Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Brushes will not turn
This is a new scrubber. I've had it 2 months. Suggestions!
  • jleachman Aug 19, 2008
    I need an owners manual for a spin hoover steam vacuum. Model number F7220-900 serial number 040500202767. My name is Joyce Leachman. 8 Frances Pl. in Pueblo Colorado. 81008. e-mail is jjl@q.com.
    President:
  • 1,673 Answers
You can get it at hoover.com, click on downloads, enter your model number and it give you a pdf file to download or:
http://www.hoover.com/pdfs/manuals/F7220900.pdf
Posted on Sep 01, 2008
Why it won't pick up water?
Make sure the switch is on the setting you are using, I.E. spin scrub. If this isn't the problem you may have a bad turbine blade, if the scrubber brushes aren't turning that is your problem. $45, a screw driver and general mech. abillities will fix it. http://www.vacpartswarehouse.com
Jul 21, 2014 | Hoover Spin Scrub 50 Deep Cleaner
Hoover windtunnel V2 Brushes Not Turning
There is a worm gear that turns the brushes, it may be damaged
Aug 18, 2017 | Vacuums
Bissell lift off scrubbing bars not working
Hi Pamela. I'm sorry you're having difficulty with the brushes not turning.
Here is a quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=18992&cid=ccsocial
Apr 19, 2013 | Bissell Vacuum, Lift Off Deep Cleaner
I have a Lux Floor Pro Heavy Duty carpet cleaner. Whis attachments (scrubbers) do I attach to the bottom to wash a non-plush carpet. I have three attachments that have hard bristles and three that have...
NEVER USE THE HARD BRUSHES ON CARPET ! You can burn up your motor, break the drive belt,or strip the drive gears The black bristle brushes are for all carpet types.
The hard bristle brushes are made for hardwood and other smooth surfaces.
Oct 24, 2009 | Electrolux UltraLux 2000 Bagged Canister...
My hoover carpet scrubber the brushes won
(1) Remove the brush block and assure the presence of the square drive pin on top of one brush. It should be about 1/4 inch square, two inches long to connect o the drive mechanism.
(2) Remove and clean the filter screen from the base, behind the brushes. Squeeze the two red tabs together, and pull down from the base. Clean the hiar/debris from the screen.
(3) Assure the Brush Speed knob on the hood is NOT set to the OFF position.
Aug 30, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
We have a 2x brushes bissell carpet scrubber. Do
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
x
Aug 29, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Brushes do not turn worked , fine last time i used it a month ago.
The brushes are run by vaccum. Take the brush out and there is a passage way in there that could be blocked. If I rememer correctly there is a screen in there. If that dont help then there is a spring hooked to a lever underneath so when you lay the back down it engages caccum to the rollers. It could be that this is stuck and not moving. Try moving it by hand with the scrubber running.
Jun 20, 2009 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
164 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
