Question about Lexmark X2500 All-In-One Printer
Scanner Question I have a lexmart all in one printer, scanner, fax..I've had the product for a year and have only use the fax and printer option..Now i'm trying to scan photo and it says the scanner application cannot find download application..Also in the manuel it says click on your productivity suite tab but i reinstalled the driver software and i don't have that software feature
  • schizoeffect Aug 11, 2008
    lexmark x2500
  • daintyslim Aug 12, 2008
    says my application has been moved
I had the same problem so i unplugged my cable and usb cord and uninstalled the program for lexmark. and i put in the cd to install and followed the directions as if i was installing it for the fist time and viola it worked. Good luck
Posted on Aug 14, 2008
Can you also Fax with this One Touch 8900 ?
This is only a scanner. To Fax, you will need a separate fax machine or fax modem. If both the scanner and fax machine are connected to your computer, you will be able to scan the document and then fax it from the computer. (Depending on your OS/software, this could be easy or take several steps. For Windows Vista and Windows 7, you can use Windows Fax and Scan to do both steps. (However, the program doesn't scan to PDFs.) Paperport will also send a scanned document to an installed fax option. PaperPort is part of the third-party software that came on the CD with the scanner.)
Documentation for the Visioneer OneTouch 8900 is available here: http://support.visioneer.com/products/8900/default.asp .
I hope this helps.
(There are some email-to-fax and web-to-fax options but I have not reviewed them.)
Jul 14, 2011 | Visioneer OneTouch 8900 Flatbed Scanner
Installing Printer/scanner kit to Ricoh Aficio 2015
the main part of the kit is a dimm card. the dimm has the fax/scan/print stored on it. the problem adding this to your machine is drivers, only twain scanning, no scan to folerd, no internet faxing, no winodws 7 drivers. if you get a whole kit you need to add the fax pcb and also get the nic for it to scan properly. good luck
Dec 23, 2009 | Ricoh Aficio 2015 Copier
I have a Lexmart X4270 Printer Copier. I replaced the print cartridge but it still doesn't print.
Are you using a factory new ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
Don
Oct 27, 2009 | Lexmark X4270 All-in-One Multifunction...
Scanner won't work with windows vista
Option one: Scan using Windows Fax and Scan
  1. Click the Windows icon (c01319360.gif ), click Programs , and then click Windows Fax and Scan .
    NOTE: The Windows Fax and Scan option is available in the Business, Ultimate, and Enterprise editions of Windows Vista. If you have the Home Basic or Home Premium edition of Windows Vista, skip to Option two: Scan using Paint .
  2. Click New scan .
  3. Click File , and then click Scan .
  1. Click the Windows icon (c01319360.gif ), click Programs , and then click Accessories .
  2. Click Paint .
  3. Click File , and then click From Scanner or Camera .
  4. Click Scan .
Jul 01, 2009 | HP Officejet 5610 All-In-One InkJet...
HP 7590 office jet pro scanner does not communicate
The scanner function is not available when you are connected wireless, you must be connected via USB to your PC for the scanner to function correctly.
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Jun 17, 2009 | HP Officejet Pro L7680 All-In-One Printer
Fax copies are unclear
I SORRY I CANNOT HELP YOU AT THIS TIME
OTHER OPTION
ONLINE AND TYPE
LEXMART X342 ALL IN ONE PRINTER INTERMITING PRINTING ERRORS
LEXMART X342 ALL IN ONE PRINTING PROBLEMS
LEXMART ALL IN ONE FAXING PROBLEMS
GO INTO CONTROL PANAL, OPEN FOLDER, GOTO
PRINTING PREFERENCE, SERVER PROPERTIES,
PROPERTIESS AND LOOK AROUND AND SEE IF YOU CAN FIGURE IT OUT
ROD
Feb 02, 2009 | Lexmark X342n All-In-One Laser Printer
I have Windows Vista and had my Lexmart all in oneworking with it. When I tried to put the scanner part in my computer says my printer spooler isn't working. I've tried to restart the printer spooler but...
Maybe there is a problem in the scanner driver they use the same spooler. Try to uninstall the printer and scanner driver. Re install first the scanner before the printer
Apr 15, 2008 | Office Equipment & Supplies
Scanner Failure: HP Officejet 6210
After hours of trying things.I found this and it worked. The scanner button doesn't work, but at least I can scan.
?id=microsoft.windows.resources.expandarrow To scan a picture using Windows Photo Gallery
    Before you begin, make sure that you've installed your scanner on the computer and that the scanner is turned on.
  1. ?id=microsoft.windows.resources.shellexecutetopiciconClick to open Windows Photo Gallery.
  2. Click File, and then click Import from Camera or Scanner.
  3. In the Import Pictures and Videos window, click the scanner that you want to use, and then click Import.
Jan 27, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Lexmark X2500 All-In-One Printer Logo
59 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
