Computers & Internet Logo
Posted on Apr 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error: Permission denied for <http://fb-tc-1.farmville.com> (document.domain has not been set) to call method Location.toString on <http://apps.facebook.com> (document.domain=<http://facebook.com>).
Anonymous
Level 2:
Sergeant:
  • Expert 142 Answers
  • Posted on Apr 22, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
142
Questions
0
Helped
27036
Points
511
Reset all your security features like firewall and antivirus settings. Go to START > CONTROL PANEL > WINDOWS FIREWALL > RESTORE DEFAULTS. and make sure that you have an existing subscription with your antivirus software otherwise uninstall it and install a new one.
No space for new apps
· 1.Check if you really have sufficient storage free.
Ifstorage is free enough
then
· 2.Clear the app chache data with the clean master app or the included cleaning app forjunk data cleaning.
Can also bedone by using adb bridge (Search on the net you will surely get something onstackoverflow.com).
If thisdoes not solve your problem.
Then try this:
· 3. (This solved my problem)
Usuallythe default install location in android is set to automatic. If for any reasonif it is change to something else it can be problematic like you experienced.
Setting up ADB (required)
->get you phone connected to a pc over the USBcable provided (Make sure you have your proper driver installed [usually it'sinstalled])).
->Turn the "debugging mode on"through the settings (You can search over the internet it's easy)
->download the adb_inteface.rar tool andextract it somewhere.
->open command prompt. Change the currentdirectory to where you extracted the adb.exe and all files from the attachment.
->type
adb devices
if it returns with last line like this
List of devices attached
cfcd5eec device
This means you have successfully set up theinterface.
Running Commands
->check the default storage location bytyping on the command prompt:
adbshell pm get-install-location
If it results something like:
open: Permission denied
2[external]
Or
1[internal]
This means it may be a problem which forces the Android OS to save on specified location 1 for internalstorageand 2 forexternal storage.
You may fix this by running the following command:
adb shell pm set-install-location 0
here 0 means automatic storage depending on the storage space availability.
Meanwhile you may get messages like:
open:Permission denied
open: Permission deniedYou can ignore this.
this is probably because your phone is notrooted.
Hope this is useful.
Netflix error 405
http://forums.mozillazine.org/viewtopic.php?f=38&t=605984&p=3155060
http://www.checkupdown.com/status/E405.html
SYMPTOMS
When you browse the default document, you receive one of the following error messages: HTTP Error
405 Method Not Allowed
The method specified in the Request Line is not allowed for the resource identified by the request. Please ensure that you have the proper MIME type set up for the resource you are requesting.
Please contact the server's administrator if this problem persists.
HTTP 405 - Resource not allowed
Internet Information Services
This problem occurs if the following conditions are true:
  • You do not specify the file name. For example, you do not specify http://Server/Web/.
  • The Scripting Object Model (SOM) is enabled.
  • A DTC event is called.
CAUSE
This problem occurs only when you use Microsoft Internet Information Services (IIS) 4.0 and Microsoft Internet Information Services 5.0. This problem occurs if you send a POST request to a server that is running IIS 4.0 or IIS 5.0, and the POST request contains a URL that ends in a slash mark (/). IIS returns the 405 error message instead of the default document. However, if the method value of the Verb property is GET or HEAD, IIS returns the default document. RESOLUTION
When the SOM is enabled and a DTC event is called
When the SOM is enabled for the page, a <FORM> tag that is similar to the following is inserted in the page. <FORM name=thisForm METHOD=post>
Because no ACTION attribute is specified in the tag, both Netscape Navigator and Internet Explorer try to make an HTTP POST request to the URI "web/". According to the HTTP RFC (RFC 2068), this is not a valid Request-URI for a POST operation.
To work around this problem, use one of the following methods:
  • Redirect from the default document to a different document. In this case, the SOM-enabled document will no longer be the default document. The new default document will just redirect to the SOM-enabled document. For example, if your SOM-enabled document is named MyDefault.asp, the default document (Default.asp) will contain only the following code. <% Response.Redirect "mydefault.asp" %>
  • Use client-side script to make sure that the file name is included in the URL. If you must use your SOM-enabled document as the default document, use a client-side code block that is similar to the following code block as the first code block within the <HEAD> section of the page. This code block does the following location replacement. Language=JavaScript> var loc = document.location.toString() var loclen = loc.length //The name of the default document var filename = "default.asp" var filelen = filename.length loc = loc.substring(loclen - filelen, loclen) if (loc.toUpperCase() != filename.toUpperCase()) { location.replace(filename) }
When the remote scripting is called
This problem may occur if you use the window.location.href property in an HTML document to determine the path of the current document. If you do this when you initiate a remote scripting call, the remote scripting call fails because the client page does not have a file name.
