Question about Belkin Computers & Internet
Not able to set up network key for wireless network
  • Anonymous May 11, 2010
    I need the specs of your wireless router. Be more descriptive on what the actual problem is.
    Odin
  • 36 Answers
Use wep to create your pass phrase
Posted on Oct 07, 2008
    Novelist:
  • 173 Answers
What is the Security Mode that is configigured on router, is it WEP or WPA?
Posted on Aug 09, 2008
6ya staff
SOURCE:
How to set up wifi
To connect your computer to a wireless router, you click the Refresh network list, then Choose your wireless network and then click Connect to your secured Wireless Network, it will asks for a Network Key before allowing you to connect into your wireless network. This Network Key is either the WEP, or WPA or WPA2 Encryption key that is configured in the Wireless settings in the Router. The Passphrase is an alternate way to setup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrase or WPA or WPA2 key that was used to configure the Encryption key in the wireless router. http://www.fixya.com/support/r5270415-network_password_network_address For information on securing your wireless network, configuring the wireless router and configuring the wireless card in the laptop/computer, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Mar 30, 2013 | Computers & Internet
Hi i am using the pc sony vaio i have the problem on wireless adabter it was in desable mode and difficutl to active it ,while i am useing the bottom in front of pc on and off of wirless adabtor but i i on...
In Vista, you can either go to control panel, device manager and right click on it and click "eneble"
or go to control panel > network sharing and set up wireless network connection
or
go to task manager (press and hold ctrl . alt . delete for a couple of seconds), until task manager comes up. Then click on the services tab, scroll down till you see "Plug Play or Plug and Play and make sure it's running. If it's not, right click on it then click "enable"
In XP
Open Network Connections
Right-click Wireless Network Connection, and then click Properties.
On the Wireless Networks tab, do one of the following: •
To enable automatic wireless network configuration, select the Use Windows to configure my wireless network settings check box. This check box is selected by default. For information about what happens when you enable automatic wireless network configuration, see Notes.
To disable automatic wireless network configuration, clear the Use Windows to configure my wireless network settings check box.
To connect to an existing wireless network, do one of the following:
Access point (infrastructure)
To connect to an existing access point (infrastructure) network, under Available networks, click the network name, and then click Configure.
In Wireless Network Properties, specify the wireless network key (Wired Equivalent Privacy) settings, or, if the network key is automatically provided for you (for example, the key is stored on the wireless network adapter given to you by your administrator), select the The key is provided for me automatically check box. If you are unsure about whether a network key is needed or which settings you need to enter, contact your network administrator or the wireless network adapter manufacturer.
Important
If a network does not broadcast its network name, it will not appear under Available networks. To connect to an access point (infrastructure) network that you know is available but that does not appear under Available networks, under Preferred networks, click Add. In Wireless Network Properties, specify the network name (Service Set Identifier) and, if needed, the wireless network key settings.
Computer-to-computer (ad hoc)
To connect to an existing computer-to-computer (ad hoc) network, under Available networks, click the network name, and then click Configure.
If you want to connect to a computer-to-computer (ad hoc) network and both computer-to-computer and access point (infrastructure) networks are within range of your computer, click Advanced, and then click Computer-to-computer (ad hoc) networks only.
To configure a new wireless network connection, click Add, and then do the following: •
If the network connection that you are configuring is to a computer-to-computer (ad hoc) network, select the This is a computer-to-computer (ad hoc) network; wireless access points are not used check box.
To change the order in which connection attempts to preferred networks are made, under Preferred networks, click the wireless network that you want to move to a new position on the list, and then click Move up or Move down.
To change the wireless network connection settings for a network that is listed in Preferred networks, click the wireless network for which you want to change settings, click Properties, and then change the settings as needed.
To remove a wireless network from the list of preferred networks, under Preferred networks, click the wireless network that you want to remove, and then click Remove.
To update the list of available networks that are within range of your computer, click Refresh.
To automatically connect to available networks that do not appear in the Preferred networks list, click Advanced, and then select the Automatically connect to non-preferred networks check box.
To open Network Connections, click Start, click Control Panel, click Network and Internet Connections, and then click Network Connections.
