Question about Acer Aspire 3050-1733 Notebook
Battery will not charge
And system will not boot (no power with dead battery) will not power up
with external power supply.
  • michaeljtuoh Aug 09, 2008
    System will still not poer up and battery won't charge. Power supply has green LED on. 9.3 v dc on out put of power supply.
  • 395 Answers
Remove battery and try on mains power.
Posted on Aug 09, 2008
Why My Inspiron mini will not start?
It is unfortunate that the computer is not turning on. Request you to try following the below steps which might help:
    (1)Turn off the computer.
    (2)Remove all the external peripherals like AC Adaptor, flash drives, battery, etc.
    (3)Press and hold the power button for 30sec which releases the static on the computer (if any)
    (4)Put back the battery and plug in the AC Adaptor.
    (5)Let the computer charge for some time.
    (6)Try turning on the computer.
    If the computer doesn't turn on then check hoe the Power LEDs on the system, battery and AC Adaptor react. Then I can check and help you further.
    Thanks and Regards.
    Kiran Kumar.
Jun 22, 2014 | Dell Inspiron Mini 10 Notebook
Toshiba Laptop Dead no bios
Most of laptops batteries have electronics inside them wich test and transmit info about the battery itself. Maybe the fail is there and not in the laptop. Try with another battery befor dumping it.
Dec 01, 2012 | Toshiba Satellite A305-S6859 Notebook
Battery Light flashes twice and does not boot up
Are you plugged in at all? Try with plug plugged in. I think your battery is dead.
Aug 05, 2010 | Acer Computers & Internet
When I try to power on my compaq pesario f700 laptop the light just flashes once and nothing happens I assume its the power supply of the laptop can I replace this myself I am very Tech savy and have...
Remove your battery and try with external power supply again if it boots up all good and proper then after booting to SOE refitt the battery and let it charge - if it doesn't boot or power on look to see if the blue LED it on around your power input point. If there is no illumination around the power input port try another 65w power supply input - your power pack may be dead. Cheap fix - if it still does the same powers on then off - you have reason to go out and buy a new laptop - would be cheaper than replacing the M/board
trust me.
Jun 17, 2010 | Compaq Presario Notebook
My Toshiba Satellite laptop does not fire up at all. Yesterday as I was working the screen blinked a few times and went dead. I can't get it to come back up. Tried connecting to an external monitor but it...
Four possibilities come to mind.
1. Your power supply is bad and the battery ran down.
2. Your system board died.
3. You have a bad device plugged into a USB port.
4. Your battery is bad and holding down the AC power.
To troubleshoot, disconnect all external devices, even remove the CD drive if possible. Try to boot.
Next, boot with just the battery.
Next, boot with just the AC supply.
That's about it. If you still have no power at boot, it is the system board.
Apr 27, 2010 | Computers & Internet
Computer wont boot up
Take the battery out and try to boot the computer up with the external power supply.. If this works the the battery is shorted. If it doesn't then you will need to try another power supply, if that doesn't work then something internal has shorted in laptop
Feb 24, 2010 | Acer Aspire One PC Notebook
Laptop was unplugged while still running ans now
This happens when the battery dies and there is insufficient detectable power to run the boot system. You must change out the battery with a fresh one, or plug in a good external power supply to get things started.
You may also need to let the internal battery charge a short time before the boot system sees enough available voltage to start all systems.
Dec 19, 2009 | Computers & Internet
Lenovo R61 Dead
The power supply in most computers has a fuse, either internal or external, that can blow without you noticing. Basically, you've been on battery operation this whole time, and the battery's finally gone dead.
It will be necessary to open the case and examine the power supply section. It may be possible to replace the fuse yourself, but any operation of this nature that involves opening the case will void any warranty you may have.
Sep 06, 2009 | Lenovo R61 T7300 Notebook
My gateway 700 xl doesnt boot
Unplug the power from you 700xl and from you monitor. Try removing the cmos battery and reinstalling it. Then, plug everything back in and try restarting. If it continues to give you the yellow light, you may need to replace the CMOS battery, especially if it is more than two years old.
Another thing to consider is if your power supply is underpowered for the number of external devices you have plugged into it (i.e., cd, dvd, external hard drives, printers, pci cards, etc). Gateway installed very low powered power supplies in their 700xl desktop computers. Usually only around 250 watts maximum.
If you are replacing the power supply with another 250 watt maximum power supply, and you have a lot of external devices plugged in, you may need at least a 350 watt power supply....if your CMOS battery is not the problem.
Nov 06, 2008 | Gateway 700 XL PC Desktop
Acer Aspire 3050-1733 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
