Question about Compex NetPassage 28G Wireless Router (NP28G)
Can not connect printer behind the rounter/printserver
I try to add HP Deskject 970Cxi which is connected to Compex NetPassage 28G to my Vista Home Premium notebook without success. Windows just can not see the printer. Same network and printer work well with other notebooks with XP Pro and Vista Ultimate. If I add printer manually, the printer will not response to the print command. The print queue is on for a few minutes before say Error. Notebook can access to internet via wire and wireless without any problem.
Any diff. between Vista Home and others OS which may cause this problem. I try already to turn off the firewall but problem is still there.
Please help
  • Kaare1234 Nov 12, 2008
    I have the same problem when trying to access a HP 990Cxi from a Toshiba LapTop with Vista Home Premium installed.
viaujoc
  • 60 Answers
SOURCE: problem with power
Since I don't know the exact circumstances of your power loss, here what I am guessing based on that you wrote.
This may be because the power does not come back cleanly after the power failure. Unfortunately, there is nothing much you can do about it. Since your router does work correctly after you manually reset it, the power supply seems to be fine.
If you have many power failures and find this situation to be annoying, you should look to buy a UPS (Uninterrupted power supply). This kind of devices have a battery that will ensure a clean power output when running, powering up and shutting down. It will protect you from interruptions and voltage fluctuation. You may also benefit from connecting you computer to a UPS because it will keep it running for a couple of minutes after a power failure to allow you to save your work and may also shut it down cleanly automaticaly.
Posted on Feb 23, 2008
kleeper
  • 87 Answers
SOURCE: How to turn off the router's firewall
1. Insert the Product CD into your CD-ROM drive. The CD will run automatically.
From the Utilities section, select to install the uConfig utility to your hard disk.
2. When the utility has been installed, double-click on the uConfig icon. The
following screen will appear, click on the Yes button to proceed.
3. Select the router from the products list and click on the Open Web button. To
retrieve and display the latest device(s) in the list, click on the Refresh button.
4. Do not exit the uConfig program while accessing to the web-based interface.
This will disconnect you from the device. Click on the OK button to proceed.
5. At the login page, press the LOGIN! button to enter the configuration page. The
default password is “password”.
6. For the first time login, you will be prompted to select your time zone setting first
before accessing the router’s main web page. Take note that during the next
and subsequent logins, you will not see the System Time Setting page again.
7. You will then reach the web page of your router’s web-based interface.
8. Under the SECURITY CONFIGURATION command menu, click on Firewall
Configuration.
Posted on Oct 22, 2008
  • 132 Answers
SOURCE: Wireless printing
Check the printer's manual if the software of this printer already supports winVista. If it is, you may connect the printer directly to the PC and check if you'll be able to print.
Hope this helps!
Posted on Nov 13, 2008
kakee
  • 1269 Answers
SOURCE: Need to re-setup my router.
Try to hard reset the router by pressing the reset button at the back of it. Hold it down for 30 seconds then unplug the power for 30 seconds. Reconfigure it
Posted on Jun 01, 2009
  • 10406 Answers
SOURCE: install CD of compex NetPassage 26G is lost
This router is at least 5 years old, and it does not support the more-secure WPA protocol. On that basis, I would "trash" it.
I checked the COMPEX web-site:
http://www.cpx.com/download.asp
and there is no mention of the '26G', although the '27G' is listed as a "legacy" product.
So, spare yourself a lot of wasted time -- go to the nearest "Boxing Day/Week" big-box store, and buy a new router, with new features, like 'Wireless N' and 'WPA2' support, and install it.
Posted on Dec 27, 2009
Need to re-setup my router. the router lost connection a few times. solved by power disconnect. now does not connect at all. type COMPEX NetPassage 27G Wireless-G 54 Mbps Extended Range.
Jun 01, 2009 | Compex NetPassage 27G Wireless Router...
What does the orange light blinking on the computer mean?
It generally means that you have an empty, damaged, or incorrect ink cartridge installed.
May 04, 2009 | HP DeskJet 970cxi InkJet Printer
Connecting Compex 28g to mobile broadband and home network
please check following points:-
1) IP address (some wireless AP's follows ip address such as 192.168.1.1 for AP and 192.168.1.2 for 1st workstation, 192.168.1.3 for 2nd workstation and so on).
2) check connection options in IE. it should be lan setting and detect automatic setting and use automatic configuration script(put IP address of AP)
3) if DHCP is enabled then obtain IP automaticlly
4) check for any WEP security options i AP.
5) user must have internet access rights.
6) if Static IP is Used please give gatway ip (your AP's IP address) and same for DNS IP address.
then restart your system and enjoy internet.
May 01, 2009 | Compex NetPassage 28G Wireless Router...
Can't configure Netpassage 26g for static ip...
Make sure dhcp is enabled and when that doesn't work try http://www.neoseeker.com/Articles/Hardware/Reviews/compexNP26G/
Apr 12, 2009 | Compex NetPassage 26G / iWavePort WLU54G...
Wireless printing
Hope this helps!
Nov 12, 2008 | Compex NetPassage 28G Wireless Router...
Hp deskject 970cxi problem
THe frown face means the cartride is empty.
Jan 02, 2008 | HP DeskJet 970cxi InkJet Printer
Compex NetPassage 28G Wireless Router (NP28G) Logo
67 people viewed this question
Top Compex Computers & Internet Experts
Michael Galve
Michael Galve
Rose li
Rose li
Are you a Compex Computer and Internet Expert? Answer questions, earn points and help others
