Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Convergence. What are the board locations where I need to replace the resistors to fix the convergence. I have ordered the IC's and jus tneed to know the part number of the resistors? Thanks,
  • 138 Answers
Small signal module 7044 and 7045.
Posted on Aug 19, 2008
Convergence color is not converting
Replace convergence IC (location 8c01) which is a STK-393-110. You will need to order an after market market convergence IC (STK 393-110) I have had good luck with this IC. Next, check and replace all the 3.9 ohm 2 watt resistors, that are bad. You can check them with an ohm meter or visually inspect for burns or peels. Resolder the Convergence board, as by now there are many bad grounds (broken solder connections). Be sure to resolder the jumper jacks that connect the board to the next board too.(Under this board are solder traces that adhere to the jumper connections that will snap to the next board.) These would include jumper jacks PM, VU, and PF. Good luck and thanks for asking, show all hands of support!
Apr 10, 2011 | Mitsubishi WS-55807 TV
Im having a convergence problem with my 50HX70. The tv was working fine until one day i turned it on and there was a blue shadow on the bottom half of the screen. I tried to adjust it and the horizontal...
Tv have a dead convergence board.The convergence board require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the convergence board to fixed the tv picture convergence problems.U have all tools and can do soldering?Yes,tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it urself.Or the shop,will $300-350 for parts and labors.
Mar 18, 2011 | Toshiba 50HX70 50" Rear Projection...
Tv shows circular double lettering on the top and bottom of screen. what is wrong and how can i fix it
Your symptom sounds like a damaged convergence IC.
While it is not a very hard repair, this repair can be a bit tricky. If you have a 45W soldering iron, solder, solder wick, and heat sink2.gif compound you can repair it yourself.
When you remove the old IC's, please be sure to remove all of the old heat sink compound, as it can act as an insulation for the new IC's and cause them to overheat. I usually clean the heat sinks2.gif with alcohol and a small rag.
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110, and they are located on the signal board (on the left as you look into the back of the set).
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
There are also two resistors on the front of the board located in the middle that are fusible link resistors, these should be checked for opens and replaced if they are found so.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
asnowman
Oct 12, 2009 | Philips 51PW9303 51" Rear Projection...
Panasonic PT-51HX42F turns on, no picture and led light blinks three times
This is a common failure for this particular television. The power light is blinking indicate a short in the power supply,
asnowman
Oct 07, 2009 | Panasonic PT-51HX41 51" Rear Projection...
My Mitsubishi vs-50111 has green, red arced line at top and bottom with double vision like suddenly. Any ideas?
asnowman
Oct 07, 2009 | Mitsubishi VS-50111 50" Rear Projection...
Panasonic 1080i
Try adjusting the convergence. If it won't move see below- (or hitting Magic Focus for some Hitachi’s)
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 05, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Convergence blue stopped working. Unable to adjust with controls. what board is it that controls it? The blue is still firing but other colors are starting to waver.
Your symptom sounds like a damaged convergence IC. They are on the Signal board on the left as you look from the back of the set.
There are two and large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110, and they are located on the signal board (on the left as you look into the back of the set).
What happens in the Panasonic set is that the convergence IC’s will short and cause the power supply to shut down from the overload of current. Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
I would suggest that you contact a service center in your area for a complete diagnosis and repair, as this type of repair can get a little tricky. But if you want to repair the set yourself, just remember to be careful. The capacitors and CRT’s can hold a charge and may shock you.
Sep 29, 2009 | Panasonic PT-53TW53 53" Rear Projection...
The TV is blurry with Red and green lines showing
Your symptoms sounds like a damaged convergence IC.
There are two and large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink2.gif. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110, and they are located on the signal board (on the left as you look into the back of the set).
Sep 20, 2009 | Mitsubishi WS-65711 65" Rear Projection...
Magic focus is off remote does not have the correct bottons to fix
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California; they will have the OEM components that you will need.
If you need any further assistance please respond to this post.
asnowman
Sep 20, 2009 | Hitachi 53UWX10B 53" Rear Projection...
THE RED ON MAGIC FOCUS AND MANUAL CONVERGENCE WILL NOT ADJUST
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
Sep 17, 2009 | JVC AV-65WP74 Rear Projection Television
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
56 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