When you enable automatic wireless network configuration, you can connect to an existing wireless network, change wireless network connection settings, configure a new wireless network connection, and specify preferred wireless networks. You will be notified when new wireless networks are available. After you select a wireless network, your wireless network adapter will be automatically configured to match the settings of that network, and a network connection attempt will be made.
To configure settings on the Wireless Networks tab, you must be logged on as an administrator, and you must use a wireless network adapter that supports the Wireless Zero Configuration service. If you are unsure whether your wireless network adapter supports the Wireless Zero Configuration service, contact your network administrator or the wireless network adapter manufacturer. For more information about automatic wireless network configuration, see Related Topics.
If you are using third-party wireless networking software, clear the Use Windows to configure my wireless network settings check box.
If you are unable to connect to an existing wireless network and the name of the network that you want to connect to appears under the Preferred networks list, click the preferred network name, and then click Properties. In Wireless Network Properties, review the settings to ensure that they are correct. If you are unsure whether the settings are correct, contact your network administrator or the wireless network adapter manufacturer.
If the Preferred networks list includes both access point (infrastructure) and computer-to-computer (ad hoc) networks, you cannot move a computer-to-computer network to a position in the list that is higher than the position of an access point network.
To provide enhanced security for 802.11 wireless networks and for wired Ethernet networks, IEEE 802.1x authentication is enabled by default. For more information about how to set up 802.1x authentication.
Hope this helps
Dec 12, 2010 | HP Broadcom NetXtreme Network Adapter
Virgin has installed. D link wireless router (home address) I have 2 laptop xp window vista and pc upstair they detect the vg 50Mb broadband but can not connect ! When I go with my 2 lap top elsewhere I...
1.
2.
3.
• To enable automatic wireless network configuration, select the Use Windows to configure my wireless network settings check box. This check box is selected by default. For information about what happens when you enable automatic wireless network configuration, see Notes.
• To disable automatic wireless network configuration, clear the Use Windows to configure my wireless network settings check box.
4.
• To connect to an existing access point (infrastructure) network, under Available networks, click the network name, and then click Configure.
Important
• If a network does not broadcast its network name, it will not appear under Available networks. To connect to an access point (infrastructure) network that you know is available but that does not appear under Available networks, under Preferred networks, click Add. In Wireless Network Properties, specify the network name (Service Set Identifier) and, if needed, the wireless network key settings.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 30, 2010 | D-Link DIR-300 Wireless Router
Troubleshooting wireless home network using windows xp
To Configure a Wireless Connection in Windows XP, Follow the Instructions Outlined Below.
  1. Click the Start button, click Network Connections, and choose Show all Connctions.
  2. Click the Wireless Network Connection icon with your right mouse button, then choose View Available Wireless Networks.
  3. Choose the name of the 2Wire access point from the Available networks list.
  4. In the Network key field, type the hexadecimal key to access the wireless network.
    Note: The hexadecimal key and wireless network name should already be set up on the 2Wire device. Use the key that you set up on the 2Wire device.
  5. In the Confirm network key field, type the hexadecimal key to access the wireless network again for confirmation.
  6. Click the Connect button.
Apr 15, 2010 | HP Pavilion m7680n PC Desktop
Wireless adapter
You will need to check the wireless settings of
the router.
wep key is a password for the wireless network.
your wireless network must be secured. You will need to check the wireless security settings on your router.
Is there any computer online using the router.
If yes then you can open the router set up page on
that computer.
router set up page is the page where you can check
all the router settings.
Click Here for more information about the routers
and network
Feb 05, 2010 | Microsoft Wireless Network Adapter Xbox...
Setting up wireless connection on aceracer, aspire sa90- wireless connection
Check the Following
1) Wireless Switch of the Laptop is off (Wifi is Off)
it is located somewhere on the edge of the laptops
or Fn+F2 might turn the switch ON and OFF
2) The setting required to configure wireless connection
Check the following steps
Windows XP
1. Click on the Start Menu, and click on Control Panel.
2.Find and double-click “Network Connections” to open up the list ofconnections that your 3. computer uses to connect to the internet.
