Question about Saeco Vienna De Luxe Espresso Machine
Doesn't stop This maschine works good but sometimes, when I switch on, display says no enough water but the tank is full.I checked the magnet what it goes up normally and aproximity switch as well but it works good from 1 inch distance.I dont understand it. Another problem is: When I want a small cofee I usually press the third button from left to make it but the quantitiy of coffe is large! as a matter of fact very large! So it doesn't stop ever. Pls help!
  • kohariatti Aug 10, 2008
    Thanks 4 ya help master but problem solved!
    Works good now.Doesn't note me about low water level(??)and coffee portion is also correct.Problem was:
    after descaling we need to setup correct portions by teaching funktion.When my problem has been written I downloaded the manual and it did help.
    Thanks again!
  • 515 Answers
I think you have to replace your power card.
Posted on Aug 09, 2008
Display fill water only but water full help
check small float in tank is not stuck in the down position
Dec 29, 2013 | Jura Capresso Impressa S90 Espresso...
Water is not registering displays says no water when tank is full. what can i do?
Check and see. If there is a float still in the water tank.. It's a magnet. Sometimes they stop floating then machine thinks there is no water..
Oct 19, 2013 | DeLonghi EAM3500 Espresso Machine/Coffee...
The water tank light continues to flash although full of water and magnet ok
What do you mean Magnet = OK.
It sits in the little bracket and should be at the top of that holder.
If you do not have the water tank all the way in.. The sensor can not see the magnet.
When you push the tank in you should feel a good clunk as the valve is seated. Check for any junk that is stopping the tank from going all the way in.
Sep 06, 2013 | Sunbeam Cafe EM6910
Display on Saeco Magic Comfort+ says "Fill Watertank" even when tank is full. Removing and resetting does not help.
Hi
This is usually a magnet in the water tank or sensor inside the machine. First do you have the grey magnet in the water tank? If no magnet in the tank, that is the problem. The magnet floats when the tank is full and sinks when its empty. It sends a flux signal to the sensor inside the machine. If the sensor is bad inside it doesn't pick up the flux field and you get the "water tank empty" display.
May 23, 2011 | Saeco Magic Comfort Plus Espresso Machine
We have a Solis Master 5000. The digital reader says the water tank is empty when it is full. We have owned the machine for about 4-5 years and we have descaled pretty regular and recently took apart and...
Hi
You need to check that the magnet in the water tank is floating when the water is half way up in the tank. If it is not floating or is missing, that is your problem. If it is floating you may have a bad sensor inside that reads the magnet or the magnet is bad..
May 14, 2011 | Solis Master 5000 Espresso Machine
Heayer doesn't work
The resistors provide resistance in the circuit, dropping voltage to the blower motor to slow the motor speed down. On high, the blower receives full voltage through the blower relay.
If you had High but no other speeds, then the resistor pack is usually the culprit. If you have all other speeds but high, the most common problem is going to be the blower motor itself, relay, or the switch panel.
You can check this by turning the fan speed to "high", unplug the blower motor, and check to see that you have roughly at least 12v at the plug. If you have 12v, that means the switch panel is activating the relay and the relay is working. Over time, heat kills the magnetic properties of the magnets inside an electrical motor. Without enough magnetic energy, you may not get enough opposing force to spin the rotor full speed when the windings energize, but still enough to spin at lower speeds.
Another thing you can check is the connector at the blower motor and the switch panel. Sometimes these will heat up, start to deform, and cause a bad connection. The bad connection may be able to handle the lower current draw on low speeds, but the higher resistance from the bad connection won't be able to handle the higher current while in the full speed position.
Hope this helps, keep me posted. be glad to help you get your heater working again soon.
Jan 07, 2010 | 1995 Chevrolet Tahoe
Flooding problem in a AWM8146
Sounds like pressure switch or feed hose to the switch blocked or faulty
Oct 01, 2009 | Washing Machines
Water gtank full telling me to fill water tank
Hi
Check an see if you have the magnet in your water tank. That is your signal to the computer that it is full if it is at the top of its chamber. If you don't have a magnet ( gray cylinder) in the water tank that is your problem. If it is on the bottom the magnet needs to be replaced.
Jun 12, 2009 | Saeco Magic Comfort Plus Espresso Machine
Krups XP9000 won't recognise water tank is full
I have just had the same problem with my Krups XP7240 and I discovered (quite by accident!) that it was the magnetic float inside the water tank which was causing it. I think the float must have let some water in and always stayed on the bottom even when the tank was full. As the float was in an enclosed plastic column it was a bit hard to access, but through sheer desperation I snapped a plastic fork in half and wedged the handle section under the float to keep it off the bottom and this works nicely. It is not professional by any means but I was quite pleased with my innovation :)
The only down side to this 'method' is that the opposite is now true and when the tank is empty it doesn't register so you would really have to keep an eye on the water level to avoid killing the element completely.
I would imagine that the only professional way to get this sorted out is to replace the tank (or float if it is accessible?). Good luck!!
Feb 04, 2009 | Krups Small Appliances Espresso Machine
Fill Watertank Message
The black thing floating in the water tank is a plastic shell with a magnet inside. If you clean it...make sure you reinstall it with the tapered (smaller) side down. There is a slight size difference BUT it will make ALL the difference in the world.
I had no idea there was a magnet in that black/greyish case. The direction of the casing is important.
I had the same problem and that solved it!
Jul 29, 2007 | Miele CVA615 Espresso Machine
Saeco Vienna De Luxe Espresso Machine Logo
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
