Question about Epson Stylus 880 InkJet Color Printer
Epson 880 not printing in color
I did all the print checks, nozzle checks, etc. Changed the color cartridge, did a color test print using block objects to print black, pink, turquoise and yellow. Only black prints. How do I check to see if the driver is selected to print black only or for color? Is that the gray scale option? I have tried everything. Help!
    Guru:
  • 859 Answers
Was gone for the weekend.
Yes, the grayscale option gives you black and white or black tank printing only.
If you go to start menu, control panel, printers, right click your printer there is the option to print test page. In the upper left should be the windows logo in color. If you don't have that and you know you've removed the protective tape for the bottom of the color cartridges and when doing the nozzle checks "you have color?", then you probably need to reinstall your printer driver.
Is your printer connected via a USB cable, a thin cable with a flat connector at the PC and a square connector at the printer. Then, let me know. Send me your printer model from the back of the printer model sticker and I'll send you the instructions and a link to the current driver as well as a program link to download a system registry clean up utility that's free to use and can clean up from an uninstall of your printer.
Regards,
Worldvet
Posted on Aug 11, 2008
  • Glenn Rogers
    Glenn Rogers Aug 18, 2008
    Do you need additional help with this problem?
    Worldvet
  • Glenn Rogers
    Glenn Rogers Sep 02, 2008
    You may need the specific ink solvent used by Epson. You can purchase it from the web page below and runs $10
    http://www.fixyourownprinter.com/kits/ep...
    Regards,
    Worldvet
  • 73 Answers
Found the answer. For some reason, my computer accepted a Mac driver. It called the printer Epson Stylus COLOR 880 (M). I went back to the original installation disk; thereafter, I had two printers, one without M, one with M, and deleted the M printer. All is working fine now.
Posted on Sep 03, 2008
Replaced both color and black cartridges. Prints only color when I try to print a flyer with both text and picture.
The black print head nozzles maybe blocked.
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
Sep 25, 2012 | Epson Stylus CX3200 All-In-One InkJet...
I have been using an epson stylus color 880 for years. One day it would not print. Replaced the cartridges and still will not print. It goes through the printing procedures but nothing shows up on...
The print head nozzles may be clogged. From the Utility section found in the EPSON printer driver, clean the print heads by performing a head cleaning followed by printing a nozzle check pattern. A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Perform up to 3 cycles if necessary. If the nozzle check is not printing completely, and if the head cleanings do not help the nozzle check pattern to print completely, try replacing the ink cartridge. Any ink cartridge installed into the printer must have a blue label on top of it. If the blue label has been removed from the ink cartridge, do not install the cartridge. Using an ink cartridge, which does not have the blue label on it, may damage the printer. Caution: If you have already installed a cartridge which is missing the blue label, or if a previously installed ink cartridge was missing its blue label at the time it was installed, and now head cleanings do not help the nozzle check pattern to print completely, your printer may require service and you should contact the EPSON Connection for further assistance.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jul 08, 2011 | Epson Stylus 880 InkJet Color Printer
Hi, when printing the page is full black. After head clean, nozzle check etc still black & nozzle check prints two x dark lines. I changed ink cartridges but no improvement. Thanks, Roger
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Feb 06, 2010 | Epson Stylus Photo 1290 InkJet Printer
My Epson color printer 880, prints erratic and very small print in a light black and sometimes blue color
Did you use Epson Genuine Cartridges? Brother Genuine Cartirdges????
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE
BE BETTER IF YOU DISABLE THE INK MONITOR.
Dec 17, 2009 | Epson Stylus 880 InkJet Color Printer
Despite print head and nozzle cleaning, and a new epson color cartridge my Epson Stylus color 880 wont print in color. I've ran the software utility for head and nozzle cleaning as well as using the...
In desperation tried another new cartridge and it worked perfectly first time: I suspect the first was faulty so off to retailer for refund ASAP. At 30+GBP they dont come cheap!
Oct 22, 2009 | Epson Stylus 880 InkJet Color Printer
Can not get rid of gaps with repeated Nozzle head cleaning
first of all, the nozzle check just tells you if there is a clogged nozzle, which you already know. you have to use the head cleaning feature on the same screen right below nozzle check. run that about 2 to 5 times and it should be cleared up!
Dec 09, 2008 | Epson Stylus 880 InkJet Color Printer
Epson stylus color 880
This is a very late response to your query, but you did have it in the C46 section. It sounds like you have blocked heads but there could be other reasons such as a faulty print head or main board. If you still require help with this problem, please post a new comment to this effect.
Nov 18, 2008 | Epson Stylus C46 InkJet Printer
Aug 09, 2008 | Epson Stylus 880 InkJet Color Printer
Color light will not go out
remove the cartridge close the printer, then again turn on printer and put the cartridge back effectively..
Jun 18, 2008 | Epson Stylus 880 InkJet Color Printer
Printer refuses to print black
Hi, I have question?
The ink that yuo are change are original epson cartidge ink?If yes , try to head cleaning twice and then nozzle check ,then the result of test print are soild in color are good , the unclean head having plenty spaces within the color in test print.
Jan 07, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus 880 InkJet Color Printer Logo
174 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
