Question about Maytag Refrigerators
I have MSD2656DE Refrigerator, 8 years old, cabinet style.. and I have frost problem IN FREEZER COMPARTMENT.. I have to tun off the refrigetrator per 3 weeks to defrost... Have you any clue?
  • 3361 Answers
SOURCE: Frost build-up causes cooling to stop
Sounds to me like a intermittent defrost timer not advancing.
It is located behind the plastic cover over the controls.
Remove the switch knobs, then remove the cover. The defrost timer access is on the right hand side. You can turn it with a flat blade screwdriver. Turn SLOWLY clockwise until the compressor kicks OFF. That is when the defrost heater is energized.
After a few minutes you may be able to hear a sizzling sound from the freezer. That would be defrost water hitting the defrost heater.
If it does the defrost at this point, replace the timer. about $30.00
Posted on Mar 28, 2009
  • 12 Answers
SOURCE: My whirlpool refrigerator (8 years old) is not cold and hums
Possible of 3 reasons.
1) Defrost bimetal is open and not allowing power to heater element in evaporator coil in freezer.
2) Defrost timer is not going into defrost, motor stopped moving.
3) Evaprator fan motor is not rotating. Possible motor.
First check for frost in the back panel of the freezer section.
if there is frost and the fan is operating, would suggest manually putting unit into defrost, depending on particular model. may be a switch you can move with a standard screw driver to get the fans and compressor to shut off. If you find this either. Top of fridge in refrigerator section below temperature selection controls. Or remove toe plate, the pretty decor under the door. and it will be in there.
If this is an electronic style, look under that toe kick and there is a technician's sheet that will explain how to get into defrost.
Allow 10 minutes for heater to heat, listen for water sizzling on heater element. if this does work. you will need the defrost timer.
Hope this helps.
Posted on May 14, 2009
  • 245 Answers
SOURCE: Freezer compartment ice build-up
too defrost just open the doors for a day with the unit unplugged. as far as why it is frosting up check door seals make sure they are all good and seal it up well and that should take care of it.
Posted on Jun 26, 2009
  • 34 Answers
SOURCE: refrigerator hot, freezer cold
Replace the defrost clock.
Posted on Sep 10, 2009
  • 8220 Answers
SOURCE: ge pss 26 ngpb-bb refrigerator,
I can't imagine what that noise could be. But I do have a service manual. This will help you diagnose the problem Their is a page which explains normal and abnormal noises associated with this refrigerator, automatic defrost, and a lot more.
Posted on Oct 10, 2010
Automatic defroster doesn't seem to be working. Frost continually builds up on the back of the freezer compartment. This is a 9 year old refrigerator. What to do?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Sep 13, 2010 | Amana ABB1927DE Bottom Freezer...
3 1/2 year old whirlpool side by side has frost and ice building up inside the freezer compartment close to the door. Freezer seems to run continuously
hi ,
your freezer cabinet need to get all out and open the back wall.
  1. you have 2 element that can be check one is the heating element , two is the thermostat.
  2. you need a volt meter to check them.
  3. if the frost is all over the coils then one of the element i told you before, is bad
  4. if the frost is in one area not all over then you got gas leak.
  5. good luck
Jan 03, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have an 8 year old Maytag side-by-side refrigerator that stopped cooling. The refrigerator side is not cool at all and the freezer side is marginally cool.
  5. good luck 911service today .com
Jan 03, 2010 | Refrigerators
Freezer building up with frost
Sounds like the defrosting system has a faulty timer/board, faulty heating element or bad electrical connections to these components.
More info, let me know...
Aug 23, 2009 | Amana 22.6 cu. ft. Side-By-Side...
hi..Sounds like one of the solenoids is acting up.Solenoids are
electromechanical devices that can be used to turn the water
to the ice maker on/off and also operate the door/screw that
dispenses ice.It could also be a fan or motor that is making
the noise.
check it out..
thank u..
kindly rate my response..
May 14, 2009 | Refrigerators
Sub zero 550 (14 years old) has a small but steady leak onto floor from freezer compartment. Small amount of frost buildup on inside of door. Food is frozen and the door "appears" to seal we
Right hand side wall in the freezer - take a look- any frozen water or moisture? Need check a drain line, usually defrost heater inside the freezer wall getting bad and draining water just freezing inside of it.
May 10, 2009 | Sub-Zero Bottom Freezer Refrigerator
Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Feb 21, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice in freezer compartment
I have seen this problem with the LG freezer unders. There is a air leak that is getting into the freezr allowing the moisture to frost up at the back of the freezer. It will form frost all over too. Since your unit is 8 month old call Lg and let them deal with the problem. At my last Lg training the problem is with the air damper in the fresh food section may not be closing fully. So Call for service.
Jul 12, 2007 | LG LRFD22850 Bottom Freezer Refrigerator...
Refrigerators Logo
206 people viewed this question
Top Maytag Refrigerators Experts
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
