Question about Refrigerators
Kitchenaid KSRS251 The spring that holds the "flapper " door over the icemaker dispenser hole came off....I've got the spring but can't figure out where or how it goes back on
  • 876 Answers
Mine goes goes inside the little box on the end where the arm comes out. I am not sure it is something you can do yourself. However, mine is a different model of Kitchenaid.
Posted on Aug 18, 2008
    Master:
  • 623 Answers
Try this site
www.partselect.com/KitchenAid-Ice+Maker-Parts.htm
    Master:
  • 521 Answers
Can i know the perfect model number so as to help you accurately.you can also check out the following site for some additional help.
www.repairclinic.com
Posted on Aug 09, 2008
  • Refrigerators Master
  • 19,396 Answers
How to install spring on french door flapper/divider for Samsung RF266
On mine one end of the spring broke off in the hole on the door. It was on top of the hinge so it looked like a pivot pin. I found that this was the second hole for the spring. I pushed the end of the new spring up under the hinge and popped the broke piece of old spring out. Now I could see the 2 holes. You then need to put the spring into each hole. The hole on the flap also needs a white plastic sleeve if that is missing. that goes on the end of the spring and fits into the flap hole. Then the trick part is understanding how the spring works? If you put both ends of the spring in the holes and shut the flap, it now stays in position to close and be flipped open by the guide that swings it open to seal.
Good Luck.
Feb 03, 2014 | Samsung RF266ABRS Bottom Freezer...
I need to replace the detergent dispenser latch on
To replace the parts you have to buy a whole dispenser assemble for $100 to $200. To buy some time ... Get a heavy gage sewing needle - hold it with pliers and heat it red hot. Stick the hot end into the plastic door at the area where the plastic latch is (where it will line up with the far end of the latch mechanism). when it cools cut off most of the needle leaving one eight to one sixteenth (more or less) protruding. Use a drill and small bit to remove some plastic (or drill a small hole) on the spring latch mechanism. push the remaining part of the needle in or out to engage the hole in the latch.. this will hold awhile.
Jul 19, 2010 | KitchenAid 24 in. KUDP01DLBS Free-standing...
Icemaker makes Ice But doesn't dispense it.
Had same problem. Looked everywhere and found no solution i'm a not a repairman...they probably do not want to post so they can make 150 for a repair visit. At least try this first it may save you $$. Remove ice bucket from freezer. Remove 2 screws @ auger...remove cover and auger ....remove spring and large hex shaped shaft. heat the large shaft end with a torch and put it back in hot side toward motor until the motor end is not frozen. No torch you can use hot water...but that may freeze again.
This was happing because my flap to the ice was not closing all the way .
Manual for parts can be found here it shows ice maker parts on page 7.
Good Luck Kono
Aug 21, 2009 | KitchenAid KSCS25FKSS Side by Side...
Ice Dispenser "Flapper" is loose--How does it reattach?
the plastic arms that move the flapper door open and closed are broken. I had this happen to me some months back. You will need to buy a repair kit from your local dealer. Explain what is broken and they can look up their part/kit number. You can't buy just the plastic door. Mine cost about $30 but was worth the price of getting my ice maker dispenser operating again. Very minor mechanics required to open this portion of the mechanism. Mostly some removal of screws and a spring or two. Good luck.
Apr 14, 2009 | Jenn-Air 21.6 cu. ft. Side-By-Side...
Whirlpool icemaker
Your unit has infered sensors on the frezzer left and right walls. There is a diagnostic test sheet brown in color in your kick plate.All you have to do is open frezzer door look on the right sensor it should blink twice followed by a 1-2 sec delay,if that is good press in flapper door on right sensor do not block path of infered beam you will not see a beam its invisable.Once you hold in flapper on right sensor the led should be solid.If solid optics are good if not solid led replace optic sensors
Jan 25, 2009 | Whirlpool ED5SHAXM Side by Side...
Icing and frost clogs the ice dispenser
check the dispensing flapper ,, it may not be shuting there is a spring and lever it the lever is bend or if the spring is broken it will not close correctly clean and clear all the ice .. then check that it will close after you open it...hope it helps
Sep 07, 2008 | KitchenAid Superba KSCS23IN Side by Side...
No water dispensing to the icemaker. Water does dispense through the door dispenser. KitchenAid ksbs25fkbl00
Unplug your refrigerator and leave the freezer door open for 2 hours (The food in the freezer will only partially thaw).
The line supplying the water to the ice maker has frozen...this will un-thaw it.
Oct 18, 2007 | KitchenAid Superba 21.6 cu. ft. Top...
Icemaker problems
Woody, This is one of the easier dispenser assy. to fix. The flapper is pretty simple, it clips on to the hinge assy. The hinge assy. has a spring that closes the flapper. There is a selenoid that pulls the flapper open. You can look up the parts on the net to see what they would cost. Flapper-12562701, hinge assy. 67004119, solenoid-12575401,spring 12565502. I don't know if you need all of them, Im not there to see. But if you have some time on your hands you could save a lot of money doing it yourself. Once fixed, you should be good for a long time. Catriver.
Jul 24, 2007 | Jenn-Air JCD2295HES Side by Side...
Ge gss25jemc ice in door keeps freezzing up
Flapper door diagram is here, you can see how the spring, etc. work to hold the door closed. http://www.partselect.com/Schematics/GE/00113173i04.gif As for the crushed ice, (item 384) on the next diagram shows the little lever that lifts the side rod on the bin (item 329) to decide if cubes or crushed comes out. The solenoid (item 383) can get frozen up and not move. Take a look where screw (item 371) is, that little square window is where the device that lifts the rod is. Take a hair dryer and heat that area REAL good to melt the frozen solenoid mechanism. Test it every now and then by holding the door light switch off and pressing the cubed selection & lever. You should hear a very loud "clank" as the solenoid pull in to lift the rod on the bin.
Jan 11, 2007 | GE GSS25JEMCC Side by Side
Refrigerators Logo
109 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
