Question about Bosch Axxis WFL 2060 Front Load Washer
Bosch axxis washer sits with door light flashing and spin/rinse light flashing
My washing machine is just sitting with the door locked light flashing and the spin/rinse light flashing. Any ideas?
  • 1462 Answers
SOURCE: Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Posted on Apr 25, 2007
RJTech
  • 32 Answers
SOURCE: Frigidaire Front Load Washer
You need to replace the Motor controller speed asm part number 134149220 they are about 165.00. very easy part to replace you have to remove the back panel and the control board is on the bottom left side two scews and two plugs.
Posted on Dec 18, 2007
SOURCE: Whirlpool Duet Sport Washer Does Not Work, Door Lock is stuck
have you checked the belt to see if it came off or maybe broke off,if its not the belt then maybe the motor whent bad or needs reset,that just some of the possibilitys you might want to check,some motors have a reset butten on thim
Posted on Mar 01, 2009
  • 67 Answers
SOURCE: Admiral Washer........Spin cycle not working.
BAD LID SWITCH
Posted on May 18, 2009
SOURCE: I have a Bosch washer, model number WFK 2401 that
I just had the same problem last week Aug 1 2009
on our WFK 2401 purchased in 2001
If you hear no motor spinning when it should then it's something
with the motor. If you hear motor spinning, esp spin cycle, but
the drum doesn't spin, then probably broken belt ($30 part).
Since I work on cars (this is very much like an alternator+belt) and wanted to avoid a $100 service call (just to come to house) and
at least try for a quick fix before buying a new washer, I opened the back, confirmed belt looked ok, so tried
replacing the brushes in the motor, and it worked.
For a good description on how to do this see
http://dossy.org/2007/05/lots-of-miles-on-our-bosch-wfk2401uc-washer-motor/
I took some pics, and time permitting will post more details
to this dossy site to help fellow owners.
I purchased the brushes at partstap.com for $50 (incl tax+ship)
Posted on Aug 06, 2009
Why does the lid lock light start flashing after the wash cycle and will not rinse or spin?
Lift lid, stick screwdriver into slot where lid latch-pin inserts and see if it goes into the cycle. If so, try adjusting position of latch.
Sep 01, 2014 | Washing Machines
Why won't my washer start a cycle? Start button LED just flashes. All other lights are steady. Door lock sounds like it engaged, but nothing happens.
There should be a way to enter the washing machine into service mode to view an error code. Check your user manual and then you should have your answer!
Jul 23, 2014 | Washing Machines
My whirpool washer does not spin in rinse cycle
pull out the plug first ???
have you cleaned the filter ,this is the first thing to do
next check the motor brushes
May 27, 2014 | Bosch Axxis WFL 2060 Front Load Washer
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
Does not empty at end of wash cycle (not blocked or pump)
faulty program board not progressing
call a technician
Jan 01, 2018 | Hotpoint WMA46 Front Load Washer
I have a 3-year old WFL 2090 Axxis Washing Machine. The door will latch initially, but unlatches during wash cycles and blinking lights come on. It was working fine until the machine was moved. ...
There is likely to be a problem with either the lid/door solenoid/lock or the 'lid/door closed' sensor becoming apparent with the extra movement of washing requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 15, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
573 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
