Question about Maytag Kitchen Ranges
Maytag oven cwg3100aab does not come on. There is a click at the controls but the electronic igniter does not spark. The gas valve is on and the thermostat was replaced a year ago.
2 Suggested Answers
  • 530 Answers
SOURCE: Maytag MGR6775 Gas stove. One igniter not working.
Clean the burner with a wire brush around where the ignitor is. it needs a proper ground to ignite. When you turn the burner on do you hear a click click click? If so this should solve the problem.
Posted on Jan 04, 2009
I am trying to find a replacement part for a 24 Maytag Wall Oven, model CWG3100AAB. I am getting an F5 code, and I believe that means it is the ERC electronic control board.
Single/Double Wall Oven - Error Code/Message - F5 Error ...
www.maytag.com/...wall-oven...code...f5...code-f5-e0/PH7028/
MaytagHave a Maytag product question? Maytag's product help articles give answers to your frequently asked questions (FAQs).
Sep 30, 2015 | Maytag CWG3100AAB Wall Oven gas
What is a pilot generator
Simply put, a pilot generator is a thermopile that generates millivolt power to operate a gas valve.
However, on your convection oven, yours operates on an electronic spark, which is generated by an electronic ignition control module.
Jul 29, 2014 | Vulcan SG4D Gas Single Oven
My maytag mgr5729adw gas range oven omits a strong gas smell when attempting to preheat. Sometimes it heats sometimes it doesn't but use to get a small boom when igniting. Ignitor still glows oran
see the next steps and proceed with common sense: God bless you
Main Control / Oven Switch
The main control or oven switch may have failed. You will need to identify the wires from the switch/control that lead to the igniter that is clicking. These wires may pass through the spark module and change colors. Refer to the wiring diagram or tech sheet. If you have power leaving the switch/ control when in the off position replace the switch /control. Manual switches can be tested with an ohmeter.
Spark Module / Igniter Module
If your oven igniter keeps clicking the igniter module or spark module is the likely problem. First be sure the igniter is clean and the surrounding contact points are clean. Make sure power is off when cleaning. If the oven keeps clicking after it's cleaned and the oven switch / control checks good replace the spark module.
Jul 26, 2012 | Kitchen Ranges
I have proble with whirlpool gas range SF265lxtq When I tried to use the oven, I setup the oven by the keypad, but the oven does not get hot, and i did not smell gas. What should I do ?
Your Direct Spark Ignition System contains a
Gas Distribution Valve and a Direct Spark Ignition
(DSI) Control that interfaces with the
Electronic Oven Control, and spark electrodes.
This provides the direct spark ignition and gas
distribution for Whirlpool self-cleaning gas freestanding
ranges. You must familiarize yourself with this system
before attempting any repair. Look through this service
repair manual for direct spark HERE
Mar 01, 2010 | Whirlpool SF265LXT (Gas ) Kitchen Range
Maytag model CWG3100AAB error code f3
when the clock goes off on my oven the oven stopsand will only come back on when it is cooled off.
Jan 18, 2010 | Maytag 24" Built-In Single Gas Wall Oven -...
I replaced what I thought was a bad igniter.But still had no glow from new igniter. Must be something else.Where do I go from here?
Hello there: The oven bake burner and ignition components are located beneath the oven cavity. In most cases the oven bottom panel can be removed for access (check your owner's manual) but on some models the oven burner has to be accessed from below in the warming or broiler drawer area. If accessing from the top, a 'flame spreader' (flat metal plate) above the burner may also need to be removed to see the burner itself.Many ovens use a single oven burner in which case they only have a single gas valve and ignitor. The same burner is used for both bake and broil functions, the broil usually being in the drawer area below the oven. Higher-end models may have a separate bake and broil burner. On such a system there will be two ignitors, one for each burner. They may also employ a 'dual' gas valve (see illustration above) instead of using a separate valve for each burner.Some range models may have an additional broil burner located at the top of the oven cavity which may be referred to as a 'waist high' broil. If not, broiling usually takes place in the drawer area below the oven, which uses the same bake burner for the broil function. Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too.
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system.
Making Observations
The oven burner's operation will usually need to be directly observed while in operation as the first step to troubleshooting problems.Ignition System Type Links
Ignition System Types:
  • Pilot Ignition
  • Electronic Ignition with Constant Pilot (rare)
  • Electronic Ignition with Glow Ignitor (most common)
  • Spark Ignition System
  • Is there continuity between the oven gas valve's terminals?
