Question about GPS
Lost info on sd card
No maps
  • mrrf89a Aug 20, 2008
    I have the same problem, a pioneer avic s2 with no maps. Please help.
  • wellted1968 Dec 06, 2008
    I have lost maps from the SD card on the S-3 model Nextar also. Have you had any luck yet?
I lost the map on my sd card for my viamichelin x-930
Posted on Apr 10, 2009
SOURCE:
SOURCE: Lost my tomtom one SD card
torrent maps from thepiratebay.org
Posted on Mar 11, 2008
SOURCE: Fine Drive 400 Software/Maps
> How do I get it to go to Louisiana?
You internal GPS antenna does not work.
Buy an external GPS antenna for FD400
on eBay $10+$10 shipping = $20
Posted on May 14, 2008
  • 3 Answers
SOURCE: tom tom sd card wiped clean
more than likely, I just purchased a new tomtom sd card on ebay with all the new maps on it, ver.7 got it for a UK seller no problems, did you back it up on your computer? hopfully you did, then you can just connect it to tomtom home and reinstall it.
Posted on Oct 21, 2008
SOURCE: TomTom One map download process
baho
Posted on Dec 02, 2008
KingDWS
  • 1606 Answers
SOURCE: Move Maps rom SD Card to Unit
All you need to do is go into the setup menu and select the default map ie the one that is in memory not the card. Then it won't look at the card and you can remove it. The nuvi doesn't need the card at all unless you have it looking for extras on it such as maps voices etc.3
Posted on Mar 09, 2009
How to access maps on sd card
Same map name on internal memory and sd card can be problem.You can also try to upgrade your software with garmin web updater,but be sure that your battery is fully charged before doing an update.
Jul 27, 2014 | Garmin nuvi 1490T GPS Receiver
Update download for tom tom xxl 540s is too big for unit, lost all maps
Theres good news for you, you can get a SD card for your tomtom, and all you have to do is to install or download your maps on the SD card then fix it into your tomtom and you will be able to view your maps from there. For the lost maps, connect your tomtom to your computer, be sure to have your drivers software, then you select your tomtom form your computer, then you install all lost maps back on it by restoring all old maps. But for large downloads, download all new maps on a SD card. That should do the job.
Hope this information came in handy.
Dec 21, 2010 | Tomtom XXL 540S GPS Receiver
I have 2010 maps on a SD card for my Nuvi. Does
If you already have a map on your unit, you will have both maps. You may have to enable the map on the SD card. At the main menu, press the wrench symbol, then the map icon and then "map info". You should see all of your maps that are available to your unit. Make sure that the square boxes next to each map are checked. Thats how you turn on/off (selct) each map. If the SD card map isn't working, make sure it has a unlock code assigned to the map or it won't work on your unit. Also, the map file name on an SD card is different than the name on your unit. - Jim
Jul 21, 2010 | Garmin Nuvi 660 GPS Receiver
I need help installing a map onto a gramin sat nav
No. They are refering to maps sent from the computer to the Garmin device. Maps are not transferred off the SD card to the unit. Simply insert the SD card into the device and the Garmin will read the maps from the card.
to double check follow these steps
  1. Power on the unit with the card in
  2. Press Tools
  3. Press Settings
  4. Press Map
  5. Press Info (or map info)
This page should list out both your UK and Ireland maps(old as dirt) and your new Benelux and France maps as well
Apr 20, 2017 | Garmin Nuvi 600 Car GPS Receiver
How to upload maps in garmin 200w from sd card
on menu touch tools, maps, map info, tick the box, you may need unit I.D. and serial number.
Regards.
Mar 21, 2009 | Garmin Nuvi 660 GPS Receiver
I have a Finedrive 400 gps. When I turn it on it says it cannot find the card. I'm guessing the SD card lost map info, odn't know why. went to Finde Drive and their updates are $110. Do you know of sites I...
This is a common problem with these units, it happens if the unit is shut off while its writing data to the SD card.
one solution is to visit C&C wireless and pay over $100 for a map update or even send them your unit for even more $. see http://www.finedrive-acc.com/shop.cart?action=ITEM&prod_id=F400-08CP
The other solution was to send it to Fine Digital but they closed their doors in the US so they no longer support us customers. Because of this I made a DVD with map data I purchased from them before they closed and I added much better instructions; this DVD updates the firmware in the unit and loads the last map data issued to the SD card. you would need a PC with a DVD drive and SD card reader to use it. you can find these DVDs on ebay for $18 which basically covers my costs only.
Nov 29, 2008 | Fine Digital FineDrive 400 GPS Receiver
Add Europe sd card to Garmin 660
No. When you plug in the SD card, the Nuvi will load the map from your SD card. Once you get to the main menu, select the wrench symbol, then the map symbol and then "map info". You should see both the US and Europe map. Make sure the Europe map is checked. You can uncheck the US map. This is how you switch between maps. The reason why you have to have the extra map on the SD card is because the Nuvi can only have one map on it's internal drive, one at a time.
However, backing up your US map is a good idea.
Good luck,
- Jim
Nov 21, 2008 | Garmin Nuvi 660 GPS Receiver
GPS Logo
500 people viewed this question
Top GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a GPS Expert? Answer questions, earn points and help others