4. Right click “Wireless Network Connection” and select “Properties”.
5. Go to the “Wireless Networks” Tab
6. Check “Use Windows to configure my wireless network settings”, if it isn't already.
7. Click “Add” to add a wireless profile.
* Enter in the Network name (SSID). (It was your desired SSID from Step 6 ).
* Uncheck the box “The key is provided for me automatically”.
* Put in the “Key 1” code from Step 7 into “Network key” and “Confirm network key”.
* Push “OK”
# Open Internet Explorer (with the computer connected to the Router)
# Enter 192.168.1.1 into the Address Bar, push Enter
# Leave the User Name field blank
# Under the password field enter “admin”
# Click “OK”
# Click “Wireless”
# Click “Basic Wireless Settings”
# Enter a desired name into the “Wireless Network Name (SSID)” field
# Write down your Wireless Network SSID, it will be used for later.
# Click “Save Settings”
For WEP:
* Click “Wireless”
* Click “Wireless Security”
* Select “WEP” in the “Security Mode” field
* Bubble “1” under the “Default Transmit Key” field
* Select “128 bits 26 hex digits”
* Enter a desired passphrase into the “Passphrase” field
* Click “Generate”
* Carefully write down the code generated in the “Key 1” field on paper, and store it in a safe place. THIS IS YOUR WEP KEY, it will be needed later on.
* Click “Save Settings”
Jan 18, 2010 | Zonet Fast Ethernet Adapter Realtek 8139D...
My wireless has a WPA key and Abox is asking
  1. Plug in the Microsoft Xbox 360 Wireless Adapter to one of the USB ports on the back of your Xbox 360.
  2. Turn on your Xbox 360 and navigate to "My Xbox" and then "System Settings."
  3. Go to "Network Settings" and then "Configure Network."
  4. Select the appropriate settings for the wireless network you will be connecting to on the "Basic Settings" tab.
  5. Enter the name of the SSID of the wireless network you will be connecting to. If the SSID is not broadcast, select "Specify Unlisted Network" and enter in the SSID of the network manually.
  6. Enter in the wireless security key (WEP or WPA) so that your Xbox 360 can access the network.
  7. Select "Test Xbox Live Connection" back on the "Network Settings" screen to verify that your Xbox 360 is now connected to the wireless network and ready for use.
Should work for either WEP or WPA
Sep 24, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Need network key
there is no set network key for that model... the network key is something set up on the router or wireless access point. You will need to talk with the administrator of that network to recieve the network key.
Oct 25, 2008 | Belkin (F5D7000) 802.11g/b Wireless...
SECURITY PROBLEM
first go to router setting page, for access router page the default ip add is 192.168.1.1 try this first, if the router page is not open then check the default Gateway in u r pc and keep the ip add of ur pc ob tend automatically
1. when the page is open then go to wireless potion>wireless security>
2. then select encryption type WEP > 64 bits
3. then type pass phrase>click on "generate network key"
4. routher will generate 4 network key , select first key as wireless security key.
5. save this settings.
now the wireless connectivity automatically disconnected
6. now search the wireless network on u r pc .
7. when u get u r wireless network , then connect to this network
now the wireless network key is ask bye system ,
8. type the network key which generated by router .
and connect 2 u r wireless network
Aug 20, 2008 | Linksys Wireless-G WRT54GL Router
I bought an Acer notebook (Aspire 9920) back in December. My ISP manual says that the 'Wireless Network Key' should be on the base of the notebook on a coloured label. This doesn't appear to be the case....
A wireless network key is used to join to a wireless network. Wireless networks are created by routers and/or access points. In order to obtain the key so you can log onto the network, you must have access to the router's settings or be given the key by someone who can access the router. To access the router, you type in it's IP address into your internet browser. If it is password protected, you will need that as well. Once in the router settings, you can set many configuration options, including the wireless network password or passphrase and encryption type.
Again, if you are joining to a wireless network, the KEY is determined by the router, not the laptop. This is how multiple wireless devices are allowed onto the same network: they all use the same key.
Mar 28, 2008 | Computers & Internet
Open Questions:
Computers & Internet Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Pamela Bates
Pamela Bates
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