To determine whether the page can use remote scripting on the client, verify that the value of the window.location.href property does not end in a slash mark. To provide a file name in the client browser, and to prevent the error on the server, use the Response.Redirect method redirect the request from the default page to another page. For more information, see the first resolution method in the "When the SOM is enabled and a DTC event is called" section. STATUS
Microsoft has confirmed that this is a bug in the Microsoft products that are listed in the "Applies to" section.
This bug was corrected in Microsoft Internet Information Services 6.0. Properties Article ID: 216493 - Last Review: 11/21/2006 13:13:42 - Revision: 3.2
Applies to
  • Microsoft Internet Information Services 5.0
  • Microsoft Internet Information Server 4.0
Keywords:
  • kbbug kbctrl KB216493
32helpful
When i enter the chat room i got the notice... a error has occured in the script on this page line:7 char:2888 error:permision denied code:o url:...
when am trying to enter chat room after entering the capache code it showing >>>>An error has occured on the script on this page .....Line : 7 ..... Char : 2888..... Error : Permission denied .... Code : 0 ...... URL : http://yui.yahooapis.com/2.4.1/build/connection/connection-min.js ......... Do you want to continue running scripts on this page? YES NO <<<<<<<<< It showing like this in one Script Error box please Help me how to solve this problem am getting mad with this .....please help me
Http://fb-tc-0.farmville.com/flash.php?ref=tab&isOuterIframe=1&&fb_sig_in_iframe=1&fb_sig_base_domain=farmville.com&fb_sig_locale=en_US&fb_sig_in_new_facebook=1&fb_sig...
Your computer is struggling to reach "fb-tc-0.farmville.com". The website is in fact working, so there is something wrong your end. Try restarting your computer & your router.
I unable to access farmville on facebook page, i have tried IE and Google Chrome and it gives me the following error The webpage at...
farmville is a big issue in facebook right now, facebook is trying to solve it also. but i recommend u to use mozilla firefox browser for it. may its fixed ur problem.good luck.
3helpful
4helpful
I have not been able to play farmville on facebook for about 5 weeks - it only loads to 50% then hangs - the error message says the following :- Error: Permission denied for (document.domain has not been...
Error: Permission denied for <http://fb-1.farmville.com> (document.domain has not been set) to call method Location.toString on <http://apps.facebook.com> (document.domain=<http://facebook.com>).
My door locks do not operate when using remote on key fob
If it's the remote buttons wearing out (check by taking remote apart and bridging the contacts with a small screwdriver. If it works fine that way, go to keylessfix.com $10.00 will fix it.
/******************************************************** This Script will be included in all web pages to show an Icon on Mouse over, Clicking the Icon will show a Zoominto Viewer (a Flash made viewer) to Zoom the Image Content ********************************************************/ var tmppluginServername = "http://www.zoominto.com/zoomapi/"; //tmppluginServername= "http://localhost:9999/zoomapi/" var versionswf="1100"; versionswf=""; var tmppluginSwfname="" tmppluginSwfname=tmppluginServername + "zoomplugin" + versionswf + ".swf"; var tmppluginimageURL=tmppluginServername + "displayimage.php?image="; var protocol = "http://"; var isInternetExplorer = navigator.appName.indexOf("Microsoft") != -1; plugin_run(); function BrowserZoomPlugin() { var ua, s, i; this.isIE = false; this.isNS = false; this.version = null; ua = navigator.userAgent; s = "MSIE"; if ((i = ua.indexOf(s)) >= 0) { this.isIE = true; this.version = parseFloat(ua.substr(i + s.length)); return; } s = "Netscape6/"; if ((i = ua.indexOf(s)) >= 0) { this.isNS = true; this.version = parseFloat(ua.substr(i + s.length)); return; } s = "Gecko"; if ((i = ua.indexOf(s)) >= 0) { this.isNS = true; this.version = 6.1; return; } } var browser = new BrowserZoomPlugin; var dragObj = new Object; dragObj.zIndex = 0; function zoominto_dragStart(event, id) { var