For the last 5 days i cant sing into my accout i try everthing fixing the internet reseting the ps3 but it still wont let me sing into it so if you could help me i would really like to play
check your connections in your ps3 once again......................check whether disk inserted correctly or not...................clean your ps3 lens properly....................if the problem persists,,,you can easily fix this by your own without having much technical knowledge using repair guide available on net......................
thank you........
all the best....................
click here to download
If you dont have it, try to sing up for a gmail or google account from other computer, and when you have it your mail accout, you must type it at Xperia........
If not, you must go to a dealer shop, to fix that problem.
Okay, i'll see if i know what we're talking about here. There are a couple of things you could try. For one, try logging into your router, (usually at 192.168.0.1 and looking in the Client or Address lists for a PS3, or whatever you have named it, and then see if you can either disconnect or renew it. Then, redo the whole WiFi setup on the PS3 setting all the settings as you would but leave the IP settings as they are (should be Auto). If that still doesn't work, go into the PS3's connection settings and manually set an IP address. My suggestion is to use the same address as an already connected (and working computer), but change the last number. Whatever you do, make sure there are not two of the same IP address on the router. Hope this helps...
its sounds like a possiable corupted firmware update. have you tried resetting the ps3 to factory default....then try reinstalling the firmware, i myself have not had any of these issues. to reset back the ps3 go to settings and find the tab to reset the ps3.....BE AWARE YOU WILL POSSIABLY LOOSE ANY SAVED DOWNLOADS ETC...MUSIC....PHOTOS....MEDIA ....AND WILL HAVE TO REDOWNLOAD EVERTHING FROM PS3 HOME STORE
Try to do a reset off all the settings to the default.
Re enter your network information and try again.
As far as reading games, most likely is the bluray diode that went out.
If it's still under warranty send it to Sony.
I look all over the net but could't find anything, until i found a site that said they could show me how to fix any problem with my ps3. At first i was not so sure about ordering the manual but i did, whats $5 plus i used paypal, but long story short i fix my ps3, i recomend this site www.gameme.20fr.com i hope this help you like it help me.
