Question about Bosch Washing Machines
How do I replace my boot gasket on my Bosch Nexxt washer?
  • Anonymous Aug 17, 2008
    same problem, second time having to replace it. Order parts from Bosch. This washer has issues.
  • Anonymous May 01, 2009
    Same problem. The Bosch man came to help me fix the dishwasher and I showed him how I had to use a ribbon to pull the wire ring tight around the gasket/boot. He had a devil of a time getting it back on. He kept working it around until it popped in place. That was about a year ago. Now it has come loose again and needs replaced anyway because it is moldy and pieces are breaking off. Everything about the performance of the washer is fine.
    Novelist:
  • 130 Answers
Here is how you do it. 1st remove the door & hinge, 2nd remove the covers on the screw where the door sits that holds down the control panel. 3rd remove two screws holding the door latch in place. Remove the spring & wire holding the boot on and pull the boot loose from the plastic holder Remove the plastic boot holder. You will now see the boot where it attaches to the tub. There is a spring and wire that holds that on. At the top there is a tab on the seal, grab it and pull towards you. The boot will come off. To reassemble I remove the counter weights(concrete weights) from the tub and put the boot firmly into the slot on the tub. Now reinstall the rear spring. Be sure to also reinstall the counter weights if removed and torque them tight around 25 to 30 foot pounds. Reassemble the front panel and put the spring retainer back on. Tools needed T20 torx driver, 13mm wrench, and needle nose plyers.
Posted on Aug 10, 2008
  • Bosch Master
  • 744 Answers
Bosch Series Front Load Washer how to replace door seal.
This video will show you how to change a door seal on this Bosch front loader washing machine.
we have all bosch repairs in our channel.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Aug 05, 2013
Followed these instructions took about an hour all you need is patients,thanks for the info!.saved me a service call
Posted on Feb 07, 2012
5 Suggested Answers
farr64
  • 121 Answers
SOURCE: bosch nexxt washer fabric softener not draining
is there a drain on the bottom left corner if so drain the contents its usually under a small panel
Posted on Sep 14, 2009
SOURCE: Replacing boot on Bosch Nexxt Front loader
are you talking about the thin wire closet to you... if you are, you'll find a small bend in the wire where you can pull it out. It is right next to a spring on the wire.
Posted on Sep 07, 2008
rickead1
  • 1998 Answers
SOURCE: noisy pump in bosch nexxt 500 washer
no its usually not that loud at all contact bosh direct to have them send you a new one or call them if its still warrantied
Posted on May 01, 2010
caroldon
  • 17130 Answers
SOURCE: how do i replace the
The gasket is needing a change becasue it is worned out. So I guess that you have got the same model gasket to be replaced.
the gasket has to go into the slot to fall into place and make the sealing water tight.
So remove off the fittings and remove the gasket out of the slot.Now replace inthe same format , push the head of gasket into the slot using good pressure and then do the fitting of the gasket to seal into place. close door and cconfirm the fitting.
Switch on and see for any leak before your first wash.
Posted on Aug 28, 2010
Replacing a gasket on a bosch nexxt washer
For parts look in Fixya. For changing go to YouTube, great videos to show you how.
Click helped, if helped.
Mar 14, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
Is there a replacement part for the rubber gasket for door of washer? I can't stand the mold.
you can get parts from ebay
Jan 03, 2011 | Bosch Nexxt Premium WFMC6400UC Front Load...
How do I replace the boot on my bosch WFMC6600UC washer? It has a tear and is leaking.
Very hard to replace boot, entire machine has to come apart. 2nd it takes experience to replace a boot, 3rd the boot will cost 150.00 to 250.00.
have a tech do it
Dec 19, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
The ring that holds the gasket in place fell out. How do I replace it?
Your gonna have to wet the boot(gasket) with just water and position the ring on the top of the boot and stretch it around the entire boot and make sure it secure.
Aug 18, 2010 | Bosch WFMC2100UC Nexxt Essence Washer
My Nexxt Washer has a black residue on the front gasket.
The black is not algae it is mold. The only way to fix it is to replace the gasket/seal.
Feb 21, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Gasget came off the washer and i can't get it back on
I have the perfect solution the placing of the Retaining Spring back on the Bosch Nexxt 500 Door Gasket. It only took me only 5 Minutes after fighting with it for hours and getting nowhere. What I did was purchase a set of 12 inch hemostats (long Clamping Pliers). The ends of the Hemostats I wrapped both of the jaws with Electrical tape to prevent the Spring on the retainer from sliding up the jaws of the hemostat. When the ends of the retainer are placed on the ends of the jaws and the hemostat opened the spring is stretched. I found that If you use your knee to hold the hemostat open while placing the retainer in the groove of the gasket you can slowly release the springs and set the retainer back into the gasket without the gasket pulling off the tabs.
Mar 01, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Washing Machines Logo
694 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
