Question about Maytag M7DH65B2A Dehumidifier
Runs, but overheated, tripped outlet causing freezer full of rotten food
After 2+ years of my dehumidifier and small dorm-size freezer being plugged into the same outlet, which is mounted ON the breaker box, I discovered a freezer full of rotten food the other night after the dehumidifier had tripped the outlet at least 5 days earlier. The dehumidifier had been set to 55% humiditiy level. My sump pump never runs because I live in a very dry area, but it's a basement, so to me it's humid, and I am VERY sensetive to ANY humidity. Anyway, I had to reset the outlet, turned the dehumidifier back on, and within 5 minutes the outlet tripped again. So I reset it, etc. again, and it happened a third time. After a few more minutes I noticed burning/hot smell coming from the dehumidifier, so I did NOT turn it back on again, but instead unplugged it. I plugged a lamp into the same outlet along with the freezer and nothing ever tripped, so the dehumidifier is definitely the culprit. What would cause this after only 2 years and how can I prevent it from happening again? I don't run it in the winter, so it hasn't even had 2 full/continuous years of use. I am beyond disappointed and furious that I lost $100+ worth of food, some of which was meant for a bridal shower this weekend. I will likey not have it serviced but will buy a new one instead, but it won't be another Maytag.
  • brcdv Aug 21, 2008
    My dehumidifier does the same thing .It is about two years and when I turn it on it trips my circuit.
There was a recall on these - it depends on the age.  I bought mine in 2003 or 2004, and they sent a repairman out to replace a circuit board.  Call Maytag to see if yours was in the recall.
Posted on Oct 23, 2008
When turn off. makes a humming sound. compressor seems to be running.
Have same issue with 3 year old Frigidaire dehumidifier purchased in 2012. Must unplug to stop compressor running with power switch turned off. Unit gets hot and smells. Unplugging creates arcs at outlet since unit is pulling a lot of power. Plugging back in after some hours will make it appear to run normally and again remove moisture but it will not shut off when the fan goes off (humidistat bad?) and the set-point is reached. Cannot leave plugged in due to safetty/fire/overheating concern. Have not found answer on this forum or any other so far.
Sep 15, 2013 | Frigidaire FAD704TDP Dehumidifier
It just quit.. was doing a good job and just not getting any power. no light. Have had it about 2 and a half years. Thanks
Before giving up on it. Test the outlet it was plugged into, to see if there is still power there. If not, a circuit breaker may have tripped or a loose wiring inside the outlet.
Thanks for choosing FixYa.
Aug 14, 2011 | Goldstar DH304 Dehumidifier
Demudifier worked great, all a sudden it just stopped. No power. Now it won't start up. What should I try?
First, check the outlet that it's plugged into, to make sure that there's still power to the outlet. If there isn't, then the circuit breaker for that outlet has been tripped, in your home's circuit breaker panel. Leave the dehumidifier unplugged and reset the circuit breaker. If it trips again, without the dehumidifier unplugged, then the outlet is at fault. Perhaps there's a loose wire connection or the interior of the outlet is cracked.
If it didn't trip without the dehumidifier plugged in, plug the unit it in,. But, before you do, make sure the dehumidifier's Master ON/OFF Switch is OFF. Once it's plugged in, turn the Master ON/OFF Switch to ON and set your controls. If it runs now, GREAT! If it trips the circuit breaker again, there's either a short in the power cord or an internal electrical short. Which will require extensive troubleshooting to find.
Hope this helps you solve the problem. Please let me know. Thanks.
May 05, 2011 | Fedders A7DH45B2A Dehumidifier
Dehumidifier trips ground fault outlet and no water in bucket
The compressor is trying to start and pulling high amps which trips the GFI...
You are better off replacing rather then repairing that unit.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 17, 2010 | Haier 45-Pint Dehumidifier
Dehumidifier is tripping circuit breaker.
The compressor is bad and is causing the circuits to trip....
Here is a tip that I wrote about that problem...
heatman101
Apr 16, 2010 | DeLonghi DE500P Dehumidifier
Why does my dehumidifer suddenly starting tripping
either the compressor is locked up or the motor start capacitor on the compressor is shorted
Apr 14, 2010 | Ebac HD880 Dehumidifier
My Fedders A7DH45B2A dehumidifier (about 4 yrs old) continues to trip the fuse embedded in the outlet on the wall in which it's plugged in.. What gives??
either try a different outlet to see if the G.F.C.I. is bad on this outlet or if the dehumidifier trips on another line it could be the units motor start capacitor that shorted or the compressor is bad
Apr 06, 2010 | Fedders A7DH45B2A Dehumidifier
Electrical
I believe it is highly likely you've got a short somewhere in your unit. The highest probability is that the cord is compromised. If that's not it, you could have bad winding insulation in the motor. It shouldn't be difficult to isolate the problem if you know your way around a multi-function volt/ohm meter.
Oct 18, 2007 | Haier HDN455 Dehumidifier
Ground fault interrupt (GFI)
I have a Whirlpool Model AD$)DSR1 Dehumidifier, with similar issues. When plugged in where it was operating for three years with no problems, it would trip the gfci within 10 minutes. I have it out in the garage right now with all the covers off, and I've had it running on a heavy duty outlet for about a half hour now. The compressor is too hot to touch (ouch!), and the condenser coils are only cool, when they should be quite cold. I am ready to judge that one of two things has happened: Either the compressor is bad, or the refrigerant has leaked out of the system.
Sep 07, 2006 | Whirlpool AD50USL Dehumidifier
Maytag M7DH65B2A Dehumidifier Logo
280 people viewed this question
Top Maytag Dehumidifiers Experts
Michael Van Der...
Michael Van Der...
Bill Long
Steve
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
