Question about Sony Network Walkman NW-E005 MP3 Player
Device USB Sony NW-005F not recognise and message Full on NW
Hi, I had reset by the small button at back of the NW-005F,
I had reinitialise and format by the menu advance setup.
Nothing work, the same message, after the usb connection to a PC, the PC don't recognise and the device indicate Full. In the pass the Service repair of Sony resolve this problem by an internal reset but we pay many money for this service.
How to open this device?
It need some trick or procedur to don't break it.
Tank
  • immuuuuu Aug 10, 2008
    format erorr problems
  • lucifershere Sep 02, 2008
    i can put songs in it but when i go to play them it flashes format error
SOURCE: i dont tranfer music to NW-E003
If you go to http://en.wikipedia.org/wiki/SonicStage#Alternatives there are a few unofficial alternatives to using sonicstage. I have yet to try them but will be doing so soon. Sonicstage just seems extremely slow anyways.
Posted on Mar 21, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: SONY NW-A3000
Bad news - if you tried multiple pc's and it still failed, then your player is done.
Make sure you:
reset the player
upgraded the firmware
used the recovery tool
called Sony to be sure
last ditch effort:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard.
Buh-bye!
-Tha Mp3 Doctor
Posted on Jul 06, 2008
SOURCE: Sony NW-A1000 will not play,
If you get the spinning disc error on your sony nw a1000 it means the hardrive is knackerd.
The hardrive in the sony NW A1000 is a segate ST1.2 6gb and these can be bought off ebay for around £8. If you can't find a 6gb one you can fit an 8gb hardrive BUT your NW A1000 will only use 6gb of it.
If you search on the internet you can find instructions on how to remove the back cover of your NW A1000 which is very easy to do! You then unplug the hardrive (be very careful!) and replace it with the new seagate hardrive. Turn the NW A1000 on and go to the home menu, select "settings", then select "intialize disc" and it will format your new hardrive so that it can work with NW A1000.
Posted on Nov 27, 2008
  • 3 Answers
SOURCE: My computer can't recognize it as removable device,
Your post:
in case you have not been able to solve your problem as yet, try the following: DO NOT CONNECT THE PLAYER TO THE COMPUTER as you have a format device on your player: firstly get rid of all your files you might need as you might have used your player as a stick secondly make sure that you still have got your OMGAUDIO file on it (if not, post that you need it, possibly I could help you with this) THEN
push the small button long, go to "menu" (the small briefcase)
push the large button and go to "advanced" by pushing the "forward button" on the side
push the large button again
a spanner will appear and "sound"
push the forward button again until you get"Initialize"
large button will say "reset", then reset but even better to solve your problem:
push forward again until you get to "format", forward to "ok"
large button and your player will be completely new formatted
get some converted music files on your player and it will work!!
I had the same problem, and finally I managed to solve it.
To be honest, I quite like my player!
good luck
Posted on Mar 09, 2009
  • 9 Answers
SOURCE: code d'erreur 000066d7
lies
Posted on Jul 09, 2009
NW-E003F and i am having FORMAT ERROR
The FORMAT ERROR message may occur if the Walkman player has been formatted using the format utility in Windows Explorer. To correct this issue, initialize (format) the portable player using the Initialize or Format utility built into your Walkman player.
Home button-->Menu-->Advanced Menu-->Initialize-->Format-->OK.
Reset the unit by pressing the RESET button with a small object such as a paper clip. Reset button is located near the volume buttons.
If the issue occurs after making any changes in the SonicStage Software, then reinstall the Software in the Computer using the latest version. Click here to download the latest version of the SonicStage Software.
This should resolve the issue.
Thanks for using FixYa
Apr 06, 2011 | Sony Network Walkman NW-E005 MP3 Player
Nw-e002f format error
Follow these troubleshooting steps to resolve this issue.
The NO DATA or FORMAT ERROR message may occur if the portable player has been formatted using the format utility in Windows Explorer. To correct this issue, initialize (format) the portable player using the Initialize or Format utility built into your Walkman player.
If the issue persists, I suggest that you un-install and reinstall the latest version of the Sonic Stage Software and transfer the songs again to resolve the issue. Click here to download the latest version of the SonicStage Software.
Thanks for contacting FixYa.
Mar 02, 2011 | Sony NW-E505 MP3 Player
Format error
Feb 15, 2011 | Sony NW-E002 MP3 Player
Your post:
good luck
Feb 04, 2009 | Sony NW-E003F MP3 Player
Sony NW-A3000 mp3 player not registering on sonicstage
I was having these problems with mine.  The first thing I tried was the reset button, it's on the back of the mp3 player and you need a safety pin or a sewing needle to push it in. Then I tried a different USB port. Problem solved.
Sep 03, 2008 | Sony Network Walkman NW-A3000 MP3 Player
No data being received and sent
you need a usb that as 2.0 or one that as it own trans former if not try a nother usb port ?
Jan 20, 2008 | Sony Network Walkman NW-E005 MP3 Player
Format error
actaully i bought ipod one month past........by mistake i formated my sony walkman NW-E005 512 MB MP3 Player now i get format error and if i copy songs then message show no data what can i do please help me to resolve my problem Thanks
Aug 11, 2007 | Sony Network Walkman NW-E005 MP3 Player
Sony NW-A1000
Maybe the mp3 player is dead.. but.. you should install the firmware update for it.. because maybe the mp3 player ROM has a defect..
May 02, 2007 | Sony NW-A1000 MP3 Player
Sony Network Walkman NW-E005 MP3 Player Logo
168 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