    Hot Surface ('Glow Bar') Ignition System (most common)
    This is the most popular system currently used for ovens and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve.
    What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame.
    It should usually only take in the area of 30-90 seconds for the oven ignitor to reach the proper resistance to allow the proper amperage to reach the gas valve to open it and for the ignitor to ignite the gas at the oven burner.
    Dec 30, 2009 | GE Ovens
    Oven doesn't light. I have a Maytag MGR5750. The pre-heat light comes on but no ignition. Stove top burners work okay.
    First thing to do is verify if the hot surface igniter or spark igniter is working. If the oven has a bottom broiler compartment then you can check from the bottom compartment. If it has a top broiler then you may need to remove the inner bottom cover inside the oven to look at the burner and igniter. Now turn on the oven and watch for the hot surface igniter to start to glow or the spark igniter to come on. If the igniter comes on then give the gas control valve(located at the bottom broiler/storage compartment) a tap with a wrench or a screwdriver. If the burner comes on then shut the oven back off and on several times COMPLETELY. If it works then you may have fixed the problem by dislodging debris in the valve. If it does not come back on then the gas control valve may be defective or the igniter could be weak. The igniter should be tested with a ohm meter and if it tests good(500-700 ohms usually) then the gas control valve will need to be replaced otherwise the igniter is bad. On spark ignition systems there is a different procedure. Another thing to check is the "runaway valve" that is located on the gas regulator for the range. It is a little lever located where the oven gas pipe comes off the regulator and cuts the gas to the burner when closed.
    Oct 16, 2009 | Maytag Kitchen Ranges
    My Amana gas oven won't heat up gas smell strong
    Sounds like a sticking gas valve or a defective hot surface igniter. Open the broiler drawer or remove the bottom cover in the oven compartment. The oven usually has a hot surface igniter or a spark igniter. Turn on the oven and watch for the hot surface igniter to start glowing. It should glow very bright. Once it is glowing the burner gas should come on. If you hear the gas come on it should light right away. If there is any delay shut off the oven and stay back. Let the gas clear out then inspect the area near the igniter and make sure the burner is not plugged(the little holes may have debris in them). If you turn on the oven and the igniter comes,glows brightly,no gas is heard but you can smell gas it is either a blocked burner orfice/assembly or sticking gas control valve. Try giving the burner and gas control valve a tap and see if it comes on. If you tap the control valve and it starts working then shut of the oven and try it several times. If it starts to come on and off now you may have cleared whatever debris was causing the problem. If it does it again then it could be the control valve or a weak hot surface igniter. The igniter can be tested with a ohm meter. Most of the time when I get this complaint it is the oven control valve that is sticking. Be very careful when doing these procedures....gas can build up in the oven compartment very quicky and flash if ignited. Always have the gas shut off valve at the back of the range within reach and the electrical outlet in case you need to unplug it.
    Sep 13, 2009 | Magic Chef 9122 Gas Single Oven
    How do I utilize the self cleaning part? Do I just press ''clean
    1. After self cleaning the range the door won't open
    2. Amana gas range conversion from NG to propane
    3. A tip on cleaning the surface grates
    4. Checking an common oven temp sensor
    5. Checking an common oven temp sensor: What does an oven temp sensor look like?
    6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
    7. GE gas range conversion from NG to propane
    8. How to change the oven temp on some common electronic controlled ovens
    9. How to re-light a surface or oven pilot light
    10. How to change a common oven glow igniter coil
    11. How a common gas valve works - click here.
    12. How Ranges, Ovens, and Stoves Work
    13. Help for storing an appliance
    14. Important Disclaimer
    15. Installing a gas flex line connector
    16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
    17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
    18. My gas range flames die when I turn on more than one thing at a time
    19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
    20. My surface burners keep "clicking" even after the burner is light
    21. Oven door and door hinge help
    22. Oven temp sensor - how to change helps
    23. Repair tips and information on surface burner spark modules and igniters
    24. Some "how to set the self clean" on my range
    25. Stainless Steel Cleaning
    26. Surface burners wont work
    27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
    28. Test for F1 fault code
    29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
    30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
    31. Whirlpool Direct Spark Ignition (DSI)
    32. Yes, your glow bar igniter can glow red and still be bad!!
    Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
    GE Profile Gas Range oven light doesn't work even after changing
    Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    Kitchen Ranges Logo
    105 people viewed this question
    Top Maytag Kitchen Ranges Experts
    vince
    gbob59
    Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
