Question about Vacuums
Sebo automatic x4 power cuts out, bag not full, filters replaced
  • mazzy68 Jan 27, 2009
    Has just stopped dead in it's tracks after 5 years no probs. The posted solution is too techie for me - what do I do to fix it (if it can be fixed)?!
  • 1,673 Answers
Could have a problem with the cord or maybe the switch. The swivel neck has wires runing from where the want plugs into and plugs into the a circuit board, sometimes one of the wires opens then the motor cuts in and out. There also is the motor and a computer controller causing a problem.
Posted on Aug 10, 2008
What is the right bag for sebo x4
  1. First, pull out the hose, turn the unit on, check for an obstruction in the hose. (unclog and obstruction)
  2. Separate the body from power nozzle. Check for obstruction in the air hole passage.
  3. Pull and clean both filters in the unit. The inside white long carriage and the exhaust filter located above indicator panel. (nozzle body)
  4. If this is not working. think about where and how dirt is carried or passes from the front floor nozzle or through the hose.Somewhere in the unit the it is clogged. The red light censers a full bag (we know that's not the issue) or an obstruction to the normal air flow.
  5. Last Resort contact
  6. In closing: I've been selling and repairing vacuums for over 30 years. Of all the 5 major brands that I sell. Sebo is by far the, best product on the market.
Aug 23, 2014 | Sebo X4 Bagged Upright Vacuum
The brush on sebo x4 will not go up or down. Red check brush light briefly flashes
You should try to replace your SEBO roller brush with the softer one. The part number is SEBO 5010GE Genuine Sebo product
Jan 11, 2014 | Sebo Automatic X1 Bagged Upright Vacuum
How to fix squeaking and bag full sign lit on the sebo x4 extra upright vacuum?
Check the main "kitchen roll" filter isn't clogged which is on the left hand side of the bag when the bin door is opened. There could be a clog, either behind the pick out metal grid below the filter roll, or the roll filter requires to be replaced. Can you add more info about the squeaking though? Is it a high pitched squeal all of the time or just intermittent and where it seems to be coming from - it could be excess air escaping from a pierced hose or a drive belt issue.
Oct 30, 2013 | Sebo X4 Bagged Upright Vacuum
My sebo x4 bagged hoover is losing power, what could the problem be
Is it a Sebo , or is it a Hoover. It can't be both . "losing power" ??? Motor comes on and off ? or stops picking up ? Be more specific please.
Oct 20, 2013 | Sebo X4 Bagged Upright Vacuum
It just keeps saying that my bag is full and cutting out, bag not full and have tried changing it anyway, but still cutting out
I would check the air filter. It sounds like it's over heating and shutting off because it doesn't have good airflow.
Oct 05, 2010 | Sebo X4 Bagged Upright Vacuum
Bag full or clog light comes on but new bag and no blockage... Sebo x4 upright cleaner
Have you checked the filters to see if they are blocked and need cleaning/replacing. Failing that it could be the sensor at fault.
Jul 25, 2010 | Sebo X4 Bagged Upright Vacuum
Full bag clog light
1.If your sebo is less than five years old, you have a reciept, and are not using it commercially, in most cases this machine will still be under factory warranty. To locate
an authorized sebo dealer simply call sebo or use the dealer locator on their website.
2. If it is no longer under warranty:
First i would pick up something small such as a balled up gum wrapper and make sure it makes it to the bag, more often than not something is not checked, and its still plugged. Heres how i'd check for plugs.
  • Pull the wand out and remove it from the hose by pressing the button on the wand look through the wand
  • Remove the hose from the machine by pinching the hose clamp and pulling the hose out (it simply presses back in when you are done)
  • press on the large button below the bag compartment on the front. (its often a different color and presses difficultly) lift the bag compartment and handle off the powerhead. (replace by simply pressing the bag compartment back onto the head)
  • look down the powerhead and inspect the other areas of the bag compartment.
  • open the orange/gray door on the bottom of the powerhead and look through checking for debris.
Simply go back up through the steps to reassemble.
If your test makes it into the bag just fine and you are not plugged, the tall filter inside the bag compartment would be my next suggestion and since you changed this it should not be a problem. This leaves few possible problems. Circut board error/Sensor error would be my next step. Essentally its one in the same, but there is no great way to test them without simply replacing parts. (an expensive proposition) The local sebo dealer will more than likely have a working used board they pop in and out to check for problems. Some dealers may let you use these others will require you either buy the parts or pay for labor.
*Bad boards in sebo/windsor products are extremely rare, my bet is always on a plugged filter or plug in general. Be sure to look carefully something as small as a toothpick surrounded by carpet fuzz can set them off.
Best of Luck
Jun 05, 2009 | Sebo Automatic X1 Bagged Upright Vacuum
Sebo vacuum cleaner cuts out ?why
it might be the bag.just check with your local vacuum store
Jun 04, 2009 | Sebo X4 Bagged Upright Vacuum
Sebo x5 vacuum cleaner
The full bag light comes on when it is getting full or a blockage in the hose or the dirt inlet by the brush roll. Other then that, there is a circuit board called the computer controller, part #5740ER and is giving you a false reading and causing a shut down.
Jun 22, 2008 | Sebo X4 Bagged Upright Vacuum
Vacuums Logo
94 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
