try doing white wash feture in options see if u can get it out this way 1st before having to take aprt cheak cables are using old style sumtimes they do get glitch do factory reset thx for using fix ya . nick
The XPS M1330 has no video card, the video circuit is integrated into the motherboard. To determine if the video circuit or LCD display is the culprit, try connecting an external monitor to the 15 pin VGA plug on the side of the laptop. If the display on the external monitor appears normal then your LCD on the laptop is the problem, if not then you need a new motherboard.
I have smth same... my monitor as gets warm, has a vertical stripe that become blurry, then it becomes worse till the white or black striped, like a zebra line appears? Some electricians have changed the condensators, have put the radiators to reduce the heat, hell knows what is with it, I really like it but no1 can fix it... any1 have any ideas?
This system has a VGA port so you can plug in an external monitor. You can buy one for less than $130 based on the Sunday ads. Other than that, it is new laptop time.
deight, your set is going into total vertical collapse, either the vertical IC is failing or some support component to the vertical circuit is failing, should not be an expensive repair, hope this helps, BMW Rider
