Question about Dometic Rooftop RV Air Conditioner
Dometic 15,000 BTU Rooftop A/C for RV
Three year old a/c cools but before it reaches proper set temp, the compressor seems to stop with a shudder, then the fan blows in extremely high gear for about 45 seconds. After a few minutes the a/c/ begins again. We have another one in front of rig that never does this.
  • 6 more comments
  • kamper2 Aug 11, 2008
    I could not find a definitive model number but specification sheet indicates my two units are one of these two model #s 620526.321 or 620526.326. Both units are ducted and both work off the Comfort Control Center. I was a bit of a step ahead of you in making notes to what as happening, although perhaps not to the degree you suggested. Does the following info help?
    8/9/08 @ 7:20 pm Excellent 50 Amp service with Hughes Autoformer Mini Transformer
    A/C was set to 73 degrees
    The outside temp was 83 degrees
    The inside temperature was 75.9 with humidity inside at 33%
    The unit's compressor cut off with a shudder
    The fan kicks into high gear and blows hard (without compressor the air is barely cool)
    The fan blows by itself for 45 seconds and then stops altogether
    The whole unit restarts both the compressor and fan at once within 2 minutes (without any human intervention)
    Removed shroud but allowed unit's insulation to stay in place and waited for the malfunction to reoccur. ( It did within 10 minutes)
    Removed the insulation at the moment the malfunction reoccurred and viewed that from what could be seen - the coils were not freezing up.
    Note: Just prior to the malfunction, the second a/c unit in front of fifth wheel kicked on and was functioning (as it always does) properly.
    To rule out possibility that the malfunction had anything to do with the second unit powering up. The seond unit was completely turned off.
    After 10 minutes, the unit cycled off properly (no incidence of the compressor stopping first followed by the fan in high gear ) but it powered up again within 2 minutes.
    Doubtful that it ever reached the temp set on comfort control thermostat at the time it kicked off -since it kicks back on in less than 2 minutes.
    Several times after turning off the bedroom unit - the main unit cycled off without incident but within an increase of three tenths of a degree and within 2 minutes it cycled on again.
    Now, after open the cover and looking at unit on roof - but doing nothing - it seems to be working properly.
  • kamper2 Aug 14, 2008
    Thankful to all who wrote in and has suggestions to try. We have tried them all and feel the main problem is simply that the unit is short cycling. Will pay for professional help and will share our results once we get issue resolved.
    As of 8/14/08, I have paid $9.99 for email expert assistance. I wish only to add to the above information, that we have monitored our problem for over 36 hours now and have found a consistent pattern of one a/c unit where the compressor runs 10 minutes and then shuts down for 3 minutes and then restarts. When maximum temp of the day ourtside is reached, we have the additional problem of the fan running for 50 seconds past the time the compressor quits. Still the 10/3 minute cycles. Other a/c unit not affected at all. It takes the unit all day to reach the set temp on the CCC since it never stays on any longer than ten minutes before shutting down for 3 minutes.
    We have turned off all fluorescent lights and computer router as once person suggested it could be RF waves. No change and we doubted it would since the other unit is not affected.
    620526.326.
    I am unsure I am properly reporting my problem. I paid for the $9.99 Premium email assistance but unsure who is answering my questions about my Dometic Rooftop AC/Heat Pump Penguin that has only a 10 minute compressor running cycle then a 3 minute off cycle nm matter what the CCC temp is set at. Will I get the solutions I paid for or are you saying you can't help after I just paid $9.99? What am I doing wrong?
    I just keep getting, "Good Luck" remarks from responders to my problem. Will someone be posting an actual solution? What did I pay $9.99 for if all I get are people saying "o.k. and good luck"?
    Dear Techexpert12
    You say I need ventilation for my unit outside but how can it not be getting proper ventilation if it is sitting outside on top of my R.V. with nothing around it and no trees or obstructions. If this indeed were the case, why would it not have done this the first 3 years I had it?
    I keep getting advice about proper ventilation of the unit. I assure
    you it is well maintained and properly ventilated. The unit has no
    obstructions and no damage to the fins or blower. The blower is
    running but compressor still shutsdown every 10 minutes and restarts 3
    minutes later. The unit is on top of our r.v. with no trees around and
    the temperature outside is 87 degrees. Since the rig is in full sun, I
    am sure it feels a lot hotter on top of the roof. Yet, these a/c units
    should be designed to handle this. If the heat build up in the unit
    can cause a shutdown, what other reasons are there for this heat build
    up besides ventilation (since I feel it has plenty of ventilation).?
    I keep getting advice about proper ventilation of the unit. I assure you it is well maintained and properly ventilated. The unit has no obstructions and no damage to the fins or blower. The blower is running but compressor still shutsdown every 10 minutes and restarts 3 minutes later. The unit is on top of our r.v. with no trees around and the temperature outside is 87 degrees. Since the rig is in full sun, I am sure it feels a lot hotter on top of the roof. Yet, these a/c units should be designed to handle this. If the heat build up in the unit can cause a shutdown, what other reasons are there for this heat build up besides ventilation (since I feel it has plenty of ventilation).?
  • 1,800 Answers
Nice tries every body but i gues the problem is about proper place sir u just shud change the place wherte u set the A/C
Posted on Aug 14, 2008
    Scholar:
  • 163 Answers
The machine has three main parts. They are a compressor, a condenser and an evaporator.
The working fluid arrives at the compressor as a cool, low-pressure gas. The compressor squeezes the fluid.
The working fluid leaves the compressor as a hot, high pressure gas and flows into the condenser.
