Question about Maytag Dependable Clean Top Load Washer, MAV3955EWW
How do you remove the agitator on a Maytag Dependable Care Washer?
The hole that the fabric softner runs down thru the agitator is plugged. I would like to remove agitator and clean.
  • anataia Oct 25, 2008
    my washing is always full of lint. i have a maytag performa
  • lulai Nov 24, 2008
    I have Maytag Perfoma (model#PAVT234AWW), and same problem.
    However, I couldn't find any area that I could take the agitator out. Please help me on this.
    Thank you,
  • 5,911 Answers
If this is a Maytag Performa or Atlantis model all you have to do is remove the center cap on the agitator by pulling on it and locate the agitator bolt underneath. Loosen the bolt, and the agitator should pull straight up.
If this is a Maytag Dependable Care series there will be 1/4 inch screw along the side of the agitator towards the bottom. Remove this screw and the agitator will pull straight up.
I hope this helps you.
PS If the problem is due to the build up of fabric softener, soak in some hot water to loosen it up. Fabric softener is essentially a form of liquid wax and it is common for it to accumulate and clog the dispenser in this manner. Periodic cleaning is recommended.
Posted on Aug 09, 2008
There is a little nut on the side of the agitator near the bottom. If you take it out the agitator slides right off.
Posted on Dec 31, 2008
Remove dual agitator
The agitator in your Maytag Dependable Care washer uses a back-and-forth motion to move your clothes from the top of the washtub to the bottom and back to the top again. The fins on the side of the agitator help facilitate this movement. When one of the fins sustains damage or the agitator fails to move, you must remove the agitator to make the necessary repairs.Disconnect your Maytag Dependable Care washer from the electrical wall outlet. Turn off the valves supplying water to the appliance.
2 Open the washer's lid to access the agitator. Look for a 1/4-inch hex screw recessed in an opening about three-quarters down the side of the agitator.
3 Insert a 1/4-inch nut driver into the opening in the side of the agitator. Fit the nut driver over the head of the screw. Turn the screw counterclockwise to remove it.Grab the bottom of the agitator with both hands. Pull the agitator from the bottom of the washtub.
  • Nut driver, 1/4-inch
Sep 29, 2016 | Washing Machines
Fabric softner won't drain
If it is a top loader:
PULL of the fabric softener cup straight up
Rinse out thoroughly
Clean out the holes in the side of the agitator
Nov 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag MTW5620T2 the fabric softner despenser doesn't despense. There is mositure inside and it slings fabric softner everywhere. It leaks from the side hole of the agitator. Gets fabric softner on my...
Liquid Softener was clogged up over time.
1-Put hot water in the place of the Softener slowly and let it over flow to dissolve the solidified liquid.
2-Keep doing this until you see water at the bottom of the tub.
3-Run a small load to clean out the gum.
Jul 02, 2009 | Maytag Washing Machines
I have a odor problem with my FAV6800 AWW TL and standing water in bleach & fabric softner cups. The problem has gotten so bad that the odor has seeped into our clothes, yuk. The fabric softner cup will...
Hello mab2005,
Take a look at this post regarding removing Fabric Softener dispenser and clean out and see if it helps. The bleach dispenser is a bit more difficult to clean up I did not bother. You can also lift the washer top using this process to make sure the fabric softener and bleach dispenser drain holes are not blocked.
To raise the top of the machine; Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. See page 33 of the Service Manual for putty knife insertion point. You might find something in the Use & Care section of the service manual that might help, I have never looked.
You may have mold built up as I and other users have, see the attached Pic. If I were going to replace a tub seal I would clean out this mold during that repair process. This is the process I'm going to try sonn and I will let ya know if it works. Start a quick wash once the water fill sequence starts I would pause the washer. I would then remove the front panel (as I show in the pic) and view the tub while I very carefully over fill with water to slightly above the mold ring. I would then throw a gallon of bleach in start a continue the quick wash to agitate the solution for a few minutes pause the washer and let sit for a while. Then continue the quick wash thru the complete cycle. I would not try this until I give it a try I’ll let ya know how this works outs.
The tangle problem is inherent to the machine design with
the tumbler rotation action to agitate the wash
load. Hope this helps.
Apr 11, 2009 | Maytag Neptune FAV6800AW Top Load Washer
I need to remove agitator from my maytag washer, how do I get to the bolt under the fabic softener dispenser?
take the softner cap off then should be able to get to it with an exteison and a half inch socket
Mar 17, 2009 | Maytag Dependable Clean Top Load Washer,...
Top of agitator comes off in washer
#15... There's a bolt in there. Lift the fabric softener to access it.
SG
Feb 09, 2009 | Maytag SAV4655A Top Load Washer
I have a foul smell comming from my washer I want to try to take off the agitator and clean it How? :)
It depends on what model Maytag washer you have. If you have an Atlantis or Performa model Maytag you remove the agitator by, first, pulling the agitator cap and softener dispenser off. Locate the bolt on the center post and and loosen. The agitator will pull straight up to remove. If this is a Dependable Care model Maytag, there's a 1/4 inch screw located on the SIDE of the agitator about 3 quarters of the way down. Locate this screw and loosen. The agitator will pull straight up to remove. I hope this helps you.
Aug 01, 2008 | Maytag Washing Machines
Need to remove Agitator
On a MAV6000, you should be able to pop off the fabric softner cap, remove the fabric softner cup underneath, and finally remove the bolt underneath to lift up the agitator. (rocking the cap back and forth is usually the best method)
Jul 10, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer fabric softener dispenser is yucky
There is a 1/4" machine screw in a recessed hole close to the bottom of the agitator. Remove screw. Lift agitator off agitate shaft.
Nov 28, 2007 | Washing Machines
Maytag Dependable Clean Top Load Washer, MAV3955EWW Logo
1,504 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
