Question about Astec SA302-3515 (6500165) 300-Watt Power Supply
Sick computer My PC turns off by its self in the middle of my work.It also turns on and off some times.Some one told me it was the power supplys that was causeing it.Can you help.
  • 781 Answers
Check all fans On M/board to see if they are working also that your heat sink on CPU is clean no fluff or dirt clogging vanes this could be an overheating problem
Another quick check is to remove side of case if it stays on longer it definitely is overheating
Posted on Aug 10, 2008
I just turned its self off and the power botton is orange bit it wont turn back on
disconnect power supply take out battery. now plug back JUST THE POWER SUPPLY. turn on. most of time this works but if it still does it let someone here know.
Jun 07, 2015 | Computers & Internet
My Desktop E-machine EL1331G-01w turned itsself off during an update and now it will not come back on, it powers on then goes back off after a matter 2-5 seconds. What causes this?
Have someone check the cooling fan for CPU and power supply. If the unit have a blown cooling fan on the CPU it will do as you described. Will also do the same if power supply is no good. Boot into safe mode and see if it still shuts down.
Jun 27, 2014 | eMachines EL1331G-01w -22344
I have a IBM net vista and the power button does not work
That IBM Netvista should have a model number on the back.
This tells me if the computer is so old it uses an AT power supply, or an ATX power supply; as modern computers do.
http://www.playtool.com/pages/psuconnectors/connectors.html#oldpc
The old AT form factor of Power Supply, used the above type of main power cables.
The Power On switch was usually connected to the Power Supply.
A separate cable went from the front of the computer, connected to a Power On button, to the Power On switch on the Power Supply.
Or a separate Power On switch was mounted to the Power Supply, and a metal rod pushed against it.
The metal rod pushed by a plastic Power On button, in the front of the computer.
The ATX form factor design uses a Soft Power On circuit.
When a Power Supply is plugged into power, there is a constant 5 Volts present.
The 5 Volt Standby Power.
The ATX power on switch is a Momentary Contact Switch.
Pressing it closes the Soft Power On circuit -> Temporarily.
The 5 Volt Standby power is re-routed, and 'excites' the Power Supply, which turns it on.
THIS type of ATX power on switch is common.
It is inside the plastic Power On button assembly,
http://www.directron.com/atxswitch.html
Regards,
joecoolvette
http://en.wikipedia.org/wiki/Computer_power_supply
http://en.wikipedia.org/wiki/Switched-mode_power_supply
http://www.hardwaresecrets.com/article/181
Apr 07, 2013 | IBM Computers & Internet
Pc turns it self on by it's self
Make sure the power button isn't sticking at all. If it is sticking then use some glass cleaner on a cotton swab and clean around the button.
Try plugging the computer directly into a wall outlet instead of a surge protector or power strip to rule out a faulty product.
If the same thing keeps happening then you'll need to replace the power supply.
Jan 12, 2012 | E-Machines eMachines Desktop PC
Replaced dead power supply computer still dead
hi
most power supplys are protected against faults when they are connected to damaged equipment
so it possibly just protecting its self
disconnect everything from the PSU except your MB
try to turn on
if your pc boots ok
re connect everythng else one thing at a time attempting to boot each time
when it wont boot you have found your fault
Feb 07, 2009 | E-Machines D2046 PC Desktop
Ran self clean on my oven and it stopped in middle of cleaning cycle
That most likely means there is a fault in the control board. You need to contact the manufacturer or retailer for service.
May 17, 2017 | Whirlpool GBS277PDS Electric Single Oven
Error code 6502 on MP510
why error 6502..........?????
Help me pls.........!!!!!!!!!!!
Feb 26, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Power to Computer
No power or computer does not turn on. Additional information to why you may be recieving now power from the computer and/or why the computer is not turnning on.
Computer Power Supply Information Helping you with questions you may have about computer power supplies.
Computer Post / Beep codes The computer POST (Power On Self Test) tests the computer, insuring that it meets the necessary system requirements and that all hardware is working .
Installing a pc computer power supply Additional help and information about installing a computer power supply.
Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | HP Compaq nc6320 Notebook
Left side don't play/ right side is perfect
You sound like you have a wire connection problem but to find out try using a spare pair of speakers or try headphones. Try to rule out any wierd system problem, but I don't think that is your problem. Since this problem went away and then came back reduces the likely hood that it is a power issue so I would go with wiring issues or connection problems. While you are playing music. Move the cable, bend it, and reinsert it a few times. Give the cable a work out. If it comes back while this is happening, you have an open connection. You will need to replace the speaker wiring.
Sep 08, 2007 | Harman Kardon SoundSticks II Computer...
Dell GX260
can you be more specific when describing the computer 'struggling to restart'? Does it beep? Does it take several attempts to restart?
Aug 09, 2006 | Dell OptiPlex GX260 PC Desktop
Astec SA302-3515 (6500165) 300-Watt Power Supply Logo
66 people viewed this question
Top Astec Computers & Internet Experts
David Payne
David Payne
Are you an Astec Computer and Internet Expert? Answer questions, earn points and help others
