Question about Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens
I have Canon 300D and need some disassembly procedure.
My Canon 300D shutter broken and i need to disassembly procedure from the front of cemera for replace it, i only have disassembly procedure from back to CMOS (IR filter remove) from this site
http://ghonis2.ho8.com/rebelmod.html.
Anybody can help me to have this procedure?
Regards,
Nawaran
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 155 Answers
Try here - full parts catalog, service manual, technical info and more. Scroll to bottom of page for download link.
Posted on Mar 25, 2009
SOURCE:
When i take a picture the top half is good but the bottom half is black
Are you using the flash? if so then the shutter speed is not synchronized with the flash if no flash is being used then the shutter may need replacement.
Apr 06, 2011 | Canon Digital Rebel / EOS-300D Digital...
My EOS 300d blank images
That problem is normally associated with having a too high shutter speed when using flash. If it happens in any mode, with or without flash you may have a shutter blind issue.
Test the camera at various shutter speeds and compare the results. If this black area is consistant across different shutter speeds, send it in for repair. It is most likely the shutter curtain not making a pass across the sensor fast enough, still obscuring the sensor when a photo was taken.
Aug 20, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
LCD 3/4 Blackout canon 300D
This is fairly common on the 300D - the submirror ( underneath the main mirro ) has a plastic pin that breaks - the camera has to be disassembled to replace. Expect to pay an independent repair shop about $105 or from Canon $180.
Dec 18, 2008 | Nikon D40x Digital Camera
Digital rebel EOS 300D
Once the CF access door is open, just push the small square button that will be below the card. That moves it out enough to pull it out. When putting a different card in, take care not to just jam it in as you could bend the pins.
Aug 25, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Problems with my canon 300d
Your sentence is not making much sense.
Turn the dial in manual to change the shutter speed
Hold the AV button and turn the dial to change the aperture
You can then press the exposure button (*) to see if your settings are too dark or light before you take the shot.
Is this what you want?
Aug 11, 2008 | Canon Digital Rebel / EOS-300D Digital...
Black images
I think the shutter broken.
Your problem is same me.
And now i need some disassembly procedure for replace it by my self.
The technician send, you can disassembly it from front of camera not from back to CMOS.
I only have disassembly procedure from back.
Are you have any disassembly guide from front of camera?
Aug 08, 2008 | Canon Digital Rebel / EOS-300D Digital...
Shooting black frames only
assuming you have the exposure set correctly (if u set way underexpose, the frame will appear black). Try put it in "Auto" mode and see if it works.
If it doesn't, your mirror mechanism may be faulty. One way to check is to take a photo of 2 seconds or longer. Look into the viewfinder, can you see anything through the viewfinder during these 2 seconds?
Jan 24, 2008 | Canon Digital Rebel / EOS-300D Digital...
Infamous error 99 (again!)
shutter mechanism of canon 300d lasts for around 5000 shots or less!! yes it is made of plastic materials thats why here in the philippines I am making my own metal replacement parts that lasts. Unfortunately, in your country you cant do anything but to replace it with same original replacement parts. avoid using faster shutter speed and continuous shots.
Nov 12, 2007 | Canon Digital Rebel / EOS-300D Digital...
Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens Logo
869 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
