Question about LG 24 in. LDS 5811 Built-in Dishwasher
LD Dishwasher power problem
I turned on my LG built in LDS 5811WW dishwasher and it powered up. While pressing the settings to wash the power died and it won't come back to life. It was weird. I've checked all the outlet power sources so it is the dishwasher that is the problem. I've seen another post on this site suggesting to check the door switch. Is this suggesting the switch may be burned out? Would I need to remove the front panel of the dishwasher door to check the switch? I don't know where this is to check it. Can you help me please? Thanks!
  • msbarks Nov 28, 2008
    Same problem. It initially powered up but now there is no power at all.
  • 423 Answers
On the LDS5811 model, I doubt very much that the door switch would cause a full failure.
If you are confident the power is live into the dishwasher, the most common failure with this symptom is a failed controller card (PCB) and will require a service call to LG.
Posted on Mar 30, 2009
I NEED A USER MANUAL FOR A LG INTELLO DISHWASHER LD-2050SH
Simply click on the following link which will take you to the PDF downloadable users manual.
http://kitchen.manualsonline.com/ex/product/headline/m/lg/d/dishwasher/p/LD-2050SH
Oct 31, 2013 | LG 24 in. LDS 5811 Built-in Dishwasher
LDS 5811ww- permanent draining
Remove the front panel - In the crack where the top and front meet about 2 inches over from each edge there are clips you push in with a putty knife or flat blade screwdriver and the front releases at the top and un hooks from the bottom. Now put washer in the spin cycle. right in front at bottom is the motor and on top of the motor is a silver colored part ( the inverter) look in between the motor and the inverter on the right about 2 inches back - you should see a green light that is flashing ( it may help to darken the room) Tell me how many times it is flashing.
Jun 16, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
LG Dishwasher LDS 5811BB does not turn on when pressing the Power button.
1. confirm there is power up to the dishwasher.
2. open electrical connection box on right side, behind toe kick panel, and hold one wire nut connector at a time while giving each individual wire a firm tug. All wires should remain connected. If not, correct poor connection.
3. dissassemble door and check door switches.
4. if all previous steps check out, you should have a red LED lit on the control board inside the door. If power to board, but no LED on, replace board.
Jan 15, 2011 | LG 24 in. LDS 5811ST Stainless Steel...
My dishwasher is an LG LDS 5811WW it reports an IE reading after one minute. Any help?
check clogging of water inlet hose ( or hose twist or freezing)....check water supply
Oct 20, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
Lg dishwasher showing error code LE how do I fix it already checked for loose wires
Try - Disconnect the Power Supply. Wait for 30 Minutes. Again Turn ON the Dishwasher. Is that Fixed the Problem.
If not, i am afraid friend, you need to replace the Wash Motor.
LE usually Refers to Motor Locked Up. Replace Wash Motor.
I have seen many of the Dishwasher gone Bad within Few Months.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 31, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
LG Dishwasher LD-2050WH with HE error code
This is a heater error. The cause is either a bad heating element or bad thermistor (the thermistor is part of the heater assembly). The heater assembly will need to be replaced.
Jan 14, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Motor removal
I am having a same problem. You can open dishwasher sump assembly from inside the dishwasher and check if something is blocking white impeller. I tried to open impeller and sheared screw head as I did't realized it is left handed screw. Even after cleaning impeller you still get problem, you need to check from bottom and see if something is stuck there. If all right and you are still getting error then it is time to replace motor. In my case I ordered entire sump assembly as my seals were also wornout. Sump assy cost $113 on Sears part direct.
Dec 30, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
LG dishwasher LDS5811ST
The problem with the dishwasher acting haunted is probably the main controller card. If you don;t have an extended waranty, know that LG will cover the parts for free through 24 months but after 12 months, the labor will be charged.
Nov 01, 2008 | LG 24 in. LDS 5811ST Stainless Steel...
Problems with my dishwasher whirlpool gold GU75xtvyo
If you are certain that the power is being delivered into the dishwasher and it is new / under warranty, I recommend that you do not crack open the dishwasher to search for the problem. You might void said warranty.
Contact the service number inside the owners manual and press for on-site resolution.
Oct 26, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
LG 24 in. LDS 5811 Built-in Dishwasher Logo
471 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
