Question about Refrigerators
Leaking fridge ge
Our GE refridgerator is leaking liquid profusely under the bottom drawer, on the 'floor' of the fridge side (side by side). Do you know where it could be coming from? THANKS!!
1) Check to make sure nothing has spilled in it. I had a bag of peas split open once and they were blocking some area and causing an airflow problem. I would then get Ice build up then it would thaw and spill on the floor.
2) I'm sure you have done thisw but make sure a water line does not have a split or pin hole.
Posted on Nov 17, 2008
Ge monogram refridgerator water on floor
Is the water filter located behind the grille under the doors?. I had the same problem and found the O ring on the filter cartridge was leaking.
Dec 17, 2015 | GE Refrigerators
GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
First Choice Appliance
Apr 19, 2010 | GE Profile TPX24PBDCC Side by Side...
Model # TBX18TRBR large puddling leak on floor, think has to do with defroster messing up?? A GE refrigator serial # HG539639
I've got the same fridge with the same problem (believe it or not it was manufactured in 1992 so it's a wonder it's still working).
I also have been able to narrow the problem down to a defrost issue. It appears as the coils are defrosted, the leaking water drains down through the inside of the fridge, pools in the bottom of the fridge (under the bottom drawers), then when that area is full it runs out onto the floor.
I'm still troubleshooting and will post back here within a week with my results.
Aug 22, 2009 | GE Refrigerators
Leak from bottom of fridge
Two things might be happening. One is the line to the fridge is leaking, this line come thru the floor or wall to the bottom and hooks up to a water valve, it may just need tightening. The other problem is you will have a hose that runs from the filter down in behind the crisper drawers to the bottom and coils up here to hold water for cold use. it then runs thru the bottom pan out to the front, to the bottom door hinge on the freezer side up the door to the dispencer. Check along the hose for a pin hole look at the bottom hinge area first, things bump into it here and can damage the plastic cover.
Jul 05, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
10 yr old GE side by side: freezer is leaking
Your drain is frozen up and so every time unit goes into defrost the water refreezes in the freezer's bottom. You either have to shut fridge off completely and let it dethaw or use hot water and an ice pick to hurry up the process. The drain is located in the very back of freezer. You will have to pull out the bottom drawer to see it. Good luck
Jun 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Refridgerator leaking
it is possibe the inlet to the drain line may be plugged.The defrost water cannot run down the drain line to the pan on on the bottom.Also make sure it is level
Apr 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge profile water/ice fridge side under bottom drawer
take out the back panel in frzzer side use a steamer to clean out your drain hole
Mar 15, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Iced up pipe in back of ge side by side refridgerator
Hi there, yes this will happen when the fridge has been over charged with refrigerant. :) If fridge under warranty get them to come and have a look :)
Sep 07, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
88 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
