Lanier 5613f problem code sc551
How can I fix this function error message
  • katbatten Aug 09, 2008
    lanier 5613f error code 5613f how can I fix it?
2 Suggested Answers
SOURCE: Lanier LD245 error code SC542 appears
Fuser warm up error. Code can only be reset in service mode after the problem is fixed
Posted on Jun 08, 2009
WHAT IS THE CODE SC551?
Symptom]
SC551 (thermistor disconnect: thermistor2) or SC561 (thermistor disconnect: thermistor3) is displayed.
[Cause]
The drawer connector surface is partially corroded.
A foreign object or debris has adhered to the surface of the fusing unit drawer connector contact and, when the adhered moisture melts due to condensation, it causes part of the surface of the drawer connector to corrode. It becomes clear that SC551/SC561 occur because of faulty contact with the image fusing unit.
[Resolution]
Replace the drawer connector on the device.
Apr 25, 2016 | Office Equipment & Supplies
What to do with error sc543?
fuser error will need to fix fuser first then reset code
Oct 08, 2014 | Ricoh Aficio SP C231SF SPC231SF SP C232SF...
Where can I find parts for my Lanier 5613F paper tray?
Hello sir; Please contact with me by email, I can get it for you.
Jul 18, 2009 | Lanier 1205 Copier
Jun 06, 2009 | Office Equipment & Supplies
How to replace drum unit
open right cover, and front cover. Remove toner bottle assembly (not just bottle), unplug drum (photoconductor) connector. Press the gray/silver release tab and slide out drum. Install and plug in new unit, replace toner assembly, close covers, and the new unit is automatically detected and calibration will begin.
May 25, 2009 | Lanier Office Equipment & Supplies
Printer shows error CH551
Is this actually a Ricoh Aficio 1013F, or another model, because "CH551" is not a ricoh service code?Do you mean "SC551"
If so, this is a fuser "triac" problem (basically a fuse in the heater unit). It can only be reset in service mode after the problem is fixed...and will require a tech.
May 21, 2009 | Ricoh Aficio 1013F Copier
Error code SC302
From the Ricoh-Lanier Error Code Sheet:
SC302: Charge Corona Output Error 3 - Grid Voltage error - Charger Roller Current Leak.
I would suggest replacing first the charge roller and if that doesnt fix it, the HIgh Voltage Supply Board.
Mar 19, 2009 | Lanier 5222/27 Laser Printer
Ricoh photocopier 1075 code sc541
Ok, its a firmware bug, but you should be able to reset it. Press clear modes, 1, 0, 7, and press and hold clear/stop. Press 1 for copy sp. Scroll down to 7, (data log) press 7. scroll to 7807, and reset it. exit all the way out, and recycle the power.
Mar 18, 2008 | Ricoh Aficio 1013F Copier
349 people viewed this question
jasbo
jasbo
