Question about Jack Lalanne Power Juicer 250 Watts
Jack Lalanne Power Juicer250
Jack Lalanne Power Juicer 250 after two attempts to use my juicer it seems the blade is'nt cutting properly!
  • hcjr1450 Aug 09, 2008
    If power is'nt being supplied properly to blade how do I get the power to be supplyed properly?
    Master:
  • 763 Answers
Try to remove the blade on your juicer and insert it properly. it might cause the unproper worked. make sure that you connected on the right voltage of your conductors. hope that helps!
CHARCOIS
Posted on Aug 09, 2008
    Genius:
  • 1,689 Answers
This is a great juicer by the way, the blade other jack lalanne's can be removed for washing, the blade itself rotates clockwaise, and to remove it, counter clockwise, if you still have the manuall, do check fi you will still be able to tighten the blade unit. because if it is the power supplied to the blade, the juicer will not move.
  • 1,031 Answers
Check the power source for proper connection ,you can try another power source ,reduce the fruits
    Master:
  • 382 Answers
There are two reasons which can cause this..
1) Dont add fruits completely in the juicer because the capacity of the motor is comparitively less!!
2)Please check the connection of the motor to the blades..
Hope this helps you out!..Thank you..
Regards!!...
  • Natesan Sabesan
    Natesan Sabesan Aug 09, 2008
    Well if the blade doesnt work(rotate) at all then there is no power supply to the blade..but if it does then over loading the juicer might be a problem..If your sure then try to open up the panel of the juicer and check with the connections going to the Motor and Connections from Motor to the Blade..If your not sure then contact a Service person which is more advisable!..
    Kind Regards!!!!!!!....
    Master:
  • 623 Answers
Dont push to ******* the fruit
    Master:
  • 848 Answers
The power is not properly supplied to blade .....just check whether the connections are proper ....
How do I get the part shaped like a half moon to release the blade from the juicer:
Fit the stubby metal bits on the half-moon into the holes on the top of the blade. Hold the half-moon firmly and exert pressure to turn it to the right. The blade should unlock.
May 09, 2014 | Jack Lalanne Power Juicer 250 Watts
Where the blade of the juicer screws on has broken off
mcdevito75, Refer to the owners manual for return of the juicer for repair, or go online to Jack Lalanne juicer for repair/return details.
Jun 16, 2010 | Jack Lalanne Power Juicer 250 Watts
I need to clean my Jack Lalanne power juicer.
is a manufacturer secret- I think you need to keep the juicer dirty
Mar 17, 2010 | Jack Lalanne Power Juicer 250 Watts
Blade for jack lalanne juicer
tri star products or search up tri star in google
Jan 17, 2010 | Jack Lalanne Power Juicer 250 Watts
Taking the Jack Lalane power juicer apart
Maybe its the orange tool you're talking about. The tool has two ends. It fits in the blade. The blade has 2 holes. Fit it in the 2 holes and turn it to screw the blade out. Careful not to cut your hands.
Jul 14, 2009 | Jack Lalanne Power Juicer 250 Watts
How to disassemble to clean. don,t have a tool. for jack lalanne power juicer.model CL-003AP.
Just find a big wire around 1/8 diameter. Bend it and insert both ends on the blade holes. Cover the sharp blade with cloth or use leather gloves.
Jun 15, 2009 | Jack Lalanne Power Juicer 250 Watts
Jak lalanne not working
Regarding Jack Lalanne juicer. After making sure nothing clogs the blades., make sure the stainless bar is on the correct slots on top of the juicer, left and right. It has a safety switch that when its not closed properly, it won't run.
Jan 31, 2009 | Jack Lalanne Power Juicer 250 Watts
How to clean my jack lalanne power juicer
Take the top part of the juicer off so that just the shreder is visable. On top of the shreder are 2 small holes on either side of the blades. a handle devise with 2 pins came with the juicer. put the tool pins into the holes and twist counter clock wise. The blade will come off then rest is simple and the unit can be disassembled. If you have lost the tool disassembly will be more dificult but can still be accomplished using a cloth on top of the blades and twiting counter clock wise. Careful though or you will cut yourself
Jan 05, 2009 | Jack Lalanne Power Juicer 250 Watts
Jack lalannepower juicer book and crescent tool
kitchen scissor points from hole to hole, works.
Aug 13, 2008 | Jack Lalanne Power Juicer 250 Watts
Jack lalanne power juicer
I seem to be able to put the crescent too in but the blade just spins and doesn't seem to be connecting to anything to pull it out. Talk about frustration!!!!!!!!!!!!!!!!!!!!!!!
Jul 21, 2008 | Jack Lalanne Power Juicer 250 Watts
Jack Lalanne Power Juicer 250 Watts Logo
186 people viewed this question
Top Jack Lalanne Juicers Experts
Greg Cann
Greg Cann
Starnley Johnwells
Starnley Johnwells
Are you a Jack Lalanne Juicer Expert? Answer questions, earn points and help others
