Question about Saeco Caffe Charisma Espresso Machine
Unable to get water to pump in order to prime
  • Anonymous Mar 08, 2009
    I used a turkey baster with cleaning solution in it and YEA it worked!
  • 515 Answers
Try to take a bellow pump or similary and force in water in the water inlet, make sure you have the steam knob open when you do this.
Posted on Aug 09, 2008
2 Suggested Answers
SOURCE: Am unable to prime water pump
Water is not being drawn from reservoir into boiler. The valve at the base of the boiler seems to function properly. After repeated attempts, I am unable to prime pump and fill boiler with water.
Posted on Jan 21, 2010
We have a blazemaster pump put new impellar kit in it but it still wont pump any water. have replaced all o rings and new suction pipe and foot valve there are no cracks in the casing.
Need to prime the pump. In order to overcome the air in the system you need to fill the pump with water. Check your owners manual on how to prime it.
Oct 15, 2016 | Pool & Spa
Machine says needs priming. Water light stays on but no water comes out when opening valve. No water for coffee either. Water pump broken?
hi,
can you hear a quite louder noise when trying to make water flow?
If no or very faint noise can be heard, pump is probably faulty or needs to be disassembled and cleaned (see tutos on the Net)
If you can hear a loud noise, the pump is working but unable to suck water, keep on trying, if still unsuccessfull you will have to open the machine and fill yourself the watel inlet tube to "help" the pump priming.
Hope that thelps
M
Apr 24, 2016 | Saeco Incanto Classic Espresso Machine
My machine reads "prime water system
The reply cannot be helpful if any explanation is offered without knowing the category, make and model of the coffee maker.
Basically the water flow in the system is slowed. The machine may need descaling.
If the pump is louder than normal, it is air locked and will need manual priming to let it pump normal.
The manual priming is to inject a few drop of water into the pump (just like a speaker needs a sip of water to continue his speech).
To manually prime the pump you can use a syringe, a Turkey bastor (if you are in USA) or use a hand pump made available with some makes (included as accessory with Saeco, Gaggia espresso machines).
For descaling you may use the link to order a reliable descaler:
http://www.shop.partsguru.com/DSC-6x2-Gurus-Choice-Best-Descaler-Economy-pack-DSC-6x2.htm
Mar 03, 2015 | Coffee Makers & Espresso Machines
I prime the pump, and the sprinkler system does not hold pressure. I have also tried to prime the pump from the intake side. what happens there is that the pump actually begins to shoot water back out the...
You can't prime the pump with the same water source you are trying to build pressure in. Shut off all the water going to the house, use the neighbors hose or have several gallons (maybe 5) to prime the pump and continue priming pump until it starts to build head pressure then plug prime hole.
RJ
Jul 05, 2011 | Flotec Corrosion Resistant Shallow Well...
Pump,run,but,no,water,no,susion
May be that you need to prime the pump...this is accomplished by filling the pump housing with water and then reconnecting to system...you may need to do this several times in order to get it running
Apr 26, 2011 | Plumbing
My machine displays "Need to Prime". I attempt to prime it but the message keeps reappearing. In other words is seems that it is unable to be primed in the usual fashion. Any advise would be...
Ventilate message
That means the pump needs to be primed by running water through the wand. Push the water button and open the knob on the right. You will hear the pump change tone when it primes and the light or message will disappear. If you have a restriction in the intake line the message will not go away. There is a flow meter inside the machine that measures water flow. If the flow meter does not spin when the pump is running, the computer thinks that the pump is not primed. Coffee grounds can get into the intake and restrict the flow meter. If you get a restriction in the water intake (below the water tank, on the machine) the pump may run and water comes out, but the flow meter does not create the jet of water to spin the turbine wheel to send impulses to the computer. You get the ventilate message. One thing to remember is when you are working on the water system (have the water tank off) do not fill the bean hopper and visa versa. Keep them covered when working on the other. Cross contamination will damage a machine fast
The first thing that I would check is the tip of the steam wand for a plug. If that is clear then I would suspect a clogged flow meter. If you can get the flow meter out it twists apart and don't loose the parts and the dot on the turbine goes up. Clean out the small opening on the bottom pipes where the hoses attach. Look inside and make sure that they are clear before reassembling.
Oct 22, 2010 | Starbucks Saeco Italia Digital Barista...
Dec 24, 2009 | Saeco Vienna SuperAutomatica Coffee...
Unable to prime Sirena Espresso Machine
n regards of the no prime issue. this is the only way i could prime this new puppy.make sure its stone cold which is a no brainer since it will not heat h2o unless its primed. first take off steamer plastic tip ,turn on steamer clock wise till pump starts. then **** the tip of the end of the metal tip hard until pump stops may need to do it a couple of times. yes this seems out of this world but it works. you are flushing out the vapor lock in the pump. bravo enjoy!
Nov 28, 2009 | Saeco Starbucks Sirena Espresso Machine
I have a flotec water pump that sits on top of my pressure tank, pump worked ok last season, and when we tried to prime the pump to start this season, it wont pull water up from the well pipe, pump will...
if the pump is working correctly, it can either be, need more water to prime it, or something in the well, such as low water, plugged filter, etc....sometimes when you have a system that is intermittently used, it can take 20 or 30 minutes of continuous priming to get it to pull, enough water to maintain the prime.
Apr 06, 2009 | Flotec Corrosion Resistant Shallow Well...
How to prime my Pool?
Prime is the term we use to state that the air has been mostly purged from the pump and the pump is moving water. When you have lost the prime, your pump is no longer pumping water through it. Sometimes it can be very difficult to regain the prime on the pump. This will tell you how to get the prime back in these difficult situations
Aug 27, 2008 | Intex 2500 Gallon Sand N Sun Pool...
Saeco Caffe Charisma Espresso Machine Logo
98 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