el; var x, y; if (id) { dragObj.elNode = document.getElementById(id); } else { if (browser.isIE) { dragObj.elNode = window.event.srcElement; } if (browser.isNS) { dragObj.elNode = event.target; } if (dragObj.elNode.nodeType == 3) { dragObj.elNode = dragObj.elNode.parentNode; } } if (browser.isIE) { x = window.event.clientX + document.documentElement.scrollLeft + document.body.scrollLeft; y = window.event.clientY + document.documentElement.scrollTop + document.body.scrollTop; } if (browser.isNS) { x = event.clientX + window.scrollX; y = event.clientY + window.scrollY; } dragObj.cursorStartX = x; dragObj.cursorStartY = y; dragObj.elStartLeft = parseInt(dragObj.elNode.style.left, 10); dragObj.elStartTop = parseInt(dragObj.elNode.style.top, 10); if (isNaN(dragObj.elStartLeft)) { dragObj.elStartLeft = 0; } if (isNaN(dragObj.elStartTop)) { dragObj.elStartTop = 0; } dragObj.elNode.style.zIndex = ++dragObj.zIndex; if (browser.isIE) { document.attachEvent("onmousemove", zoominto_dragGo); document.attachEvent("onmouseup", zoominto_dragStop); window.event.cancelBubble = true; window.event.returnValue = false; } if (browser.isNS) { document.addEventListener("mousemove", zoominto_dragGo, true); document.addEventListener("mouseup", zoominto_dragStop, true); event.preventDefault(); } } function zoominto_dragGo(event) { var x, y; if (browser.isIE) { x = window.event.clientX + document.documentElement.scrollLeft + document.body.scrollLeft; y = window.event.clientY + document.documentElement.scrollTop + document.body.scrollTop; } if (browser.isNS) { x = event.clientX + window.scrollX; y = event.clientY + window.scrollY; } dragObj.elNode.style.left = dragObj.elStartLeft + x - dragObj.cursorStartX + "px"; dragObj.elNode.style.top = dragObj.elStartTop + y - dragObj.cursorStartY + "px"; if (browser.isIE) { window.event.cancelBubble = true; window.event.returnValue = false; } if (browser.isNS) { event.preventDefault(); } } function zoominto_dragStop(event) { if (browser.isIE) { document.detachEvent("onmousemove", zoominto_dragGo); document.detachEvent("onmouseup", zoominto_dragStop); } if (browser.isNS) { document.removeEventListener("mousemove", zoominto_dragGo, true); document.removeEventListener("mouseup", zoominto_dragStop, true); } } function imgplayerprogress_DoFSCommand(command, args) { var imgplayerprogressObj = isInternetExplorer ? document.all.imgplayerprogress : document.imgplayerprogress; } function zoominto_addElement(divIdName, htmlval) { try { var newdiv = document.createElement("div"); newdiv.setAttribute("id", divIdName); newdiv.setAttribute("title", ""); newdiv.style.position = "absolute"; newdiv.style.display = "none"; newdiv.innerHTML = htmlval; document.body.appendChild(newdiv);; } catch (e) { } } function zoominto_addmyelems(divIdName, htmlval) { try { var newdiv = document.createElement("div"); newdiv.setAttribute("id", divIdName); newdiv.innerHTML = htmlval; document.body.appendChild(newdiv);; } catch (e) { //_L(e); } } function zoominto_initializelements() { zoominto_addElement("plugpanel", " "); zoominto_addmyelems("plugincheck_0909", ""); } function zoominto_GetElementPostion(theElement) { var selectedPosX = 0; var selectedPosY = 0; tmpw = theElement.width; tmph = theElement.height; while (theElement != null) { selectedPosX += theElement.offsetLeft; selectedPosY += theElement.offsetTop; theElement = theElement.offsetParent; } var tempelement = new Array(selectedPosX, selectedPosY, tmpw, tmph); return tempelement; } function plugin_showdeadcenterdiv(Xwidth, Yheight, divid) { var scrolledX, scrolledY; if (self.pageYOffset) { scrolledX = self.pageXOffset; scrolledY = self.pageYOffset; } else if (document.documentElement && document.documentElement.scrollTop) { scrolledX = document.documentElement.scrollLeft; scrolledY = document.documentElement.scrollTop; } else if (document.body) { scrolledX = document.body.scrollLeft; scrolledY = document.body.scrollTop; } var centerX, centerY; if (self.innerHeight) { centerX = self.innerWidth; centerY = self.innerHeight; } else if (document.documentElement && document.documentElement.clientHeight) { centerX = document.documentElement.clientWidth; centerY = document.documentElement.clientHeight; } else if (document.body) { centerX = document.body.clientWidth; centerY = document.body.clientHeight; } var leftOffset = scrolledX + (centerX - Xwidth) / 2; var topOffset = scrolledY + (centerY - Yheight) / 2; var o = document.getElementById(divid); var r = o.style; r.position = "absolute"; r.top = topOffset + "px"; r.left = leftOffset + "px"; r.display = "block"; } function pluginalertShow(layerid) { document.getElementById(layerid).style.visibility = "visible"; document.getElementById(layerid).style.display = "block"; plugin_showdeadcenterdiv(280, 115, layerid); document.getElementById("plugin_btn_activate").focus(); } function pluginalerthide(layerid) { document.getElementById(layerid).style.visibility = "hidden"; document.getElementById(layerid).style.display = "none"; } function zoom_getValidString(){ return "&isValidviewer=1";// all things are valid } function zoominto_showflash(zoomres) { try{ if(zoomres == undefined) zoomres="600x442"; zoomarr=zoomres.split("x",2) var divimgplayer = document.getElementById("div_plugin_img_player"); divimgplayer.style.display = "block"; divimgplayer.style.visibility = "visible"; //old movie 550 400 // plugin_showdeadcenterdiv(600, 371, "div_plugin_img_player"); plugin_showdeadcenterdiv(parseInt(zoomarr[0]), parseInt(zoomarr[1])+120, "div_plugin_img_player"); // zoominto_setImage(); zoominto_changeobject(document.getElementById("plugpanel").title,zoomres); } catch (e) { } } function zoominto_closeflash() { var divimgplayer = document.getElementById("div_plugin_img_player"); divimgplayer.style.display = "none"; divimgplayer.style.visibility = "hidden"; } function hidezoomicon(){ document.getElementById("plugpanel").style.visibility = "hidden"; } function getMouseX( e ) { return e.pageX '' ( e.clientX + ( document.documentElement.scrollLeft '' document.body.scrollLeft ) ); } function getMouseY( e ) { return e.pageY '' ( e.clientY + ( document.documentElement.scrollTop '' document.body.scrollTop ) ); } function dhtmlLoadScript(url) { var e = document.createElement("script"); e.src = url; e.type="text/javascript"; // document.getElementByTagName("head")[0].appendChild(e); document.getElementById("addiv").appendChild(e); } function getactualimgdimensions(imgsrc){ zoomintoheavyImage = new Image(); zoomintoheavyImage.src = imgsrc var tempelement = new Array(zoomintoheavyImage.width, zoomintoheavyImage.height); return tempelement; } function plugin_run() { var newcss = "#div_plugin_img_player td {padding:0;} \n #div_plugin_img_player th {padding:0;}"; if ('\v'=='v') /* ie only */ { document.createStyleSheet().cssText = newcss; } else { var tag = document.createElement('style'); tag.type = 'text/css'; document.getElementsByTagName('head')[0].appendChild(tag); tag[ (typeof document.body.style.WebkitAppearance=='string') /* webkit only */ ? 'innerText' : 'innerHTML'] = newcss; } var image = document.getElementsByTagName("img"); var totimgLength=image.length; zoominto_initializelements(); for (var i = 0; i 50 && zoomarrdim[1] > 60) { image[i].onmouseover = function () {imgvals = zoominto_GetElementPostion(this); document.getElementById("plugpanel").style.display = "block";document.getElementById("plugpanel").style.visibility = "visible";document.getElementById("plugpanel").style.left = imgvals[0] + "px";document.getElementById("plugpanel").style.top = imgvals[1] + "px";document.getElementById("plugpanel").title = this.src;}; image[i].onmouseout = function (evt) { imgvals = zoominto_GetElementPostion(this); strx=imgvals[0]; stry=imgvals[1]; endx=imgvals[0] +imgvals[2] ; endy=imgvals[1] + imgvals[3]; tmpcurx=evt.pageX; tmpcury=evt.pageY; if(tmpcurx > strx && tmpcurx stry && tmpcury 1 && match[1] != "") { output += match[1]; x += match[1].length; } else { if (clearString[x] == " ") { output += "+"; } else { var charCode = clearString.charCodeAt(x); var hexVal = charCode.toString(16); output += "%" + (hexVal.length Default115%125% \n"; document.getElementById('resselect').value=zoomres; }
Top Facebook Computers & Internet Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you a Facebook Computer and Internet Expert? Answer questions, earn points and help others
