'CD-writer' ?
When you open "Device Manager", and expand the 'DVD/CD' branch of the tree, is your CD-writer listed?
Jul 31, 2010 | Sonic RecordNow! Deluxe 7.3
Have just installed S1500 software and finished the installation but get an error message "Failed to initialize drinver module (0 X 80210019)". What does this mean and how do I proceed? ****
Try the following step :
Pre-Installation Steps
  • Log onto PC with an account that has Administrative Privileges.
  • Disconnect ScanSnap scanner, if connected.
  • Close any open applications.
  • Install ScanSnap Manager, ScanSnap & CardMinder software from the ScanSnap Setup CD-ROM.
    • Upon reboot of the installation you may receive an error message stating, “Failed to initialize driver module.” Please disregard and continue.
ScanSnap fi-5110EOX Vista Update Pack Installation Steps
  1. Download the fi-5110EOX Update Packs (Vista 32-bit Support)
    1. ScanSnap Manager V3.0 – ssv3020up.exe
    2. CardMinder V2.0L10-V2.0L11 – cm2012.exe
  2. Install all two update packs that were downloaded in Step #1.
    1. Reboot is NOT required after each update pack.
  3. Reboot the PC after all three update packs installed completely.
  4. Connect ScanSnap Scanner via USB, open lid, let Windows Vista install the new hardware.
Mar 07, 2010 | Fujitsu ScanSnap Manager
Tsstcorp cd dvdw ts-l633a scsi cdrom device can't read the driver or it is corrupt. I am getting error code 39
Using Device Manager, look to see it laptop is sensing the presence of the cd-rom. (if it is not on the list, try removing / rebooting / and then reinstalling cd-rom) If it shows on the list, click to open it's properties and then delete the drivers for cd-rom (this will cause the laptop to reload the drivers on the next reboot) if it still doesn't work, go to micosoft updates and try to update the drivers there. If it still malfunctions, then the cd-rom may be faulty. Try replacing it with another cd-rom and see what you get.
Oct 10, 2009 | Acer Aspire 5500 5570-2609 Laptop
Dvd rom problem
Try to turn off the vista's burning feature.
It's not yours or anyones burners....just an update in vista which buggered the policies up
Go to your run command and type (start.....Run.....)
type gpedit.msc
Go to User configuration/Administrative templates/Windows components/Windows explorer
On the right pane, double click on "Remove CD burning features" tick the enabled button, then OK.
Reboot or logoff/logon to apply.
If your vista version does not have the gpedit function, do the following.
Open regedit, go to:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
In the right pane, if it does not already exist, create a new 32-bit DWORD value. Name the new value as NoCDBurning, and assign the value data to 1.
This should fix the problem
Sep 07, 2009 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
Sonic record now program will not find cd drive
  1. Update your drive's firmware/drivers. Most companies regularly update their firmware and drivers. If you are unsure what model your burner is and its firmware, click here to find out.
  2. Enable DMA. Direct Memory Access enables better efficiency of data. For more info, check how to enable DMA.
  3. Your media. Check the following:
    • The disc is clean and unused.
    • The media is recommended by your burner's manufacturer or try a different brand, preferably a name brand, if you continue to have problems.
    • Make sure that media (-R/+R, -/+RW, dual-layer compatibility) is supported by the burner by checking burner's manual or manufacturer's website. This is especially true for some Blu-Ray burners which do not support CD-R/RW media.
  4. Lower the write speed of your burner.
  5. If your burner is external, make sure it is connected directly to the computer via USB/Firewire and not a hub or other other device like a sound card.
  6. Update to the latest PX Engine. The PX Engine improves compatibility with newer burners on the market.
  7. A reinstall of the burner's drivers may also help.
    • Windows XP: Go to My Computer and choose Properties.
    • Windows Vista: Go to Start --> Control Panel --> System and Maintenance --> Device Manager.
    • Click on the Hardware tab.
    • Select Device Manager
    • Expand DVD/CD-ROM Drives, then select your burner and uninstall it by right -licking on it.
    • Reboot.
Mar 24, 2009 | Dell Dimension 2400 PC Desktop
Please wait while windows configures sonic update manager...the feature you are trying to use is on a CD-rom or other removable disk that is not available....etc. I cannot get rid of this start up message
  • go to start/run then type in "cmd
  • when box opens, type in msconfig
  • go to start up tab and de-select the item that corresponds to that message.
  • close off, and next time you boot it will be gone
good luck
Terry
Apr 01, 2008 | Computers & Internet
Computers & Internet Logo
172 people viewed this question
Top Sonic Computers & Internet Experts
Richard Finch
Barbat Nae
Barbat Nae
Are you a Sonic Computer and Internet Expert? Answer questions, earn points and help others
