Question about Whirlpool SF367 Gas Kitchen Range
Whirlpool built in double electric oven
I used the self clean option on my built in and now it will not heat
  • tgirard1 Aug 12, 2008
    its electric thanks
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    You have this posted under "Gas Kitchen Range", but list it as an "Electric Oven". Is this gas or electric?
  • 5,911 Answers
Okay...a few more questions. Are both elements NOT working? That is, BROIL and BAKE features are now dead? If so, you may an Electronic Oven Control (EOC) board failure. This is the clock/timer for your range. All the oven features are typically controlled by the EOC.
If its just one element. More than likely the element has blown. You will need to unplug the range and remove the back panel in order to access the terminal lugs where the elements penetrate the back of the oven wall. There are a pair of terminals for each element. A resistance check across these terminals will vary, but should read something on the K ohm scale. If the continuity readings are infinite (open) replace the element. I have a link under my "Tips and Tricks" that explains how to do this, if needed.
Are you confused yet? If so, please post back and let me know.
Posted on Aug 12, 2008
No power on double oven after a storm
I have a RBD275PRS00 built in double oven. Had an electric
www.fixya.com/support/t8971528-rbd275prs00_built
Apr 16, 2011 - Had an electric storm the other night and ever since the oven won't -Whirlpool ... Question about Whirlpool RBD275PR Electric Double Oven ... For an oven to require parts after 2.5 yrs of service and 2 self cleanings tells me ... fiest press the on key see if the display comes if not the turn the power off for 5-8 ...
Whirlpool panel buzzing Ovens Questions & Answers - Fixya
www.fixya.com > Forum > Tags > panel buzzing > Ovens
Whirlpool ovens panel buzzing related questions and answers. ... the control panel on my Whirlpool electric double oven Model is RBD305PDS14? ... No power on control panel During self clean cycle the power to the panel went out. ... panel the instrument panel on an oven won't change time because of a storm problem.
Jan 01, 2016 | Whirlpool RBD275PR Electric Double Oven
Have Whirlpool self clean electric oven model # F368LXKQ. Am trying to self clean-get a F5E1 or FSE1 error code and it will not start to self clean/heat. Any idea what the problem is?
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Jan 19, 2011 | Whirlpool Ovens
My heating elements are not heating for bake, broil or clean. just finished a round of self cleaning and now oven doesn't heat.
The self clean or self destruct mode has burnt a wire, the relay, or the control...
A tech with an electrical meter will need to check through the wiring and see what burnt up...
heatman101
Dec 13, 2010 | Whirlpool RBS275PD Electric Single Oven
Oven turns on but creates no heat
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
May 06, 2010 | Whirlpool GMC305PRS Stainless Steel...
Whirlpool electric double oven #RBD305PDQ14 control panel blank
I suspect a poor connection at the wiring to the EOC is the cause of the failures.
Apr 21, 2017 | Whirlpool RBD305PD Electric Double Oven
Self cleaning oven won't start self clean mode
NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
Apr 27, 2009 | Whirlpool RBD305PD Electric Double Oven
Cleaning cycle stuck whirlpool rbd245pdb1
whirlpool self-cleaning electric built-in oven #RC8400XAB serial # XD1301008. Self-cleaning lever locked. How can I release it???????
Jun 10, 2008 | Ovens
Self Cleaning Cycle for Oven
I lost the instruction manual for my Whirlpool 30" Electric Built-In Double Oven and want to clean it. Can I get instructions for how to set the cycle for self-cleaning, etc.?
May 10, 2008 | Whirlpool GBD307PDS Electric Double Oven
Whirlpool SF367 Gas Kitchen Range Logo
215 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
