Copying dvd to vhs
How do I do this?
    Brigadier General:
  • 3,614 Answers
  1. Locate the output jacks DVD player. Sometimes they are standard female RCA A/V jacks, like those found on the front of many VCRs. Others are more tricky, having a small jack that looks like a stereo headphones plug. These camcorders require a special cord that converts a 1/8" stereo signal into RCA A/V male plugs.
  2. Using the proper cord, connect your PLAYER to the VCR's RCA A/V input jacks, usually found on the front or back of your VCR.
  3. Turn on your VCR and TV, so you can see the input from the camcorder. You might have to select "Input 1/2", "Line 1/2", or "VIDEO" depending on your VCR model. You should now see whatever is on your camcorder displayed on your television.
  4. Press "Record" on your VCR, then press "Play" on your camcorder. That's it!
Posted on Aug 09, 2008
SOURCE: vhs to dvd
Place a piece of wide scotch tape over the square hole on the left side tightly. Best to wrap it under also so it is tight from all sides over the hole.
Posted on Apr 11, 2008
  • 1463 Answers
SOURCE: Copy VHS whith copy protection to DVD
hello jordannoanno
this is true the macrovision will stop you copying the copy right tape /dvd .
this can be over come by removing the macrovision >
if you email me i will tell you how to go about this .
Posted on Apr 22, 2008
  • 5326 Answers
SOURCE: I have a Samsung DVD-VR357. I get no color on VHS.
Are you trying to copy a comercial VHS tape to DVD?
If you are then macrovision copy protection system on either the tape or in the machine is the reason for the loss of colour.
There's not a lot you can do about it. If you want to copy commercial material you will need to transfer it to a computer and get a program to do it. But unless it's unavailable it is cheaper to buy the DVD version I have found and you will get better picture and sound too!
If it does it with a none comercial tape (ie something recorded of the TV). Then it could be a head fault or something else. In which case try cleaning all the heads guides etc first.
Posted on Jun 20, 2009
1. Set up with a new blank DVD.
2. Insert VHS and adjust to the beginning of
your recording.
3. Use the DUBBING button on your remote: you can adjust video quality (2 hours or 4 hours play) at this point.
4. RTFM for use of the PAUSE and DUBBING buttons to skip over commercials etc.
Posted on May 10, 2010
SOURCE: Want to copy vhs to dvd
After i recorded a karaoke dvd . can't mute the singer's voice on that disc so i can sing .Any idea why ?
note : the disc used to record was not the original
Posted on Jun 06, 2011
There are machines made just for that task such as the Magnavox DVD recorder. There is a VHS tape deck on one side and a DVD recorder on the other side. You can copy a VHS tape to a DVD and copy a DVD onto a VHS tape as well
Jan 21, 2017 | Televison & Video
How to record dvd from vhs
There are some units that can do this, but if you are trying to copy commercially recorded VHS movies to DVD you will have issues. The VHS tapes have copy protection on them and all manufactured hardware to record these have been required by law to support the protection. Thus, you will get poor copy reproduction when copying. If they are home-movie style VHS tapes, no such issues exist. You can either get a unit that has both devices integrated and has copy capability, or you can you a VHS player and send the outputs to a DVD recorder.
Jul 09, 2016 | Televison & Video
I have a grundig gr1000(b) vhs/DVD combo. Is it possible to record from video cassette onto DVD? It doesn't seem to be mentioned in the instruction manual. Thanks for your help.
Yes! You can select to copy from VHS to DVD or DVD to VHS, set the VHS tape ready to play and press pause, then put a blank recordable DVD disk in and then select copy, the options for VHS to DVD or DVD to VHS can be selected and then it will copy, when the tape gets to the end it will turn off itself, if you want to stop earlier you will have to stop it! Hope this helps.
Nov 02, 2014 | Televison & Video
Daewoo DVD-T "copy not possible - this media cannot be copied" when trying to copy from VHS (tape is not copy protected) to blank DVD-R and +R media. Same problem with all DVDs and VHS tapes
You can only copy non-commercial VHS tapes that you have recorded yourself to DVD. You can\'t make copies of most commercially made VHS movies due to copy-protection.
Dec 29, 2013 | Daewoo DV-6T955B DVD Player/VCR
I cannot copy commercially recorded VHS tapes to DVD. Msg comes up saying it is COPY PROTECTED. Heard that if for personal use only I am permitted to copy tapes. Any way around this?
No,this can be done only copyright materials through the VHS box converter run through a computer with a programs call copy decoders programs.Than u can copy VHS copy protected matrials.Than u reburn it back to DVD disc.So this require alot of work,time and money so not worth it to copy commercially VHS tapes to DVD Disc.
Jan 19, 2011 | Samsung DVD-VR320 DVD Recorder/VCR
Copy Protected VHS
Yes. Generally protected VHS tapes can be copied to DVD.
Feb 08, 2009 | Philips Magnavox DVD/VCR Dual Player
Cannot do this on a combo unit. There is a chip that senses copy protection and prevents recording a copy-protected DVD to a VHS and vice-versa. Solution: Use an outboard DVD player or an outboard VHS VCR and try the recording with the video routed through a "stabilizer" box. The stabilizer (about $30 or less on Ebay) defeats the copy protection on MOST DVDs, but not all. It works with Netflix DVDs. Route the audio as usual. Audio is not protected.
Dec 15, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox zv420mw8
Are you trying to copy a DVD to DVD. Because I think if you are then it won't work. It might copy it to VHS VIDEO. But that wouldn't be worth it as you would lose quality. Try finding DVD CLONE for your PC.( It might be a free download) Look for it on the net. It will copy dvd to dvd and it's less complicated. I hope this helps.
Jul 28, 2008 | Philips Magnavox DVD/VCR Dual Player
I just bought at Best Buy the Samsung DVD Recorder & VCR. You can copy your VHS tapes right to DVD and or hook up an external source into the deck and copy them to DVD.  I find it working well but many of my tapes have tracking issues which is becoming a hurdle for myself.
Apr 22, 2008 | Samsung DVD-V4600 DVD Player/VCR
Recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Jan 20, 2008 | Televison & Video
Televison & Video Logo
120 people viewed this question
Top Televison & Video Experts
