Question about GE Spacemaker JVM1640SJ Microwave Oven
Mounting this unit under the cabnet
A once friend gave me this microwave and for the last year we have been using it sitting on the counter.  Now we have new cabinets and want to mount it under it, but we were given no mounting brackets or hardware.  Does any one know what we need and where I might find it? Thanks
  • GE Master
  • 9,098 Answers
You can download GE owner's manuals and installation instructions here.
You can usually find helpful exploded view diagrams and order parts (including mounting parts) by entering your full model number here.
Posted on Aug 09, 2008
How do i remove a over the stove microwave?
On a 1-10 scale- this is a 2.
place a cardboard box on the stove to support the microwave once it is free.
Remove power cord from the outlet in the cabinet over the microwave.
In the cabinet over the microwave, locate the 2 mounting screws.
Loosen each one about 6 turns- the microwave should drop down in the front by about 1/2 inch.
Once loose, you can remove both screws completely and allow the front of the oven to rest on the cardboard box.
While supporting the front of the microwave,have a helper remove the cardboard box.
Tricky part...while supporting the front - angled slightly down, lift hard under the rear of the microwave and pull toward you.
Have a helper feed the power cord through the upper cabinet bas as you bring the microwave toward you and slightly down.
Place the microwave on the counter- with a towel in place to prevent scratching the counter.
remove the rear-wall mounted support bracket.
Done
Apr 27, 2014 | Maytag MMV4205 Microwave Oven
I have a G E over the under the counter microwave the power cord fuse is 20 amp I replaced it pluged in the microwave front lights up I then put something in oven turned on fuse blows ASAP what should
If you're trying to say that the fuse blows as soon as you press the "start" pad to begin cooking, then you have as shorting high voltage capacitor.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Nov 27, 2012 | Microwave Ovens
IKEA/Whirlpool IBMS1455WS-0
I have the same microwave and keep having this problem over and over again. If I recall correctly they have had to replace the main control board each time. Luckily the part was not available once and they gave me a new microwave so I got a new five year warranty. This is a horrible flaw in a fairly expensive microwave. Seems like the button only lasts 2 years max. It is really disappointing. Don't think I would get another whirlpool. Had lots of problems with the fridge too.
Apr 27, 2012 | Microwave Ovens
Does the ge spacesaver xl1400 microwave have to mounted or can it just sit on a counter?
Theoretically JVM1400-series microwaves (XL1400 is a meaningless number they put on the ovens) can be used on a counter top, but it's really not safe because it has no feet, and it may slide and fall off the counter.
Also, it will probably not set level on a counter.
If you need mounting hardware or other parts, you can get them by by entering your full model number from the tag on the oven here.
Sep 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore over the range microwave oven model 721.80413500 keypad just stopped working. No response when pressing any button, even the light and fan button. Microwave was working fine minutes before.
80% of power problems are caused by ceramic fuse locted under microwave cabnet.Use a tester to see if you have continuity.You may just need a fuse.
Jan 29, 2011 | Kenmore Microwave Ovens
I have a 5 year old Samsung microwave oven, model MD800WC. It sits on the counter. The display lights up and the light goes on when the door opens - so there is power and there is a connection. BUT, the...
looks like your control unit pcb is not having power, most likely a varistor blow up on the input power line to the board, just replace it and fix the melted track on the board.
Sep 22, 2017 | Samsung 1.8 Cu. Ft. Over-the-Range...
How to remove from mounting
if its an under counter set-up,then remove the 2 screws inside the cabinet above the unit and lift out of angle bracket mounted to the wall,use 2 people to be safe when doing so
Apr 15, 2010 | Kenmore 61689 Microwave Oven
I have a convection/microwave oven that is approximately i yr. old. it recently stopped working. i bought it at walmart for 149.00 it worked just fine and i was so pleased with it so was very surprised...
You can find contact information for Daewoo at http://www.e-daewoo.com/customer_service.asp
If it's within one year, it should still be under warranty.
Either way, I would recommend contacting them for your nearest Daewoo-authorized service center.
Most recent Daewoo owner's manuals can be downloaded here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 25, 2008 | Daewoo Microwave Ovens
Unit does not work
open microve cover find magnetron crimp connections to magnetron
Feb 12, 2007 | Emerson MW8108P Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
247 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
