Question about Mackie SWA1501 Subwoofer
Signal light stays on, no sound output
On my Mackie SWA 1501, the speaker pops when powering up, but the signal light remains on even with nothing connected, and when there is something connected, I get no sound. I have checked the 3 internal fuses I can access from just pulling the power amp, but none appear blown. Are there additional fuses under the input board I should check?
My guess from my trouble shooting thus far is I have an input problem... perhaps a blown fuse if there is one under that input board or an ic chip or capacitor on the input may be out... any ideas?
Thanks
  • MTNKEN Aug 09, 2008
    I have a bit more info now.... I took off the input module, and there is an aluminum strip on the side of the board that is screwed into two chips mounted off of the input board... these chips are connected by three soldered legs into the input board, and one of those chips is completely disconnected from the assembly... the chip is in the T14 slot.... and has TIP122 C0420 written on it.... it is located on the lower left corner of the input board...
    I tried moving it to establish a connection while the unit was plugged in, and the speaker popped slightly
  • TheShards Feb 14, 2009
    I, too, had this same problem with my sub. Fortunately I have two of them, so I was able to swap the power amp stages to troubleshoot the speaker vs. amp. I did notice the T1L250V fuse had blown but replacing it did not fix the problem (of course, fuses mostly blow because they were taken down by an active component). In desperation (because I dreaded paying upwards around 500 bucks to replace the amp, and so far I was only down 50 cents for the fuse) I took off the input stage and found exactly the same result: One of the transistors was COMPLETELY broken from its connection. The three legs broke right at the board solder joint (i.e., the solder welds held fine, but the actual metal legs broke). There was no way I could solder the transistor onto the existing stumps, so I removed the stumps and soldered three long legs that I cut off from a wirewrap IC socket I had laying around and then soldered then into the holes on the pc board. Then I soldered the the transistor stumps onto those new legs sticking out of the board taking care to make sure the holes on both transistors lined up with the heat sink strip (I had to remove a small portion of the glue melt that hold the strip firmly to the board soI could get to the transistor's mounting holes on the board; no big deal though). Now the cabinet seems to work fine. I have a gig in a few days so I can't wait to see if it still craps out after a half hour or really does go the distance now. But after only 50 cents...and a couple of hours 'rediscovering the wheel'...it feels good to know the research on the web paid off, even if only temporarily! Thanks for your help folks! This was quite the adventure. -Phil.
T14 is part of the +15v power supply that feeds the input board.
It is actually a transistor.
If this is the only problem on the board, then this transistor could be resoldered back on but you will have to make sure it tests OK and it attaches to the heatsink the same way it came off. ie make sure it is electrically isolated from the heatsink
It seems if there is no fuses blown on the power amp board you might be one of the lucky ones.
In my opinion this amp is a clever design but is under-engineered for robustness
Posted on Sep 16, 2008
My mackie swa 1501 when you plug in no power checked the outlet their is power checked power cord good. what can i do
There are many possibilities, the switch, motherboard, electronics etc. If you are a DIY kind of person and you want to try trouble shooting yourself, you need tools. Better still, take it to a service person/ outlet to proper checks.
Oct 06, 2014 | Mackie SWA1501 Subwoofer
Mackie thump 15 a over load light stays on when powerd not even sending a signal to them.
There's a problem with the amplifier transistors or other heat generating circuit. That's what triggers the overload light.
Sep 11, 2014 | Mackie Thump 15 TH-15A Powered Speaker
Why does my mackie swa 1501 sound keeps cutting in and out
So it's heavy? .... i wanna know exactly what happens . You turn it on and turn on the volume, pls tell mecwhat exactly happens and when with which freq
thx rich
Jun 17, 2014 | Mackie SWA1501 Subwoofer
Mackie sub swa 1501 no LED no output but light on board appears to be on
los transistores de salida estan en corto 2sa1943 y 2sc5200 reviisa los drivers tip 122 y los irf
Feb 18, 2012 | Mackie SWA1501 Subwoofer
Blowm fuse
for 110V supply use at least 8Amp fuse but for 220V supply 4amp will do.
Mar 12, 2010 | Mackie SWA1501 Subwoofer
The Amp on Mackie SWA 1501 sparked and burned today
I don't think the amps are available from Mackie any more. You can have it fixed: www.alivesoundcenter.com
Nov 26, 2009 | Mackie SWA1501 Subwoofer
Humming speakers
If you disconnect the signal leads and the hum is away, it's probably a groundloop problem, or your equipment is generating the hum.
If it does not go away, the amps are defective
Sep 23, 2009 | Mackie SRM-450 System
Sw 1501 no sound output
in my dvd dts audio is not playing
Feb 13, 2009 | Mackie SWA1501 Subwoofer
I have a pair of mackie srm 450 and one swa 1501 the bass output in one of the 450s has no sound. i hear sound only from the high frequency part of the speaker
you have one of two problems.1) the woofer is blown(most likely) or 2) the crossover is fried(rare). Take the woofer out and press on the speaker cone(softly). If there is a scratchy feeling when you move it or if it doesn't move at all, you'll either need a new woofer, or get that one reconed.
good luck.
Dec 04, 2008 | Mackie SWA1501 Subwoofer
Mackie SWA1501 Subwoofer Logo
683 people viewed this question
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
Iron
Iron
Govind Deepak Kumar
Govind Deepak Kumar
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
