Question about Sony LAMP BLOCK XL2100U Projector Lamp
Our lamp does not turn off
We can turn off the TV but the lamp still stays on, it has melted the cover due to the exessive heat. The only way to turn off the lamp is to unplug the TV.
This is a defect that Sony has "kind of" recognized with an extended warranty, till 2010. I consider it a fire hazard and feel strongly that Sony is underestimating it. They are also NOT fully supporting the warranty and seek to charge me for repairing the problem, at the minimum an "installation fee" for the new bulb. BS. I am writing to the CPSC and Consumers, and taking them to court. Good luck!
Posted on Nov 13, 2009
I turned on my tv this morning and it started smoking and of course smelling like something inside was burning. We took off the back and can see nothing that looks burnt or melted but the tv still wont...
hi,
may be ur tvs lamp side have some problem. may be the lamp over heated and burned. just open its lamp cover ann check it.
also check its power supply input point(near fuse) there is an MOV (used for voltage surge protection) is burned or not. if there is any voltage surge it will get shorted and the fuse will blow off, protect the power supply for any further damage. check the fuse also. if found open then check the MOV. insert fuse only after replacing the MOV.
ok
Dec 22, 2010 | Samsung HL-S5087W DLP TV
Sony Grand WEGA KDF-60XBR950 60 green orange green red flashing light
3 blinks is a lamp cover error, did you make sure that the lamp cover is screwed in tight? Also check the lamp cover for deformity, there is a problem with your model where the set over heats and melts the lamp cover a little causing it not to make connection with the lamp cover switch. Let me know if you find either of these problems? If not we can troubleshoot a little further.
Tim Nolan
Sep 14, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Power ligth blinks three times then starts blinking red tv wont start
Lamp cover error, lamp cover is not attached securely. Please check the lamp cover if deformed. If the lamp cover has been deformed due to excessive heat exposure, replace it with a new one. Sometimes the lamp cover melts due to overheating caused by poor air ventilation. Clean the fan and lamp compartment to avoid overheating....
Nov 30, 2010 | Sony KDS-60A2000 60" HDTV
Interior bulb heating up
LG has had an issue with this and has re designed the lamp cover and the lamp holder itself. contact your nearest parts supplier with your model and re order this part and you will receive the new upgraded cover.
Oct 04, 2009 | LG LFX25971ST Bottom Freezer French Door...
Projection lamp casing melted.
This will be covered covered under warranty by Sony. If you will call 800-282-2848 you can locate a Sony authorized servicer that should be able to repair this at n/c.
Feb 09, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Original lamps producing excessive heat.
there is a recall for that problem you need to contact LG and they will send a repair kit for your refrig. it should be repaired at no cost but be sure to ask them.
Jan 19, 2009 | LG LFX25960ST Stainless Steel French Door...
Red lamp light stays light
I doubt that it is the optical assy. it sounds more like a chassis problem either on the DM or the FMT board.
check out www.tv-techs.com
if it is a chassis problem it will cost about $250.00 plus shipping one way to fix the chassis
Dec 30, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Feb 13, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Shutting off and on...
the problem may be due to dry soldering in the power supply stage if it was with the lamp there would be red or green light showing the presence of the power to the tv after making it own some of the components get hot and it will make the the soldering point conectionless and after some time the heat sink get cooled and the soldering point gets connected and u will see the picture again it is a simple problem if u have a soldering iron u make it hot and re solder all the components in the first part of the circuit board and the problem if rectified
Jul 03, 2007 | LG RU52SZ30 52" Television
Tv keeps turning off
If it's staying on for just a short period of time it sounds like there is a sensor that is giving the unit a faulty condition (Perhaps for reason or due to a fault in the sensor). There are normally a few temp sensors in the TV around the Lamp and Ballast. They may be bad, or the lamp or ballast is just generating too much heat.
Feb 05, 2007 | Panasonic PT-45LC12 45" Rear Projection...
78 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
