Question about Maytag MSD2454G Side by Side Refrigerator
Maytag MSD24GR ICE MAKER
I HAVE INSTALLED A NEW ICE MAKER, HOW DO I RESET IT TO MAKE IT START MAKING ICE?
  • Maytag Master
  • 3,051 Answers
You need to turn off the water to it then take the arm and move it all the way down and turn on the water and you should hear it click than give it time for the first batch to get made be adviced to throw the first batch away somtimes there is dirt and little uglies in the first batch good luck!!!!
Posted on Aug 09, 2008
My maytag PBF 1951 HEW ice maker is not making ice.
HI.THIS SOUNDS LIKE YOUR INLET VALVE ALI
Jul 12, 2012 | Maytag Refrigerators
The ice maker is not making ice. The water filter has been replaced and there are no trouble indicators from the lights on the front of the unit. The house has a water softener for whole house service.
Hello
Where the water comes into the ice maker.Be sure it is not frozen up.If it is, remove ice with a hair dryer.
Also,reset ice maker by lifting full ice tray arm and putting it back down.
Jun 05, 2011 | Maytag MFI2266AE Side by Side Bottom...
The ice maker has stopped making ice.
first check the water supply on the ice maker check inlet water solinoid valve then reset the unit by unplugging power cord after a minutes plug the unit and start ice maker see to it that the compressor running.
Jan 23, 2011 | Frigidaire 20.6 cu. ft. Top Freezer...
Ice maker not making ice
check the water solenoid for the ice maker on the back
Jun 11, 2010 | Maytag MFI2266AES Stainless Steel Bottom...
My maytag is model MFD2560HES serial number
does the water dispenser work OK ? if yes , a try this : pour 3/4 of a cup of water into the ice maker, right into where the ejection fingers are. also , take all of the ice out of the ice bin. then , give the freezer time to freeze the water you have poured into the ice maker and see if the ice maker ejects the ice into the bin. if it does, it might reset itself and refill the unit and work normally.
Mar 17, 2010 | Refrigerators
Maytag MSD2754GR - Ice Maker quit working.
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Aug 29, 2009 | Maytag MSD2456G Side by Side Refrigerator
Ice maker quit making ice
There are repair instructions available for this particular ice maker at www.AnyoneCanFixIt.com Specifically, you should locate it at www.anyonecanfixit.com/household.htm
Aug 24, 2009 | Maytag MFD2560HES Bottom Freezer French...
Maytag side by side multi problems
1. Ice maker is not cold enough to start the ice making process.
3. having to take off the back panel is an indication of a problem in the defrost system. Call to have a service tech check this out.
May 15, 2008 | Maytag MSD2756GES Side by Side...
Same thing happened to me. I unplugged the refrigerator, plugged it back in and it worked. I guess the computer system reset itself. Easy fix.
May 13, 2007 | Maytag MSD2756G Side by Side Refrigerator
Maytag MSD2454G Side by Side Refrigerator Logo
313 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