A blower (electric) blows air to condenser coils to lower compressed cas temp and convert it in liquid. Blower's Air output must be free flow to have satified result, otherwise temperature arise and control sensor stops compressor's operation.
    Genius:
  • 1,665 Answers
Ensure that heated by compressed freon coils are well ventilated and blower is running. If their temperature goes high causes compressor to stop and remain stopped until temperature goes at acceptable range.
    Genius:
  • 1,142 Answers
The fan runs but there's no cold air?Is the air conditioner completely dead? See section 1. Is the thermostat knob turned to the proper setting? Is the compressor motor running? The compressor is a football-sized case with no apparent moving parts. It is located inside the air conditioner at the center. Is it humming or making any kind of continuous noise or causing the lights to dim? If it is making a continuous noise, and your air conditioner is still not cooling at all, there may be a serious problem with one or more of these areas:
  • Compressor
  • Condenser
  • Evaporator
These items are not user serviceable. You will need to contact a qualified appliance repair technician to repair these components.
If the compressor is not running but you do have power to the air conditioner there may be a problem in one or more of these areas:
  • Compressor
  • Overload and/or relay
  • Thermostat (Open thermostat)
  • Burnt wiring
  • Bad selector switch
  • Capacitor
  • Posted on Aug 14, 2008
      Master:
    • 521 Answers
    Sorry to know that no 1 answered ur question.
    ok after reading n going through ur problem.i wud just like to tell u that u r hunting on a wrong side to find out wat the problem is.
    actually i find that unit is completely okay but its not getting a proper place to throw out the hot air outside because maybe ur ac is fitted in a very congested place were it cannot receive proper n enough fresh air to ventilate.so it gets hot n compressor turns down off to come back to its normal state.again it starts but same thing repeats n compressor goes of again. it will carry on till u place or get ur unit fitted on a proper place where it can get enough fresh air for ventilations. nothging to worry much .thanks.
    pls do rate the solution if it helps u know ur problem n solve it.
    • tech expert12 Aug 14, 2008
      pls refer my solution sir and very sorry for the inconvininceyou are facing from others.
      as the unit is old it starts this type of problem later.
      Master:
    • 623 Answers
    Okay good...good luck
    • 319 Answers
    Excellent,
    Good luck and let us know!
    I have a parc model..36 foots, my ac is not cooling enought.i wont to kow i much btu is my ac..mod:59516-531. tank you
    15,000 btu. Has it been cleaned well recently? Quite often that is all that is required. Has it never cooled sufficiently?
    Aug 30, 2011 | Dometic Rooftop RV Air Conditioner
    We just bought a new 29" 5th wheel camper, that has one 15,000 BTU roof unit. Should this one unit cool the rv?
    Yes if its working properly. A 20 degree temp. differential between its supply air and return air its good.
    Jul 02, 2011 | Dometic Rooftop RV Air Conditioner
    The compressor will not shut off when the temp reaches the set temp the fan stops but compressor does not then freezes up evap coils.the ac is a dometic 15,000 btu quick cool on a 1997 holiday rambler,it...
    This is very much relay problem. The olden days relay get stuck due to residual magnetism. Or spring would have snapped. Or contacts would have bonded permanently. Check these or replace the relay totally.
    May 24, 2010 | Dometic Rooftop RV Air Conditioner
    Rooftop RV Air Conditioner: my duotherm rv ac rooftop 15,000 btu the free...
    If it's the pencil type, it just pokes into the fins (carefully)
    If you look real close with flashlight you should be able to see where it poked in before, usually a couple of inches up from bottom. If it's the little round disc, it snaps in down in bottom corner, there should be a small hole for it in the frame.
    May 17, 2010 | Dometic Rooftop RV Air Conditioner
    A/C starts, goes immediately to heat
    Unfortunately, your rear unit is calling for heat. If you put the rear unit on heat pump mode, does it then cool?
    moz-screenshot-2.jpgmoz-screenshot-3.jpgThe reversing valve is energized in the cool mode of these AC's. So there is no real way to bypass it. I would check the thermostat and the control board in the unit to make sure that the switches are set correctly.
    In the service manual section of the dometic/Rooftop RV Air Conditioner section. I have posted service manuals for the Heat Pump and the Comfort Control.
    Hope this helps,
    Jeff
    Rate me please.
    Jul 06, 2009 | Dometic Rooftop RV Air Conditioner
    1 yr old 15,000 btu Coleman fan blows compressor not working
    The power supply or compressor coil may be faulty. There could be shorted wire, open circuit, bad relay.
    Jun 18, 2009 | Dometic Rooftop RV Air Conditioner
    PROBLEM WITH DOMETIC RV ROOFTOP AIR conditioner
    Check at the compressor terminals between the Red and the terminal for the overload protector to see if you are getting power to the compressor on startup.
    Jul 23, 2008 | Dometic Rooftop RV Air Conditioner
    Dometic a/c, duotherm thermostat, turns right back on after it reaches desired temperture.
    I have a dometic 13500 BTU Roof mount a/c. It is set up with the duo-therm analog thermostat. The system cools fine. The problem is that the a/c gets down to the right temp, then it turns off like it should but turns right back on within a few seconds. Any help would be greatly appreciated.
    May 13, 2008 | Dometic Rooftop RV Air Conditioner
    Dometic Rooftop RV Air Conditioner Logo
    327 people viewed this question
    Top Dometic Heating & Cooling Experts
    Bill Long
    Donni Steen
    mike cooper
    Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
