Question about Sony Audio Players & Recorders
CD837 am fm radio....Please tell me how to set the time,as I can't find the book.
  • oepbc Aug 10, 2008
    couldn't ask for anything better...
    President:
  • 1,114 Answers
Hi - You can download the manual from the link underlined in blue below:
CD837
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Posted on Aug 09, 2008
  • Greg Cann
    Greg Cann Aug 10, 2008
    Thanks for the good feedback, it makes it all worthwhile!
    Best regards,
    Informatica.
Electricity disrupted, reset buttons will not respond
if its a gfci receptacle its probably bad just change the receptacle if its a breaker and it resets and trips something is going to ground and making it trip back out or the breaker could be weak if its a square D box it will be a simple fix just take the cover off and pull it out it clips in the box no unwiring required. but back to the gfci you could have a bad connection or a bare spot in a wire its hard to diagnose on a computer
Aug 29, 2015 | Sony White Dream Machine Icf-cd837 Am/fm...
Connecting mp3 car radio
If you radio has an Aux input then you can connect a audio cable from your MP3 player to the Aux input on your radio.
If your radio does not have an Aux input the you can use a FM transmitter device. Connect the MP3 player to the FM transmitter and tune your FM radio to the radio frequency on this FM adapter to listen to your audio book on your MP3 player.
Check out these WEB sites fro FM transmitters.
http://dx.com/c/car-accessories-799/car-audio-systems-707/fm-transmitters-players-710
http://www.amazon.com/Coby-CA-745-Wireless-Transmitter-Cigarette/dp/B000OTF6G0
http://www.popularmechanics.com/technology/how-to/gadgets/4307160
Feb 05, 2013 | Audio Players & Recorders
TIMEX Dual Alarm AM/FM Calendar Clock Radio - T433B Can't figure out how to set alarm time...
On the manual below on page 7 and 8 will tell you how to set the alarm.
http://www.manualsonline.com/mdownloads/64580048-2a62-445b-b8f9-911293790997.pdf
Good Luck and please rate 4 thumbs up for the free answer
Sep 25, 2010 | Timex AM/FM Alarm Clock Radio
No sound when put on 88.3 fm
I didn't think this unit had an included FM transmitter - so I looked around for more info, and everything I've found indicates it does not.
It will however play audio via the built-in speaker or headphone jack. Use of a third party FM transmitter will allow playing audio (navigation, alerts, MP3 or audio books) when connected to the headphone jack and with both the FM transmitter and FM radio set to the same frequency.
The FM transmitter will work best when set to a frequency that is unused and has the least amount of interference from adjacent stations. Check by tuning the car radio across the FM band and note frequencies that have those qualities. Leave the radio on one of the clear frequencies and set the FM transmitter to the same displayed on the radio. You should try several to find the one that works best. Also, be aware that as you travel, you may enter an area where that frequency (or one close by) is in use by a broadcaster. This will require repeating the process as needed to reduce interference.
Oct 16, 2009 | Garmin Nuvi 350 Car GPS Receiver
Kenwood KDC-MP442U / Perset stations
goto the stattion you want then hold down the button you wanna save it as i.e
tune into 97.50 for essex fm
then hold down button 1 for couple of seconds
Job done :)
Upfront Audio
please rate :)
Apr 03, 2009 | Kenwood KDC-MP235 CD Player
Ow do i set the time of my sony alarm clock with radio?
I just did the trial and error thing. it's okay now. thanks
Jan 26, 2009 | Sony Dual-Alarm AM/FM Clock Radio with...
Radio code
If you don't have the radios security code, you can try entering 1111 as some replacement radios were coded with this security code. Your local Audi Dealer may be able to provide the correct security code for your vehicle, if you provide them with your vehicles Identification Number (VIN). This VIN is typically located on the drivers door pillar.
The radio should have a serial number on the unit which also can be given to the Audi dealer and checked in their data base of radio security codes. The serial number will start with AUZ, one radio serial number for example is AUZ1Z9A1965412.
To enter the code on the Wiesbaden Radio: Turn on the radio, SAFE should be displayed.
Push and hold the AM/FM button, then while holding the AM button down, push and hold down the SCAN button. Release the AM/FM and SCAN buttons, and the display should show 1000. Now enter the correct code using the radio pre-set station buttons (1-4). Button 1 changes the first digit in the code "1"000, Button 2 changes the second digit in the code 1"0"00, button 3 changes the third digit, button 4 changes the last digit in the code. In most cases the first digit is a 1 and won't need to be changed. You push each pre-set station button multiple times to step through the digits (1-9) to get the correct code displayed.
Code 1246 would entered by pushing button "2" two times, pushing button 3 four times, and pushing button 4, six times.
After entering the correct security code, push and hold down the AM/FM button, then while holding down the AM/FM button, push and hold down the SCAN button. The display will then show SAFE, release the two buttons, and now the radio should play correctly.
Sep 19, 2008 | 2001 Audi S4
Saving radio pre sets and book marks, I don't understand and manual is vague
reload the latest firmware from creative website
http://us.creative.com/support/downloads/
Dec 22, 2007 | Creative Labs ZEN V Plus MP3 Player
24 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
