Question about Blaupunkt Louisiana DJ32 Cassette Player
Display on blaupunkt alicante cd30
Is there a way to change the bulb or the led on the display of my car radio because it does not light up. The radio works fine but i cant see any thing on the display!!!! Allso the cd disk does not appear to play but i cant be sure because i cant tell what mode the radio is in!! the disk goes in and spins but thats all. The main thing i want to fix though is the display.
  • Anonymous Apr 02, 2009
    exactly the same
  • 774 Answers
It is not worth repairing... get a new one.
Posted on Sep 02, 2017
5 Suggested Answers
SOURCE:
blueextc3221
  • 15935 Answers
SOURCE: To switch itm on
look for power button or "source" button. May be labeled SRC
sometimes it takes a 2 second hold - not just a quick press.
Also could be 3/4 circle with a diagonal dash.
On this unit....
http://www.audiophile.pl/upload/Blaupunkt%20CD/BLAUPUNKT%20ALICANTE%20CD32.jpg
It is upper right button SRC
Posted on Dec 22, 2008
SOURCE: Hi I just purchased a
Hi, I also purchased a car with this equipment. There is no manual. To switch the radio on and off, you will need to press and hold the little blue button (inside the left hand dial) and hold it pressed for a few moments.
My problem is how to eject the CD? Please let me know, if you manage to figure it out.
Posted on Jan 17, 2009
  • 33 Answers
SOURCE: I have a Vauxhall Astra with a Blaupunkt CD30
I could be in demo mode possibly. If you have your owners manual it will tell you how to "defeat demo mode"
Posted on Mar 04, 2009
  • 5013 Answers
SOURCE: How do I remove a blaupunkt alicante radio so I
It should be a standard DIN fitting so the instructions are below
Here is a video showing how to remove a standard radio fromthe dashboard. A pair of extractorsare required (available from Ebay etc ) but these can be made from 2 pieces ofbent, wire coat-hanger or 4 smalldrills(using the blunt end) or 4 small Allen Keys or 4 small screwdrivers or 4 nails or even 4darts. An assistant isuseful to pull the radio out whilst you are releasing the 4 securing clips http://www.youtube.com/watch?v=urC-4NbXvDQ note: on some radios, these 4 holes are protected by 4 small screws. These can be unscrewedusing the appropriate of Allen key. ====================================================
Posted on Jan 18, 2011
Testimonial: "I havnt noticed 4 holes in this head set unlike my old one. This one seems to have two slots on each side which looks like a flat key is needed. Thank"
Hi I need a code for a blaupunkt Lausanne cd30.bp0160y3058189.p/n 7640160310 .thanks
Go online and type in Blaupunkt radio codes. Find a site which gives radio codes for a few bucks, see if yours is carried, pay up and off you go. Check several sites for cheapest .
May 14, 2015 | Blaupunkt Car Audio & Video
Radio code
In most cases yes. You may be able to protect the memory with an accessory plug power pack.
Some radios will hold memory for a short time to allow battery to be changed. Please read your manual or contact the service dept for your car.
Feb 17, 2014 | Blaupunkt Alicante CD32 CD Player
BLAUPUNKT CD30 MP3 CODE
This unit is VIN coded which means it has to be electronically linked to your car.
This is a job for the Main Dealer or a Radio Decoding Service
There is no free or cheap solution on the Internet.
Jan 25, 2013 | Car Audio & Video
Radio leds
They are not LED but tiny "back light" display illumination bulbs, they are soldered on the radio circuit board and best left to repair shop to replace as you can ruin the radio if you don't know what you are doing and overheat the boards.
Jun 19, 2012 | 2007 Suzuki SX4
How do I remove a blaupunkt alicante radio so I can put an aux lead in the back. It is in a Daewoo lacetti if thats any help
Jan 18, 2011 | Blaupunkt Alicante CD32 CD Player
Can you replace the led for the faceplate Jenson phase linear ump401? Thank you in advance
The display is not an LED (Light Emitting Diode) it is a LCD (Liquid Crystal Display), behind the display is a tiny light or light bulbs that back light the display, yes they can be replaced, you can buy the bulbs at Radio Shack if the number can be crossed over, but most likely they are a Radio Shack # 7219 Micro Lamp
Nov 05, 2010 | Jensen Car Audio & Video
How to enter code for blaupunkt cd30 vauxhall
Blaupunkt CD30 Code Entry
Turn on the radio, the display will show 'CODE' followed by '0000'
Press preset [ 1 ] repeatedly for the first digit
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the fourth digit
Finally press the [ station ^ ] button to save.
Jul 13, 2010 | Car Audio & Video
My radio in my 2007 Acadia works fine , but the display just went blank .....Is there a separate fuse for the display ??? Thanks in Advance !!!
Unfotunately not. there is normally a small globe or LED running the face display. Remove the radio and open it up. Check the face side for any light bulb or LED. If it is a light bulb, you should be able to get a replacement part, Otherwise send it in for a repair. Hope this helps.
Jun 08, 2010 | Car Audio & Video
Put in code but could not press enter, entered code but nothing happend so entered it again now its locked
leave it switched on..undisturbed for as long as it takes to automatically reset itself.
If your radio is a BP Lausanne then the code entry instructions are
Blaupunkt Lausanne CD30 Code Entry
blank.gif _uacct = "UA-277454-2"; urchinTracker();
May 05, 2010 | Blaupunkt Lausanne CD31 CD Player
Blaupunkt Louisiana DJ32 Cassette Player Logo
2,190 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Marvin
Marvin
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
