Question about Singer 7462 Mechanical Sewing Machine
I don't not have the Instructions on how the bobben should be threaded in the bottom of my sewing machine. I have tried everything that i can think of but it well not thread. If it dose come up it dose not feed oof the bobben . It is a Singer electronic sewing machine modle 4562. Please help.
The manual for this sewing machine (Model 4562) is available and may be downloaded at no cost from Singer.  The Link to that page is: http://www.singerco.com/accessories/manuals.html
Inserting a wound bobbin is found on page 15.
Posted on Sep 30, 2008
I have a janome 2049LX. Why doesn't my double needle pick up the bobben thread?
The length of the needle might be too short. Compare the length to your single needles.
Jan 11, 2015 | Janome 2049LX Mechanical Sewing Machine
Empisal dressmaker 270D - top thread wont catch bobbin thread
Thanks for the advise, but I've opened the magine and it looks like at the back of the bobben, the part that controls the bobben has missed or skipped a louver so that's why my magine does not grab the cotton. The bobben case is not rotating the way it suppose to.
Jun 04, 2014 | Sewing Machines
The bobben is put in right and threaded right but the sewing isnt going into the cloth
try a new needle
try cleaning under the needle plate and in the feed dog area
it's also possible that the sewing machine needs to be checked for a timing issue.
Sep 05, 2013 | Sewing Machines
Singer 7444 mechanical sewing machine needle will not pick up bobben thread
try changing the needle--flat side does to the back of the machine
also make sure the needle & thread are the correct ones for the project your sewing
Apr 02, 2012 | Singer 7444 Mechanical Sewing Machine
The lower side of thread is looping
Could be your bobben tension need reset.Try that and let me know if it helps.Good Luck.Don't give up!!!
Nov 27, 2011 | Singer 3116 Simple
I have an old Singer sewing machine. Probably dates around the 1950's. The machine is in a cabinet and you have to tilt it to put it away. The bobben is underneath and you have to tilt the machine to...
I tried looking up your machine by google, and what I think is yours is a Singer 319w. If, I am right, you can get a manual for it at www.sewingmanuals.com and download one for $10. They show a picture of it, and if it matches you will be in luck. If, that is not your machine, call Singer at 1-800-4singer and you can get a manual for it from them, usually $15. plus s/h. You can get parts for it at www.sewingpartsonline.com also. Good luck & have fun
Dec 27, 2010 | Singer Sewing Machines
How do you thread the bottom bobbin?
Depends, it is a top load bobbon or does the bobbon go below the needle shaft. ???
Just remember that when you place the bobbon into the shuttle the tread always has to pull clockwise. So if you are holding the bobbon facing you the thread comes from the top to the right.
Lay the bobben into the shuttle making sure you pull the threads in a clock wise motion until you pull it under a metal point that looks like a flattened needle. This is also your bobben tension and then take your hand and turn the clutch wheel slowly. You will see the thread loop around the bobben thread and pull it up.
Dec 20, 2010 | Singer Sewing Machines
I can not get the bobben to thread right and when I sew it knots up on the bottom side of the stitech
the knots on the bottom are caused by the top thread not being in the tension disc or something in the discs( thread , fuss etc)
Oct 24, 2009 | Sewing Machines
Thread and bobben pattern for juki ddl 5550 machine keeps cutting bobben thread
Your bobbin case may be too tight. Try loosing it by turning the small screw a little turn to the left. If thats not it, you could also have a bend or snag in the bobbin case that is snapping the thread. If this is the case you will need to replace it.
Jun 21, 2009 | Juki Sewing Machines
Brothers pe150 embroidery machine will not sew
If you tighten up your needle thread, reduce the tension of the needle thread.
For embroidery, and zig-zag, and because the needle makes side movements, it needs more needle thread.
So try to keep you needle thread not very tight,
and tight up your bobbin case tension more, so that the two threads meet under the meterial.
Mar 30, 2008 | Brother PE-150V Computerized Sewing...
Singer 7462 Mechanical Sewing Machine Logo
792 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
