Question about Refrigerators
Refrigerator Repair...Kitchenaid KSRS251
Spring that holds "flap" door to icemaker in place, came off.....can't figure out where it attaches and how to get it back in place.....
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Kitchenaid KSRS251
If you post exact model number here you get exploded view. Alternatively give us model number.
Posted on Aug 09, 2008
The door flap on my KitchenAid French Door fridge isn't springing completely back into place, and it's catching on the other door.
Locate and adjust the spring responsible for getting that flap into proper place and all will be resolved.
Aug 30, 2015 | KitchenAid Refrigerators
Icemaker flap door doesn't shut completely resulting in in frost layers forming on and around ice bucket and water leaking into the drip tray and ice forming on freezer door near the freezer door.
I found 9 different model to your model number, but all the unit use the same dispenser components.
Below there is a picture of the dispenser, item number 4,5,6,7 and 8 all deal with the working parts.
4 - return spring 5 - pin 6 - dispenser door 7 - Door Mechanism Assy (this one has a heater, not really needed) 8 - Door Delay kidlmo_2.gif but in looking up history, I found a complete door kit that should solve the issue. They came out with a part 8201649 and this part contains all those item and a bracket that can fix the broken tabs that the pin sits in. That was more common.
Back a couple of years ago they stop telling customer that the repair was not possible when the bracket to the pin support (mount) would break.
I hope this helps..
Jul 15, 2011 | KitchenAid KSRG22FKSS Side by Side...
I have a KitchenAid KSRS251 side-by-side refridgerator that is clicking every couple of minutes and the you can hear an motor or something run for a few seconds. The freezer is defrosting and I think...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 18, 2011 | KitchenAid Superba KSRG25FK Side by Side...
Ice maker door frosts over - turning to ice. I have to chip it off - but it returns if icemaker is on
This sounds like you are saying the Ice Dispenser door is freezing over. If yes the door is sticking open and we need to either repair the solenoid plunger=> KSRD22FKST16 Dispenser Components The reason this happens is your refrigerator is drawing warm moist air through the=> 8201649 Dispenser Door Flap If you should need additional help you will need to contact me, because Whirlpool that owns Kitchenaid will not allow me to post their service manuals here.I do not mind helping you it is Whirlpool has made things very strict now since thay purchased Maytag.I will be here or Fixya, Thanks, Sea Breeze
Mar 13, 2011 | KitchenAid (KSRD22FKST) Side by Side...
Ice maker will not make ice. Red light blinks
I have a kitchenaid with the same problem. Red light blinks twice when open is normal. Hold the flap down and the red light will be on.= normal= optics are working. If the ice rakes rotate, module is probably fine. Check the simplest solutions first, defrost the freezer in case the icemaker water nozzel might be frozen. That solved my problem. I then increased my freezer temp by a couple of degrees and so far, no problems.
Good luck.
Jan 30, 2010 | KitchenAid Superba Architect KSCS25INSS...
Ice maker not getting water. Everything else seems to work fine. I can put water manually into the ice maker and get ice. But no water from the line. It is a KSRS251 superbra side by side Kitchenaid model.
You will have to remove the icemaker and look inside the water fill tube at the rear wall of the freezer.
The water line may be frozen closed.
If so,take a hair dryer and thaw it out.
This manual will explain other test to complete.
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
Nov 09, 2009 | KitchenAid KSRS25IL Side by Side...
Not making ice
Pour about 2/3 cup of water into icemaker . If it dumps , replace the water valve . If it doesn't , replace the icemaker . Your icemaker may have the white flap arm with a spring attached between the arm and bottom of the icemaker . Check that spring , to make sure both ends are seated . Ocassionally , the top of the spring (fitting into the bottom of the icemaker ) comes out , and has to be pushed back into the hole .
Sep 07, 2009 | GE GSS23SGSSS Stainless Steel Side by Side...
Kitchenaid Refer Icemake not working
The light is supposed to flash twice with a 1 second intermission. When the fridge door is closed the light stays ON. Check this by pushing the white flap to the right of the icemaker while the door is open
Dec 11, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
81 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
