Question about Frigidaire FWTBB30DS Front Load Washer
Frigidaire washing machine fwt449gfs1
I replaced the front door latch(from white one to black).
The machine worked for about 3 loads and now stopped.
Door Lock light turns on and off correctly.
Does the new(black) door lack have to be modified?
dave
SF CA USA
Check to see that the switch is actully being activated when door is closed. I wiggled the door upward to notice the machine started working. I then wedged a piece wood or wooden pencil in the botton of the door crack and that caused the switch to activate.
Switch is okay but the door alignment needed to be fixed.
Posted on Aug 25, 2009
My affinity washer door wont close. Seems the door lock is not working or something is stopping the door from latching
you may have broken off a piece of the latch
(hook portion) either on the door or the receiver portion on the machine. check for diagrams online using model #
Apr 04, 2016 | Frigidaire Affinity FAFW3577KW 3.5 Cu. Ft....
Frigidaire washer door catch is stuck, washer won't run
After looking at the schematic of this machine it seems that the door AND the control board have to work perfectly together in order for the safety mechanisms to operate correctly. You may have a bad control board or a loose wire. The best thing to do is look closely at a schematic and make sure that everything looks right. here is a blueprint: http://www.pcappliancerepair.com/model/index.php?id=FWT449GFS1
Jan 03, 2014 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire front loading washer model FWT449GFS1
For a repair manual, contact Frigidaire directly.
Oct 07, 2017 | Washing Machines
I have a two-year old Frigidaire GLTF2940FSO front loader washer that has stopped in the middle of a load leaving water in the drum and will produce a buzzing sound no matter what cycle you put it on. We...
did you try unplugging it and plugging it back in to see if you can get it to reset? Would it buzz when you try to drain it? Does the door latch lock when it goes into the wash cycle? Usually the door latch locks when it goes into the wash cycle and stays locked. So it filled up, the door latch should lock, then should go into wash cycle. Then you said few minutes later it stops. How did you get the door open? reason i ask is Usually i would see the clothes get stuck inside the washer because the door latch is still locked when it stops. Was the door unlocked when it stoped. If so maybe something going on with the communication from the board to the door latch maybe. Did you try operatin the drain?
Aug 01, 2009 | Frigidaire GLTF2940ES Front Load Washer
FWT449GFS1 front door buzzing Frigidaire front loading washer
Could be rubber door boot needs replacing. I am in the midst of replacing mine because door won't stay closed and buzzer sounds till I hold in door.
scott
newcastle on.
Jul 30, 2008 | Washing Machines
Affinity washer not wanting to spin!
My Affinity washer quit spinning during the rinse cycle 14 months after we purchased the machine. We checked to make sure ithe drain was clear, and we tried changing the size of the loads. Nothing we tried worked. I was not getting any error codes on the control panel. We called a technician out to our house to see if it could be fixed. He diagnosed the problem as the control panel. We called Frigidaire to see if they would help us out with the cost of the repair since the machine was only 14 months old, even though our one year warranty had expired. They stated that they would not cover the replacement of the control panel. After the technician replaced the control panel and tried the machine, it still did not work. He called the Frigidaire tech support to find out why, and they told him that he needed to replace the door latch system, not the control panel. After he replaced the door latch the machine worked fine. When researching this problem online, I discovered that Frigidaire has had several problems with the door latch system on their front loading washing machines. They previously had a class action lawsuit due to this problem. When I found this out, I called Frigidaire to see if they would pay the repair bill we had incurred, even though our warranty had expired 2 months ago. After they contacted the technician that worked on our machine, Frigidaire decided that they would pay the cost of the replacement door latch and the labor fee. We had to pay for the cost of the initial service call. If you are having this problem, I would suggest that you contact Frigidaire. They will require that you have a diagnosis made by a certified technician. According to our technician, the flow chart for the Frigidaire front loading machines is inaccurate, so if they make an initital diagnosis of a faulty control panel you may want to have them contact Frigidaire tech support to double check the diagnosis. Frigidaire may help cover the cost of repair if your machine has a problem with the door latch.
Dec 18, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire FWTBB30DS Front Load Washer Logo
217 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
