Question about Toshiba 50HPX95 50 in. Plasma HDTV
Toshiba 50in plasma
I came home last night to see the power light on my toshiba 50hpx95, blinking....i have sound but no picture...i have done the hard reset and soft reset...the tv worked perfect the night before-all i did was turn it off lik ei always do and wnet to bed....
please help
    Genius:
  • 1,139 Answers
Hello brattbabie1,
Ok you have sound and no picture. This denotes that since this is a plasma TV the circuitry that controls the activation of the screen may have become defective. You will need the schematic to show the voltage levels that need to be present on the cable that connects between the screen and the control circuit and a voltmeter to measure those voltages. I would suggest that you get a qualified TV technician to work on this problem, due to the technical nature of this issue.
I hope this helps,
Thank you,
Shuttle83
Posted on Aug 10, 2008
Samsung Plasma PN59D8000FF no picture no sound
Generally if the power lamp is on but the set is dead its the power board, you could remove the back if your comfortable doing so and check the voltages going from the power board and see if any are missing or incorrect...good luck!
Nov 25, 2017 | Samsung Televison & Video
TV shuts down with Red Light blinking
it must be your tv was heated on long usage.
sir, try to go to your nearest expert technician. they have tools to use on fixing your tv's hardware. or see if your tv has a warranty to send it back to the place what youve bought it. hope that helps!
CHARCOIS
Aug 09, 2008 | Toshiba 50HPX95 50 in. Plasma HDTV
I have a Toshiba 50hpx95 plasma tv with a blinking red light. I have already replaced the power supply board and the problem is still there. I need help
I'm no TV expert, but I can share what little knowledge I have, specially what I went through with my plasma TV. It happen in mine, and I got the Y Board fix. When mine was blinking, there was no power, but it wasn't the power board, so searching for an answer in the internet, I found out that it could be one of the boards (Y board or Z board) In my case was the Y board, so I took it to a professional and he fix it for me. IF possible search for: How to troubleshoot TV Y Board.
Mar 02, 2015 | Toshiba 50HPX95 50 in. Plasma HDTV
My toshiba 50hpx95 has a steady blinking red light, it has no pauses or breaks to recite a code, just steady blinking. I had it in the shop and they said the power board needed replaced, so i replaced it...
This tv have a Tuner signal board it is also dead too,this problems happen sometimes,the power supply board dies,but sometimes the Tuner signal board take power surges from the power supply board itself than kiill the tv Tuner signal board too.Try website like Ebay.com to buy a refurbish tv Tuner signal board for the replacement.Fixed this problems,many times before.Blinking power LED light.First replaced the power supply board,than didn't solved the problems,than the tv Tuner signal board it is also dies too.
Mar 16, 2011 | Toshiba 50HPX95 50 in. Plasma HDTV
My toshiba 50hpx95 plasma tv makes just a clicking noise from the relays on the power supply but nothing else wont power on and no lights flashing
A common problem with modern power supplies is dryed out capacitors in the power supply, This pulls down the voltage and shuts down the tv. The can usually be spotted if you know what to look for (they swell up and deform a little). It is not a job for the novice. But capacitors are cheap.
Try a local tv shop for estimate
pete
Nov 08, 2010 | Toshiba 50HPX95 50 in. Plasma HDTV
Toshiba 50HP95
I would contact guy at
plasmatech@gmail.com
he has great expertise and all parts for Toshiba Plasma TVs
Jan 08, 2009 | Toshiba 50HPX95 50 in. Plasma HDTV
How to bypass seine card? 50hpx95
Turn off set, unplug power. Remove back cover. On brown circuit board left of center, unplug connector PJ63A. Plug in power, but don't electrocute yourself! If you no longer get the continuously blinking red light, hit the power button. If it comes on, the SEINE module is bad and must be replaced.
Dec 13, 2008 | Toshiba 50HPX95 50 in. Plasma HDTV
Red light flashing. TV wont start.
Bypass the SEINE module if you know how. If you use off air HD you will have to get a new module.
Sep 26, 2008 | Toshiba 50HPX95 50 in. Plasma HDTV
Power led blinks but no picture or sound
Had the same problem myself. Took some doing but I managed to find a service bulletin that I downloaded. The problem is with the siene module and all you need to do is unplug connector JP63A from the main board and your TV will work again.
Take the back off the TV (there are a lot of screws) and look on the left hand side of the main circuit board that is mounted in the center of the TV. You will see a small white connector that is labelled JP63A, simply unplug it. Plug the TV back in and let it reboot. That's it, should be able to watch immediately.
Aug 15, 2008 | Toshiba 50HPX95 50 in. Plasma HDTV
Toshiba 50 inch plasma
Hello BlufftonT,
This is an indication that there may be a problem in the power supply, possibly bad capacitors, and or defective active components. I would suggest first checking to see if there are any blown fuses, and or loose connections. Past this point I would advise that you either take the TV to a TV repair shop or have a TV technician troubleshoot the TV in home to determine the problem it is having.
I hope this helps,
Thank you,
Shuttle83
Apr 01, 2008 | Toshiba 50HPX95 50 in. Plasma HDTV
Toshiba 50HPX95 50 in. Plasma HDTV Logo
317 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
