Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool Top Loader Washing Machine - Model 3RLSQ8033RW2
My machine will not fill with cold water, only hot water, any ideas?
  • 481 Answers
It may be a bad water valve or just a clogged screen. take off the cold water connection from the back of the washer and clean out the screen you see inside the plastic piece the hose fits on. do not take it out, clean it while it is still inside.
Posted on Aug 12, 2008
Only have boiling hot water filling up in my top loader washing machine
Hello there ..... I will take the presumption the machine has been working okay for a while - if this was the case then you will require a replacement inlet valve for the cold water.
I do however find it extremely odd for a late model machine to do this as the safety parameters will not allow the machine to fill with hot water only - in all cases the cold will always fill "FIRST" followed by the hot water - it should have gone out on a fault code 48 or 49.
I will also assume you have checked the inlets for debris restricting the filters and the cold water inlet.
The only other option is to have the valve replaced.
Jul 15, 2011 | Fisher and Paykel GWL11 Top Load Washer
Does not take water ,hot or cold
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Jun 16, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
The cold water cycle is not working on my Roper washer top loader heavy duty
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
heatman101
May 12, 2011 | Roper RAX4232KQ Top Load Washer
Whirlpool Cabrio won't fill with hot water
heatman101
May 03, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Will not fill with cold water
heatman101
Sep 28, 2010 | Whirlpool LSR5132PQ Top Load Washer
Top loader washing machine does not fill up
very simple, your drain hose is below 4 ft, your drain hose should go in the hole between the hot and cold water, if you dont see a hole then it is covered, you need to knock out the hole...
Nov 10, 2009 | Washing Machines
WASHER WON`T FILL FULLY WITHOUT RE OPENING TOPLID SEVERAL TIMES?
water valve should be a single unit consisting of a hot and cold solinoid assembly. This whole valve assembly should be replaced.
Jul 20, 2008 | Washing Machines
Whirlpool top loader
You either have a defective pressure switch or water inlet valve. Start to fill the machine with warm water so that both solenoids on the water inlet valve (hot and cold) are activated. After about 30-60 seconds, push the timer knob in to stop water flow. If the water continues to flow, replace the water inlet valve. If this is the case, it may take a few times of starting and stopping water flow to allow solenoid to heat up and become symptomatic. If water flow stops abruptly each time knob is pushed in, you most likely have a defective pressure switch (water level switch).
May 09, 2008 | Whirlpool LXR9445JT Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
103 people viewed this question
Dan Webster
Dan Webster
Sal De
