Question about XM Radio (XMP6000)
Xm stopped working display says "antenna"
After almost 4 years with no problems my xm suddenly stopped working. the display says "antenna". i checked all the wires and connections-everything is intact. i have a pioneer xm ready car stereo. what gives?
  • 1 more comment
  • Anonymous Sep 09, 2008
    radio display says decades on it
  • carolmatton Jan 05, 2009
    i just had the second xm antenna installed three months ago just stopped working out of the blue.
  • Anonymous May 11, 2009
    Same thing - I have a My-Fi and it just absolutley will not work with any antenna. I have two external hook-ups one for the house one for the car and it doens't work with either...and that includes separate docking stations. I even tried the goofy little antenna that is supposed to clip on your hat (very stylish I might add) and that doesn't work either. Pretty frustrating.
Broken antenna cable. Likely you have a kink or worn thru point on the wire somewhere.
Posted on Sep 17, 2008
My TV suddenly stop receiving signal via antenna. What can I do?
Check and replace its tuner. If you wish to get some details; check the site linked here. Pull up older posts.
Sep 03, 2016 | Dynex DX-LCD37 TV
Cant get xm weather on garmin 740s
To receive XM weather or audio, the GPSMAP 740s requires a GXM 40 Smart Antenna with XM subscription.
The GXM 40 Smart Antenna (010-00730-00) is used to receive weather and audio service from XM satellite radio. For details on XM services please visit our XM webpage.
Once a GXM 40 Smart Antenna has been connected to the GPSMAP 640, the device can display the subscription information for the antenna.
From the Home Page in Boating mode:
  1. Select Configure
  2. Select System
  3. Select System Information
  4. Choose Weather Subscription
From the Home Page in Driving mode:
  1. Select Tools
  2. Select XM Services
  3. Select XM Radio
  4. Set the channel selector to channel 0
  5. Select Radio ID
The subscription information will now be displayed on the screen.
Mar 26, 2011 | Garmin Gxm 51 Weather And Audio Xm...
I have XM radio in my chevy malibu. Worked fine
I believe when the antenna loses power it does not show it on the screen sounds like there might be a break in the antenna wire or simply came out of socket in the rear of the radio.
Nov 03, 2009 | XM Radio (XMP6000)
XM radio is not working. Tries to 'Load' but then says 'no signal'. XM says that I am receiving the signal but Honda says there is no problem. They want to try to replace the antenna for $500 but are...
You best bet - if you can get to the rear of the XM tuner unit, is to temporarily connect a magnetic-mount XM antenna and see if it works. A bad antenna usually says "check antenna" - not loading could be a good antenna with a bad location. I would try the little XM antenna by itself, then go from there. $20 is a lot cheaper than $500. Let me know how it works out.
Oct 30, 2009 | XM Radio XM Direct 2 Mini-Tuner Car Kit...
No Signal on XM Radio - Goes in and out of Signal
xm will not hold signal but if I move the antenna wire around inside the vehicle it will suddenly come in clear as day
Sep 02, 2009 | Delphi Roady2 SA10085 XM Radio Receiver...
No signal problem on xm home satilite docking staion
You have probably lost a local repeater. Try moving it temporarily to a south-facing window. Here's another one to try: Put in dock and turn off with button on unit. wait 10 seconds, now press "2" "0" "7" "XM" buttons one at a time in that order ON THE FRONT of your SkyFi2 and the radio will go ON by itself! Now, press "Display" 4 times. You will see a screen that says "SAT1", "SAT2" and "TERR". You need a constant checkmark for DEMOD on at least one of the 3 boxes. Please tell me which ones are checkmarked and the average "BER%" number is. The lower the BER% number, the better. If BERis 100%, you are out of luck. Write back and let me know what you read. Press "Display" 5 more times to go back to regular screen. Thanks,
John
Aug 20, 2009 | Delphi SKYFi XM Radio Receiver
All of a sudden my radio displayed acquiring signal and now nothing will work. I have reset it to factory default and still nothing.
Tuner needs to be replaced. Where the antenna is input into the board, it has a bad solder joint. If it's older than a year that's the problem. It has been a BIG! issue with SIRIUS & XM. Sorry for bad news but I hope this helps.
Jun 21, 2009 | Sirius Satellite Radio Receiver
Roady xt Antenna Problems
when it reads antenna it means there something wrong with either the connection or the antenna itself, it could be the location of the antenna or the antenna is going bad. if there is no obstructions on the car blocking the antenna i would advise purchasing a new antenna. you can get one at http://shopdelphi.com/consumers/satradio/xpressrc/
Feb 07, 2009 | Delphi Roady XT XM Radio Receiver
Xm not working
I had a short in my TERK antenna and it gave me the same problem.
If you know someone else using xm, you can try their antenna to see if that is.
I took mine to Best Buy and they had one they checked it with.
Best of Luck.
Oct 15, 2007 | Pioneer DEH-P3370XM CD Player
Delphi Roady XT Quit Working
Chances are it's not picking up the XM signal. First, contact XM to resend your setup. if that doesn't work check your antenna connections.
Oct 31, 2006 | Delphi Roady XT XM Radio Receiver
Car Audio & Video Logo
2,000 people viewed this question
Top XM Radio Car Audio & Video Experts
xxxxxx xxx
John
John
Are you a XM Radio Car Audio and Video Expert? Answer questions, earn points and help others
