Question about V, Inc. Vizio P4 Plasma Television
Vizo VX42L HDTV10A
My TV has ousnd problem. After turining on the TV for 15-30 minutes, sound turn off and then if I turn off the Tv and turn on again sound come back and the process repeat again. I called a Tv repair guy and he told me that digital sound board is bad, however I can not find sound board in the part list of vizio. Vizio repait solution was telling it is main board. If anyone, know what is the actual problem
  • 92 Answers
This is most likely the main board problem. There are many different types of main board for this model. you can get the parts at vancebaldwin.com but make sure you give them your serial number so that they could send you the correct one.
Posted on Jun 16, 2009
Vizio vx42l hdtv10a preset picture too bright
You should be able to change the brightness levels in the menu.
Jan 13, 2013 | Vizio VX42L 42 in. LCD TV
Vizo VM60P HDTV10A will not power up. Logo Dark
the unit needs to be examined by someone able to do so---first place is to look at the power supply for the set......
Aug 26, 2012 | Vizio VM60P 60 in. Plasma TV
Vizio vx42L HDTV10A screen flickering, all the the time.what is wrong with it.
make sure all cables are seated all the way in. unplug set for a couple hours.
Mar 22, 2011 | Vizio VX42L 42 in. LCD TV
I have aVizio VX42L HDTV10A. was watching a show when we heard a loud pop.Then all went dark. Would not turn back on. I took off the back cover and found the ceramic fuse was blown on the board # DPS-283AP...
This means you have a dead short, It is probably a Diode in the power supply area, but without testing board you don't know. If you know basic electronics, i would say check all diodes in power supply and look hard for something burnt and replace that also. Or just replace power board, check shopjimmy.com
Dec 08, 2010 | Vizio VX42L 42 in. LCD TV
Vizio VX42L LCD TV died?
it is the power supply. in the given scenario like yours, the PSU is the suspect in 90% of the cases.
Apr 09, 2010 | Vizio VX42L 42 in. LCD TV
Vizio vx42L no power will not come on just went
First place to check will be the power supply, look for blown fuse, burnt parts, bad caps with bulging tops. Check for DC voltages, you should have 5, 12, and 24vdc at the power supply DC output connectors.
Parts: check www.shopjimmy.com
Jan 08, 2010 | Vizio VO47L 47 in. LCD TV
Vizio VX42L HDTV10A No sound, No picture, logo lights up
Vizio VX42L HDTV10A No sound, No picture, logo lights up.
Jul 31, 2009 | Vizio VX42L 42 in. LCD TV
Vizio vx42l hdtv back light
If backlight went out then sound should still work. Are there any indicator lights to show power is coming on anymore? Try unplugging for 30 seconds, hit power button a few times, then plug back in and try to turn on. This drains any capacitors of power to attempt to reset (basically clearing the TV's throat).
Can also try something on a different input. If current input is composite, S-video, or component, try using DVI or HDMI connection as this uses a different board in the TV. If that fixes it, then at least you can try to replace one board instead of entire tv. :)
Apr 06, 2009 | Vizio VX42L 42 in. LCD TV
V, Inc. Vizio P4 Plasma Television Logo
175 people viewed this question
Top V, Inc. Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
rostit
Are you a V, Inc. Televison and Video Expert? Answer questions, earn points and help others
