Question about Lexmark X2350 All-In-One InkJet Printer
Paper is jamming
After placing paper in feeder according to guidelines it hangs up on the right side and will not feed through. This is regular copy paper. what shall I do?
  • maynez Aug 16, 2008
    paper feeds only from one side but also, i get a message that says that printer can't print because printer is busy. the power light blinks non-stop
I found the problem. there was a huge paper clip stuck in the printer.
Posted on Aug 16, 2008
Perhaps clean the rollers...the dust build up tends to not allow the paper to be fed down and printed on
Posted on Aug 13, 2008
Epson stylus DX3800 All in one printer, scanner Unable to print
Open the printer cover and look closely for tiny paper shreds that might got stuck between the rollers. If you have a canned air, try blowing out the paper path as those tiny piece of paper might be blocking the paper sensor.
Sep 20, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Konica 7025 paper jam
Does this happen when he orginals go thur the document feeder? How does the copy look if the orginal is placed on the glass. Vertical feed problem mite be dirty rollers or dirty clutch,
Aug 13, 2009 | Konica Minolta Office Equipment & Supplies
Paper twists when feeding
there is something stuck in the feeder.place one thick paper and help it with your hant to pass into feeder.anything is inside will unstuck
Nov 04, 2008 | Epson Stylus Photo 950 InkJet Printer
Landscape copies get stuck
The roller may have something stuck in that area, something even as small as a peice of paper can continue to make it jam. if not, you may have to call the company to get a repair guy in... umm... or repairGirl?
May 17, 2008 | Toshiba 2060 Copier
Paper feed on Canon i 350n ink jet printer
If the paper is lodged too far into the printer and can't be removed:
Press the power button to turn the printer off.
Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
Close the front cover.
Press the power button to turn the printer back on.
Resend your document to print.
Ensure that:
The paper is a recommended paper for inkjet printers.
You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
The printer is on a flat, level surface.
The left paper guide is against the side of the paper.
You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
The left paper guide does not cause the paper to bend in the sheet feeder.
Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
Envelopes or the appropriate specialty papers are selected in the printer driver.
You are using a paper or envelope size supported by your printer.
May 13, 2008 | Canon i350 InkJet Printer
Paper jam
I removed paper from jam, red light will not quit flashing, I turned
printer off and on again, but it will not print and red light will not
quit flashing, What can I do?
May 12, 2008 | Office Equipment & Supplies
Jammed paper
Ensure that:
Apr 28, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
False paper jam
Ensure that:
Apr 25, 2008 | Dell 922 All-In-One InkJet Printer
Paper jam
Turn the printer off and open the access cover.
Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
Watch the paper as it feeds through and try to determine where the jam is occurring.
Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
Turn the printer off.
Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Ensure that:
Mar 24, 2008 | Office Equipment & Supplies
Brother MFC paper jams on one side
Honestly? Unplug the machine...REMOVE THE DRUM UNIT!!!!! and other parts not locked down. Turn it upside down and shake it lightly to moderately. You can also try holding the lever forward while you do this. This has worked for so many machines you would be surprised. You might be even more surprised what comes out. I have seen pens, pieces of ceiling tiles, wire clippings, Matchbox cars, and grape jelly (I didn't ask).
Dec 16, 2007 | Brother MFC 6800 All-In-One Laser Printer
Lexmark X2350 All-In-One InkJet Printer Logo
76 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
