Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Help with Phillips TV
The power light is on but there is no sound or picture. I have a beeping sound that continues while the TV is on. Any suggestions?
  • Anonymous Aug 17, 2008
    when i put the input button it blinks on picture off picture
  • Philips Master
  • 3,459 Answers
This is a common problem with some older models. Check the site www.magnavoxhelp.com to see if they have a repair kit for your set.
Posted on Aug 13, 2008
Samsung HLS5687.Replaced lamp,turned on TV the light goes on turns off. The projector boards continues to beep then tv powers off. Color wheel does spin. Not sure what the beeping is.
Did you check the ballast for the lamp? It provides the high voltage/energy to excite the lamp (no filament) into operation. If it does not work properly neither will the bulb.
Great set - I have the 5685.
Mar 06, 2016 | Samsung HLS5687WX/XAA
Phillips Magnovox
Its a power supply issue the only solution is to get it repaired.Possible power outage.Repair charges would be around $400.
Goodluck,
Please don't forget to rate the solution
Apr 25, 2008 | Philips 9P5034C 50" Rear Projection...
Power light but no picture or sound
Hi!
My name is Chris.
I have this Phillips Wide Screen TV that didn't have or come with a remote, so I had to go out and buy a universal remote for it today from a BIG W Store. I'm having some technical difficulties & problems with switching and turning it on, but as I use the universal remote to turn on the TV, I'm having a bit of a slight problem with it turning it on, Ok, Yes, it works and Powers on, but there is nothing showing or giving me the indication that there is no picture or sound showing up on this Wide Screen Phillips TV, But there is a little red & green light at the bottome right hand corner that keeps on flashing red when ever I use the universal remote to switch the power on. Is there a possibility, that i can get some help on here, to help me out with any suggestions, is to why I'm not getting any picture or sound showing up on this TV with this universal remote ? Is there anyway that i can maybe get some help with this to help me out with solving my issue with the Phillips Wide Screen TV ?
Nov 17, 2013 | Philips 42PF7320A 42 in. Plasma HDTV
Picture but no sound on magnavox tv
My tv which is phillips has sound but no picture,there is two red lights on the front that comes on ,one is for power but what is the other one
Jun 20, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
The TV has no picture or sound but the red light on the front comes on?
The red light on the front is part of the system control (computer) in your television it indicates likely your power supply and computer are functioning. There are a multitude of problems that can cause no picture and no sound. Power supply troubles are most likely. The system control will have it's own little power supply which is always on so it can listen to the front panel or your remote. It will continue to operate when the heavy duty power supply might not. This suggests a shop repair would be in order. House calls can't fix something like this unless they are VERY lucky and find something obvious. You will still pay for the house call even if they can't fix it.
Mar 31, 2010 | Hitachi 51F59 51" HDTV Projection...
NO PICTURE OR SOUND ON MY PHILLIPS MATCHLINE LCD TV 15PF9936 PLEASE HELP!!!!!!!!!!!!!!!!!!!
make sure it has power at the outlet,then suspect a blowed fuse or dioed or flyback,etc.
Feb 13, 2010 | Televison & Video
Green light blinks but no sound no picture
Power surge will knock out picture and sound if you don't have a power strip. Found out from Best Buys when purchasing another LCD TV. They have a warrenty against such problems.
Jan 18, 2010 | Sanyo DP19648 19 in. LCD TV
I have a RCA 27" flat SDTV purchase in
Ur power inverter board is dead.
U need new one.
Aug 20, 2009 | RCA TruFlat 27F520T 27" TV
TELEVISION NOT WORKING
The beeping you are hearing is an error code. call a tech to come look at itas they will have the full lists of codes.
Mar 22, 2009 | LG 42PX5D 42 in. Plasma HDTV
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
165 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
